04-03-2024, 10:09 AM | #1 |
Rep 36
PPF Issues
So this is my first car that’s ever gotten PPF applied and I’m wondering if anyone has encountered similar issues.
I went with a full front + roof + b pillars. There are a few dust specs underneath on some of the panels but I figured that might be normal. You don’t really see them unless you’re washing the car which brings me to my question. He also had to redo my roof as it was peeling up from the edges. I washed the car over the weekend and noticed the bubbling from the PPF on the pillar of the rear passenger window. Installer is blaming my pressure washer but I don’t know if I’ve seen anyone having issues with peeling/bubbling PPF before. My pressure washer is just a cheap karcher but I’ve got an obsessed garage sprayer and wand so it’s setup for flow, not pressure. Am I out of line here? Is this normal for PPF and I just need to be careful around the pillars? He also didn’t pull the hood emblem or fender badges when doing the initial install which was a head scratcher for me. |
04-03-2024, 10:25 AM | #2 |
Rep 208
I'm not a PPF expert but I don't think you're out of line. I would think PPF should be able to stand up to modest water pressure equivalent to an automatic car wash. I think you have a right to complain about the job they did here.
Limegrntaln13477.50 Gberg211943.50 |
04-03-2024, 10:27 AM | #3 |
Rep 497
What spray pattern tip(s) were you using? Also, how long was the car PPF'd before you washed it?
Installers are all different but I personally wouldn't want an install that didn't involve removing badges/emblems. |
04-03-2024, 10:50 AM | #4 |
Rep 692
That is NOT normal from my experience. I would definitely ensure they know. I’m not an expert so I won’t criticize but I would have them reinspect things.
04-03-2024, 10:51 AM | #5 | |
Rep 36
I thought he would remove the emblems but I guess I should’ve asked. The fender had me concerned as well as you can see some crud at the bottom of the fender badge. Will this eventually cause the ppf to peel up? I have no idea. |
04-03-2024, 11:08 AM | #6 | |
Rep 497
Yeah, they should've removed the emblems because it will result in problems like you're having on the side vents. Unfortunately that build up isn't going to get better. You can try to clean it with a soft detail brush. If it gets really bad, it will have to be trimmed out. |
04-03-2024, 11:14 AM | #7 |
Rep 170
From what Im seeing and I do PPF ..... The Pillar not normal needs to be re done the Fender will just keep collecting dirt and spread more it will need to be trimmed or re done as well ....
Limegrntaln13477.50 |
04-03-2024, 11:43 AM | #8 |
Rep 3,963
Both areas in the pictures look terrible. Those bubbles will not get any better and will likely get worse.
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5 |
04-03-2024, 12:02 PM | #9 |
Rep 2,610
I would think pressure washing issues would be peeling, not random bubbling in the middle of an application.
04-03-2024, 12:39 PM | #10 |
Rep 36
He said he'll replace the B pillar but blaming the pressure washer kind of shocked me. I didn't bring up the side marker but will when I take it back for the B pillar fix.
Lots of people get their very expensive cars PPF'ed and use pressure washers with no problems. He said he didn't remove the side markers because of the risk of breakage which I know is . Pros can remove the emblems put them back no problem. |
04-03-2024, 02:23 PM | #11 | |
Rep 497
He should be experienced in removing all sorts of trim, emblems, etc. It's a lesson learned but you should always ask the installer all of these questions (and a bunch of others) ahead of the work being done but now you know for the future. |
04-03-2024, 07:12 PM | #12 | |
Rep 36
Just sucks because this is kind of my “forever car” and I’m stuck with a mediocre PPF job. |
04-03-2024, 10:38 PM | #13 |
Rep 858
Honestly dude, your PPF guy should probably not be doing PPF. I hope you didn’t pay a lot because you got ripped off by a goofball installer.
04-04-2024, 12:44 AM | #14 |
Rep 6,962
Im no professional, but, I think this installer was doing what you call "working dirty" Not working in a clean environment, and allowing contaminants into the work. My entire car is PPF'd and STek Dynoflex is amazing. Ive had mine installed for about 27 months, now, and its been perfect. As they say, its all about the install, and it looks like this install was destined to be a thorn in your side, straight from the start. My installer never sweats me using a pressure washer on mine, because, as they say, once its cured, it should be considered a semi permanent part of the paint. They need to heat seal the edges to make sure nothing gets in.
YT: G Dubyou |
04-04-2024, 08:26 AM | #15 |
Rep 497
If this is a "forever" car, you might just want to cut your losses and get the PPF redone by an authorized installer of the brand you choose. I've had PPF done to a lot of cars and never once had to replace any of the film due to these sort of issues.
04-04-2024, 08:56 AM | #16 | |
Rep 36
There are a few more dust specks or whatever they are but when I brought it up he said he couldn’t guarantee a dust free install. That also annoyed me but given how he’s had to redo the roof and now the b pillars, I wasn’t going to push him on it as it would likely be even more of a rush job. FWIW this film is Covrgard which looks to be a new company. I’m already about $2,800 in the hole with this guy. No idea how much it would cost to have another shop remove this film and apply their own. |
04-04-2024, 04:08 PM | #17 | |
Rep 6,962
I would get on Yelp in your area, or if you have other Bimmerpost, or BMW guys in your area, and find a shop that does amazing work. I like in the Sacramento area, and the shop that does my car, is unbelievable. I bought all of my OEM carbon after my car was full PPF'd and they said, bring it down, and we will just take care of it for you. They wrapped my OEM side skirts, my OEM front lip, and my OEM winglets, for nothing. And they do such a good job, everything is still flawless, 27 months, and 16k miles later.
YT: G Dubyou |
04-04-2024, 08:58 PM | #18 | |
Rep 36
I’ve also thought about reaching out directly to the manufacturer since they’re a relatively new company and their website has no dealer locator that I can find. Was thinking of trying to find a different installer to fix it under warranty. It’s been raining like crazy here the last few days so I went into the garage to take a look at the fender badges. Not good. Not good at all. |
04-04-2024, 09:00 PM | #19 | |
Rep 3,963
04-04-2024, 09:36 PM | #20 | |
Rep 36
Noticed the weather stripping is a little messed up on the roof and the corner is starting to peel up again. For those who’ve had the roof done, what do your corners look like? Is the film just not pliable enough to hold that corner? |
04-04-2024, 10:09 PM | #21 |
Rep 497
I have XPEL Gloss on the non-painted and carbon fiber surfaces with XPEL Stealth on the painted surfaces. I have my car fully covered.
Roof rear: Roof front: Side vents: Those pics are under harsh light using an Astro Pneumatic light. My installer removed my vents during the install so the film is tucked behind, there are some shadows reflecting but the film is tucked. I replaced my vents with the M Performance CF vents during the PPF. There are a bunch of threads on how to remove the side vents, it's very easy with a pry tool. There are 3 white clips per side. My car was done with a combination of hand cutting and the computer/plotter. I think part of the issue might be the product in addition to installer rushing. You definitely shouldn't be having issues like this after a few months. Hope that helps a bit. |
Gberg211943.50 |
04-04-2024, 10:10 PM | #22 | |
Rep 3,963
