02-23-2022, 10:20 AM | #2 |
Rep 415
No, nitrogen is an addition when you sign the papers. It is a pointless addition too. Nitrogen is something you only need when you are racing. They tried to sell me it too along with extra insurance etc.
02-23-2022, 10:23 AM | #3 |
Rep 453
My dealer didn’t even try to sell it to me. Guess they know me by now.
jimbethesda1857.50 |
02-23-2022, 10:26 AM | #4 |
Rep 73
Drives: F90 M5, G80 M3C, Tesla M3
Garage List 2020 LR Defender 110 [0.00]
2021 BMW G80 M3C [0.00] 2017 Porsche Macan [0.00] 2019 BMW F90 M5 [0.00] 2020 Tesla Model 3 [0.00] |
What's the benefit of having N2 in your tires?
02-23-2022, 10:33 AM | #5 |
Rep 241
It's supposed to be some what more stable.
I was not charged for it. Payed MSRP with no extra add on. |
KylianHamilton64.00 |
02-23-2022, 10:37 AM | #6 |
Rep 749
KylianHamilton64.00 Limegrntaln13546.50 |
02-23-2022, 10:53 AM | #7 |
Rep 2,744
Many dealers sell it at ridiculous premiums. If it's a couple bucks, go ahead and splurge if you'd like, but it's not worth the minuscule differences.
https://www.consumerreports.org/tire...s-a6260003694/ https://www.aaa.com/autorepair/artic...late-car-tires
02-23-2022, 11:10 AM | #8 |
Rep 7,001
I wouldn't call it worthless. I think the dealers overcharge for it, but they need to pay for their equipment they purchased to provide the nitrogen fill.
Nitrogen is an inert gas, meaning that its not flammable. It's also lighter than the air it displaces, meaning there are no explosive blowouts, like when you pop a balloon, with a needle. We used it exclusively in the airline industry, for filling tires. The gas is more stable, which means there is less of a pressure difference, from cold to hot. So, as our tires get hotter, from use, the pressure fluctuation, is less. When tires filled with Oxygen, heat up, you can expect to see a temperature difference between 4° to 7° F . While the swing with Nitrogen may be 0° to 2° F, causing a lower heat cycling range, effectively, slightly, lengthening tire life, from less heat damage.
YT: G Dubyou |
02-23-2022, 11:31 AM | #9 |
Rep 1,282
you guys realize that air is nearly 80% nitrogen to start with right? It is impossible to get 100% nitrogen into your tires. Realistically, you're getting it filled out of poorly maintained equipment by a tech who doesn't give a shit. Maybe you are getting 90% N2 instead of the 78% you get with regular air. Very much not worth it outside of specific circumstances.
02-23-2022, 11:51 AM | #10 | |
1947
Rep 1,908
Drives: E92 M3
The usual air compressor machines at gas stations are going give you a mix of water vapor and air where the air is 78% nitrogen, 21% oxygen, and the rest is "other" because that's what our air consistent of. Nobody is filling tires with air that has substantially more oxygen. If you're filling your tires on a very humid day, that water vapor displaces nitrogen, oxygen, and other gasses. What you get now is maybe 1% water vapor and 99% air as opposed to maybe 0.5% water vapor and 99.5% air. (These are made up numbers) When you do a nitrogen fill, those air content ratios are changed where the best machines get you as close to 99% nitrogen as they can and the rest is "oxygen, other." Typically, the nitrogen contents aren't close to 99% and much closer to 78%. However, it is much dryer air so the pressure will be relatively more stable compared to regular air/water vapor mixes. Take a look at this tire filling machine that drys compressed air or nitrogen - https://www.intercompracing.com/docu...ner-Racing.pdf If your dealership has that, use it and worry much less about your tire pressures.
Nkr151123.50 Limegrntaln13546.50 |
02-23-2022, 12:25 PM | #11 | |
Rep 2,744
02-23-2022, 12:30 PM | #12 | ||
Rep 7,001
YT: G Dubyou |
2011ninja3412.50 |
02-23-2022, 12:36 PM | #13 |
6920
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
Nitrogen has been proven pretty reliably to show no material improvement for passenger car tires. The fact that places charge money for it is even worse.
02-23-2022, 01:21 PM | #14 | |
Rep 7,001
Why Nitrogen? Nitrogen is Air – without the bad stuff. Air is about 78% Nitrogen, 20% Oxygen with moisture and some other gases. Tires loose pressure because air goes right through the rubber. This is called permeation. The Oxygen in air escapes much faster, causing quick initial pressure loss. Laboratory guides rate the permeability rate through rubber of Oxygen at 23.3 vs. Nitrogen at only 9.43. Oxygen, CO2 and Helium all leak faster than Nitrogen. Oxygen is also reactive. “Oxidation” weakens, dries and cracks rubber. It can also damage Alloy rims and break-down sealants. Moisture can corrode valves from the inside causing problems with proper valve closure. All problems with regular air are accelerated by pressure. Nitrogen is the best solution. Nitrogen inflated tires maintain a more consistent tire pressure across different temperatures. Tire performance is more reliable and efficient when recommended tire pressure is maintained and heat is reduced. Most auto dealers recommend Nitrogen inflation exclusively for vehicles with tire pressure monitoring systems to prevent heat-related pressure warnings from your vehicle.
YT: G Dubyou |
2011ninja3412.50 |
02-23-2022, 01:42 PM | #15 |
Rep 2,638
This is why non car people think I'm out of my mind.
We will debate the value of nitrogen to standard air pumps to inflate tires. This is a safe place for these discussions. And now I know a lot more about nitrogen |
02-23-2022, 01:44 PM | #16 |
Rep 7,001
YT: G Dubyou |
2011ninja3412.50 |
02-23-2022, 01:44 PM | #17 |
Rep 73
Think I'll opt for the Helium option to make the car a little lighter
02-23-2022, 01:51 PM | #18 |
DROP TABLE EVs;
544
Rep 297
Gotta reduce that unsprung mass as much as possible!
@g80mt on Instagram - 2023 BMW M3 6MT in Individual San Marino Blue / Tartufo
Past BMWs: 2013 BMW 128i 6MT M-Sport Slicktop, 2016 BMW 340i 6MT M-Sport Join BMWCCA today and become eligible for members only events, discounts, and the new car rebate of up to $1000! Feel free to use me as a referral (with member #553730) which enters me for a performance school day (I should probably be better at driving, anyway). |
02-23-2022, 02:13 PM | #19 |
Rep 421
02-23-2022, 02:44 PM | #20 | |
Rep 294
Drives: 2013 Focus ST, 2022 M3Cx
Seems like you should pay for nitrogen just for the safety aspect... |
02-23-2022, 04:36 PM | #21 | |
6920
Rep 3,277
02-23-2022, 04:44 PM | #22 | ||
Rep 7,001
YT: G Dubyou |
