10-02-2023, 09:41 AM | #1 |
Rep 110
Damage to Vehicle Detected
Quick question..... Is everyone else going to the dragstrip running into the "Damage to vehicle detected" message when launching? I've always been able to knock out consistent 1.6 60's with this car and it happens every so often. Last outing I had a hard time resetting the message. It doesn't seem to affect performance at all.
Also.... 1st outing I was seeing 11.3-11.4 @ 115-117 and this past outing was 11.2-11.3 @ 119-120. DA was 2900'. I think this car has a 10 second pass in good weather.... |
10-02-2023, 09:48 AM | #2 |
Rep 1,282
If you have track mode enable it, the threshold for triggering that warning is higher.
Also if you tune the car it can be raised as well. |
Jasinedward65.50 |
10-02-2023, 11:10 AM | #3 | |
Rep 110
Is there a way to lengthen launch control? I've sat at a light before but LC seemed to time out... |
10-02-2023, 11:14 AM | #4 |
Rep 1,282
Stock no, tuned yes the launch params are adjustable.
To be clear regarding the damage detection m1/m2 doesn’t matter, that’s just recalling your presets. You have to set the display to track mode (center screen will be turned off) to get the increased damage threshold. If you don’t have the m drive professional package on your car then you won’t have track mode. |
Jasinedward65.50 ChrisM41653.00 |
10-02-2023, 11:21 AM | #5 | |
Rep 110
10-02-2023, 11:50 AM | #6 |
Rep 1,282
Jasinedward65.50 |
10-14-2023, 11:02 PM | #7 | ||
Rep 994
Drives: 2024 M4 Comp X-Drive
Thanks for this, great info…couple of quick questions… - At the drag strip after you use launch control are you able to hotlap the car or do you need to drive it around for a bit before you can use it again? - Also are you able to park and let the car cool and then use LC again when going back to the staging lanes? Thanks!
10-30-2023, 10:27 AM | #8 | |
Rep 110
10-30-2023, 10:49 AM | #9 | |
Rep 6,729
I have track mode but the windows still rolled up, the seat adjusted forward and the belt retracted as it was sensing a crash. Don’t know how to turn it off. |
