01-08-2024, 10:14 AM | #1 |
Rep 1,064
Breaking in the CCBs
The Owner's Manual only says:
For M carbon ceramic brake: Drive cautiously for the first approx. 600 miles/1000 km. That's it? None of this "brake at 0.3g from 60 to 30 for ten times" nonsense? |
01-08-2024, 10:47 AM | #2 |
Rep 2,606
Bedding brakes is not supposed to be ridiculous hard pulls and hard stops. It should be done gradually and evenly. Driving normally takes care of this in the first few drives. It's not a super important thing to do, consciously, if everything is installed correctly.
harperium1313.00 |
01-09-2024, 06:33 PM | #3 |
Rep 483
Drives: 2020 BMW X3M
Coming from the guy that complained the X3M had no power in 8th gear when getting on the highway. 🙄
01-09-2024, 07:13 PM | #4 | |
Rep 3,407
01-10-2024, 05:42 AM | #5 |
Rep 5,550
although pad transfer on CCBs isn’t exactly the same as pad transfer on iron brake rotors. CCBs have a friction layer (cracked surface) applied to the rotors and it’s the wearing off of this layer that results in the rotors needing to be replaced (as well as burning off of internal fibers which reduces the weight of the rotors. Rotors are marked with their min weight when replacement is required).
01-10-2024, 09:03 AM | #6 |
Rep 2,606
01-10-2024, 09:18 AM | #7 | |
Learning to drive again
714
Rep 321
Drives: M3CS
https://www.pagidracing.com/files/Pu...ing-In_web.pdf https://alconkits.com/blogs/tech-tip...eet-brake-pads https://www.brembostoreusa.com/blog/...-need-to-know/
Cheers,
BoB |
01-10-2024, 09:26 AM | #8 | |
Rep 2,606
As I mentioned, they should be gradual and should be worked up from easy braking to moderate braking, as your links also mention. None of that full slam on the brakes multiple times nonsense. And my overall point being, the actual requirement for bedding brakes in will happen with those that drive normally/moderately enough that unless you're going to be tracking the car every day, you won't notice any difference. |
01-10-2024, 01:05 PM | #9 | ||
Rep 3,407
For insight, I'll break the post down piece by piece. Before all else, to answer the question "Is it necessary to properly bed in brakes?" Well, if you don't care to have maximum performance from your brakes and never intend to track the car, then it really doesn't matter. You don't need to bed your brakes for them to work, and regardless of that...a few thousand miles of street driving undos what you achieved from a proper bedding process anyway. However, since OP asked, and on the topic of bedding specifically... Quote:
This involves hard braking from moderate speed to a crawl, and accelerating relatively quickly back up to moderate speed (enough to cool the brakes a little but not too much)...repeatedly. The guides above from Pagid and Brembo outline the specifics well. Street driving actually undos or reverses the desired outcome of bedding in the first place, which is to embed an even layer of pad material onto the rotor surface. Regular, mild use of the brakes at cold temps effectively polish the surface off. Sure, it's not super important. But it does require a specific process. Otherwise, the brakes are not bed at all. |
01-10-2024, 04:41 PM | #10 | |||||
Rep 2,606
I'll break down your post piece by piece as well. Quote:
If you're not going to post anything useful the first time, then don't post. |
