12-20-2021, 02:13 PM | #1 |
Rep 10,859
IND | Fall-Line Motorsports G8X M3 / M4 Oil Cooler Guard
MADE IN THE USA. The G8x M3 and M4 cars are incredibly well sorted from a cooling standpoint. Even in a road course environment with extremely high ambient temperatures, the S58 engine tends to operate beautifully, with consistent oil and water temperatures. BMW M invested a great deal of time, money, and effort into designing a cooling system that worked in nearly every condition that the M3 and M4 would be tested in. Although excellent ducting, good core design, strong fans, and other factors all play in to how well a cooling system works, there is one ultimate factor which cannot be circumvented- you must have enough heat exchanger surface area, and you must have enough heat exchangers. When examining the front of an M3 or M4, then, we see the hard work of the M engineers in packaging the various cooling components of the car. Everything had to be accounted for, and given ample space, surface area, and ducting. Unfortunately, this leaves the S58 engines oil cooler precariously exposed with no protection. A direct impact to the oil cooler can have catastrophic effects, draining the S58 of all of its oil in seconds, a fact that more than a handful previous generation M3 and M4 owners have had to learn in a painfully direct way. Having seen that this was a critical need for the M3 and M4 cars, IND worked with Fall Line Motorsports to develop a robust oil cooler guard, specifically designed to shield the S58s oil cooler from large road debris and prevent disaster. The new Fall Line Motorsports oil cooler guards will be constructed from thick stainless steel plate, and will fasten directly to existing frame members on the G80 and G82 cars, spreading any impact across strong structural components. Special care was taken to ensure that the opening in the oil cooler guard matched the shape and size of the existing BMW oil cooler air outlet, ensuring that proper air flow is maintained. Product Details:
The Fall-Line Motorsports G8X M3 / M4 Oil Cooler Guard may be viewed at the following link to our online store: https://ind-distribution.com/product...l-cooler-guard Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com
11-14-2022, 10:55 AM | #3 |
Rep 28
Any coupons for this BLACK FRIDAY Sales??
IND-Distribution9572.00 |
