06-07-2022, 03:12 PM | #23 |
Rep 7,009
Likely to adjust for a taller tire/ sidewall and still have the same turning clearance, inside the wheel well.
YT: G Dubyou |
IAm379.50 |
06-07-2022, 03:53 PM | #24 |
Rep 501
Ive used this calc in the past https://tire-calc.com, works well and easy to use. Stay within 1% as has been said for xDrive and you should be fine IMO.
You should also be weary of the tire brand, although a tire is 285 for example, it can vary by MM between brands, which can affect your numbers if youre running at the edge of tolerance youre looking at. |
Limegrntaln13602.50 |
04-26-2024, 08:17 AM | #26 |
Rep 2,472
Doing the math the factory rear = 285/30/20 and I知 looking to run a 295/30/20 = +1.1%
Should I just keep the factory 285/30/20 as I知 now > 1%?? Looking to run 275/30/20 up front |
04-26-2024, 06:10 PM | #27 | |
Rep 739
In this case a 275/30/20 front and 295/30/20 rear would be a 1.9% difference and definitely out of range for xDrive. A 275/30/20 front and 285/30/20 rear is a 0.8% difference, which should be fine for xDrive.
pdjafari153.00 |
04-28-2024, 11:46 AM | #28 |
Rep 387
There are literally dozens running 285/30/20 and 295/30/20 on Xdrive. I am one of them. Been running this set up for almost 7k miles on custom tune and and XHP. Zero (0) issues.
