03-06-2024, 11:00 AM | #1 |
Rep 2,080
New Tires Size 295/305
Anyone have tried these tires size on xdrive/OEM wheels? Pictures?
Front 295/35/19 Rears 305/30/20 Same OEM .04% diameter bettween them. So not issues there. I want more meaty look and wider a$$
03-06-2024, 02:00 PM | #2 |
Rep 1,943
The extra width and height might give you some rubbing issues in the front.
03-06-2024, 02:15 PM | #3 |
Rep 5,832
Difference is 0.4%, not 0.04%
What specific tires do you plan on running because in that size range a lot the tires are for rear applications. Front tires are designed with wider valleys/groves to provide better steering control in wet conditions. Running rear spec tires on the front can increase the chance of aquaplaning but no real impact in dry conditions. |
03-06-2024, 02:26 PM | #4 | |
Riding the knock sensor
2419
Rep 1,608
Drives: 21 X5MC | 23 M4CSL
03-06-2024, 02:34 PM | #5 |
2419
Rep 1,608
Lower or stock height? Either way, the fronts are problematic even with the common liner mod - you’ll need to do more at the front and at the rear section of the liner. 305/30/20 rears work if lowered but it will rub a hole in the felt liners at the inner rear when fully compressed - this happened to me on track. Not a big deal but something to be aware of as you’ll collect a ton of debris in those caverns behind the felt.
03-06-2024, 02:45 PM | #6 | |
Rep 5,832
Hit_Apex2418.50 |
03-07-2024, 08:51 AM | #7 | ||
Rep 2,080
03-07-2024, 09:38 AM | #9 |
Rep 2,080
I mean, we can play with spacers no problem. I can try no spacers or whatever other size to clear the inner.
03-07-2024, 10:24 AM | #10 |
Rep 1,943
Well keep us posted, you can also try a 285/35/19 and 295/30/20 as well.
03-07-2024, 10:26 AM | #11 |
Rep 2,080
indeed, thats the safer one option.
03-07-2024, 02:42 PM | #12 | |
Rep 395
New to me, but it might be something new... looking forward to 285/35/19 and 295/30/20 supercar3 |
03-08-2024, 02:47 PM | #13 | |
Rep 819
https://www.bimmerpost.com/forums/sh....php?t=1924513
Current - G82 X-Drive in Verde Ermes
SOLD - F82 Sakhir Orange SOLD - G01 X3 White SOLD - E93 Burgundy |
03-08-2024, 08:18 PM | #14 | |
Rep 2,080
03-08-2024, 09:17 PM | #15 |
Rep 7,011
Im sure its possible. The front rubbing will probably need some liner adjustment. Im not sure what the hard on is with getting rid of the stock PS4s to go a "little" wider.
You're going from a BMW Star tire, to a non star. The PS4s Star, has 4 tire compounds, versus the standard off the shelf PS4s only having 2. The OEM BMW Michelins, are half PS4s and half Sport Cup 2. The standard off the shelf PS4S is shown with the tan carcass, while the BMW Star is shown with the Blue carcass. The tire is a completely different inner construction with the belts reaching into each groove, allowing for a tighter cornering tire feel. The OEM BMW Star tires only come in OEM sizes.
YT: G Dubyou |
mathys213.00 |
03-09-2024, 08:13 AM | #16 | |
Rep 2,080
I second those ps4 only for bmw are way better that other ps4s.
Limegrntaln13605.50 |
