05-09-2023, 12:24 PM | #1 |
Rep 124
Winter storage
With about 6 months before snow fall in Canada, I'm trying to figure out a solution to store my car safely in my garage. Don't wanna drive on salted roads and cause premature rusting if I can avoid it.
What do you guys recommend? I'm primarily worried about the battery and brake disks rusting. PS: I have full body PPF with ceramic. Last edited by Gottagofast; 05-09-2023 at 01:16 PM.. |
05-09-2023, 12:39 PM | #2 |
Rep 900
I put a battery tender on mine for the winter. Don't worry about the brakes rusting. As long as you don't wash and or drive it in wet weather then just park it for the winter you'll be fine.
On a side note man. It's just starting to get really nice here in Michigan and your already talking about winter? Let me at least enjoy some nice weather first lol. Oh and you'll probably get some heat from the guys that say this isn't a Ferrari and just drive it all year round lol. I got flamed a couple of years ago for talking about storing my car for the winter months from a few guys on the forum. I say enjoy your car how you want to! Last edited by LuckyBrand; 05-09-2023 at 01:12 PM.. |
05-09-2023, 12:41 PM | #3 | |
Rep 647
So are you saying you plan to park the car for the winter or drive it? Sounds like you’re talking about storage. Look here: https://g80.bimmerpost.com/forums/sh....php?t=1969297 |
05-09-2023, 12:50 PM | #4 |
Rep 1,773
It's an x-drive. Drive it. I don't daily drive my car or park it outside in the snow but I do drive my car in the winter. Then again we get very mild winters now so snow driving is minimal. I do switch to winter tires once the temps drop below 40 F. My car is lowered so I would not drive it in heavy snow and we have an SUV for that anyway.
05-09-2023, 01:06 PM | #5 |
Rep 255
Despite having an M3CX, I stored mine in my garage over the Toronto winter and used a beater to get around. Much less stressful.
Here’s what I do: 1. Park it on thick rubber mats or foam.add a few more psi in each tire. Doing this will help prevent flat spots. 2. Make sure it’s showroom condition inside and out. 3. Put a battery tender on it. Make sure it’s one that is Lithium Ion compatible. 4. Install a custom fit and super soft car cover to protect it from dust. 5. Even though my garage is completely enclosed, I add some moth balls around the car to deter rodents…just in case 6. Leave it be. Don’t start it. 7. Enjoy a few beers while preying for a quick return to spring. |
Gottagofast394.00 LuckyBrand1360.50 |
05-09-2023, 02:54 PM | #7 | |
Rep 1,275
2022 M4 Competition ConvertibleDravit / Tartufo Full / Carbon Fiber Exterior...loaded
2020 X5:MW/Coffee Extended Merino, M Sport, B&W....loaded 2007 X3: Sapphire Black / Black loaded 6 speed Gone: M3 E93 Silverstone II over Bamboo |
05-09-2023, 02:55 PM | #8 |
Rep 392
I only put my car in the garage if there is a snow storm but as soon as the roads are clear, it's back out
GrannyShiftG801300.50 vmoney89109.50 |
05-09-2023, 03:22 PM | #9 | |
Rep 255
I forgot to mention that I fill the tank completely before I store it. That’s important. Prevents rust in the tank as well. |
05-09-2023, 03:23 PM | #10 |
Rep 255
05-09-2023, 03:41 PM | #11 |
Rep 8,060
Drives: 2024 X5 M60i
Most people are out there celebrating the start of the upcoming summer driving season and here is OP worrying about winter storage already.
05-09-2023, 03:43 PM | #12 |
Rep 941
chicagofan0019203.00 LuckyBrand1360.50 |
05-09-2023, 03:45 PM | #13 |
Rep 8,060
05-09-2023, 05:46 PM | #14 |
Rep 1,444
Drives: 2018 M3CS
Where in Canada?
I’ll be storing mine over the winter months. The plan is: dealership change the oil, fill the gas to the absolute top, thoroughly clean inside/out, bounce sheets inside and in engine bay, towels in the exhaust pipes, hook up battery tender, over-inflate tires to 50-60 psi. |
05-09-2023, 07:45 PM | #16 |
Rep 760
05-09-2023, 07:49 PM | #17 | |
Rep 760
edofloat453.00 |
05-09-2023, 08:47 PM | #18 |
Rep 255
05-09-2023, 09:30 PM | #19 |
Rep 760
The point is that the things you do are subjective (e.g. debatable if needed; difficult to verify if they add any value to the storage process) and adding Stabil is certainly in that category but is such low cost, why not just do it. Anyway, the right answer is to drive the car as much as possible.
05-09-2023, 09:47 PM | #20 | |
Rep 255
LuckyBrand1360.50 |
05-09-2023, 10:07 PM | #21 |
6920
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
For what it's worth i have stored my E46 M3 for 12 winters in a row for an average of 6 months. I haven't bothered to use fuel stabilizer or increase the psi in the tires for several years now when I used to do it religiously (please don't fill your tires to 60 PSI, that's a really bad idea). No flat spots and the fuel is always fine. It's not necessary. Neither is a car cover which almost always does more damage than going without.
Few musts: something in the tailpipes (i use steel wool) battery tender clean car dont start it during storage park brake off and in neutral (if manual) and use a block behind the tire FULL gas tank oil change either before storage or as soon as you can after |
LuckyBrand1360.50 vmoney89109.50 |
Tags |
m4 comp, storage, winter |
