01-21-2024, 09:58 AM | #23 |
2022 M4 Comp Xdrive
1016
Rep 1,537
Schulminator476.00 |
01-22-2024, 10:32 AM | #24 |
Rep 190,815
Im not familiar with customer support issues with Spool. We have been offering their parts for some time, and aside from the longer wait times, I have not had any problems.
01-23-2024, 04:37 PM | #26 |
Rep 501
E60 your stock fuel system taps out. Your stock LPFP can handle the E85 up to 100%, your HPFP's cannot and neither can your injectors. With that said, you have guys saying go PI! But as mentioned here by some members, now youre introducing another computer not running through your DME. Best route if you want full E85 is Injector and HPFP's. I have spoken to Tuner and top shop here in SFL for the info.
01-23-2024, 04:48 PM | #27 | |
Rep 92
01-23-2024, 04:56 PM | #28 | |
Rep 501
Longevity for these is around the 700-730 WHP/WTQ mark, anything above that youre in the upper limits and danger zones. Now, if youve got a built engine, then youre good. But I dont see your stock turbos being effcient past 33-34 pounds, so you will need Pures/Vargas... Oh, dont forget transmission, youll be slipping around that 750 ish WTQ mark, not immediately but youre definitely over that 30% buffer they have. |
kurdishcuts72.00 bilal5.00 |
02-06-2024, 11:45 PM | #29 | |
Rep 2
02-07-2024, 01:21 AM | #30 |
Rep 277
Is this actually true? The odd post mentions this but never any actual shop or tear down to be heard of...
Even the 2 redbull cars with 100% stock internals with 1000hp and 900ft lbs beat on for over 2 years ... no bent rods. Shrug. |
02-07-2024, 06:53 AM | #31 |
In the Details
1810
Rep 867
Drives: Yes
Garage List 2020 AMG GTR [0.00]
2022 R8 Quattro Spyder [0.00] 2023 X5M50 [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Civic Type R [0.00] |
Is that at the wheels? Because 900 ftlbs at crank is more like 750 at the wheels.
02-07-2024, 07:01 AM | #32 |
Rep 989
Drives: 2024 M4 Comp X-Drive
I’ve heard the base manual G80/G82 has less headroom fueling wise than the comp…I’m not sure how accurate that is but given the G87 is rated for lower power than the base manual G80 I’d find a way to verify the fuel systems are identical or creep up on the power when you’re tuning. (and put in safeties to see where you start to see the limit fueling wise)
02-07-2024, 07:56 AM | #33 | |
Rep 277
A bit higher than your threshold.. but around there. Regardless. Where are the bent rods posts? Ref https://www.bmw-m.com/en/topics/maga...tbrothers.html Last edited by Mapper; 02-07-2024 at 02:06 PM.. |
02-07-2024, 11:37 AM | #34 | |
Rep 858
02-07-2024, 11:46 AM | #35 | |
Rep 858
What’s puzzling is the documented 9.1 vs 9.3 compression ratio on that engine… where the heck did they get the drop from?… I don’t think they ran a different gasket. |
Mapper184.00 |
02-07-2024, 11:49 AM | #36 | |
Rep 5,155
Mapper184.00 |
02-07-2024, 04:31 PM | #37 |
Rep 858
They only touched intake and exhaust ports. That’s outside the valves.. That doesn’t change the combustion chamber and shouldn’t touch the compression ratio. I took that into consideration.
02-07-2024, 05:12 PM | #38 |
Rep 1,929
Looks like headwork to me.
02-08-2024, 01:43 PM | #40 |
Rep 858
That is definitely head work. It’s been a few weeks since I’ve see the video they did on this. My bad… I would have worded the damn article to include the verbiage, but that’s just me. Maybe it should have been assumed like Mapper said that with intake and exhaust porting additional head work is needed, but I’ve seen that done in the past and the head dome was never touched… maybe due to types of engines, not sure. Good info to know, so thanks Mapper.
Mapper184.00 |
