10-29-2021, 08:04 AM | #67 | ||
Rep 1,383
Is it crazy loud with the downpipes or ok ? Big pops and bangs? Tempted by Soom's videos but not sure if I will regret it |
10-29-2021, 08:54 AM | #68 | |
Rep 70
Pops and bangs are amplified more but in a tasteful way, it doesn't sound like an AK going off like a 370, but you hear it more. If you don't want any pops and bangs at all just run in comfort mode, it seems to be tied to sport plus engine option only l. It's very livable in comfort mode with valve closed and I would argue it's not much louder/noticable. I do however have the VSC-2 valve controller, so I'm able to open the valves up all the way so my setup is louder then it would be for someone running without. |
barryc3651956.00 |
11-02-2021, 01:47 PM | #69 |
Rep 426
I just ordered mine. This would make a great christmas present for myself
Is there a video that i can check out to prepare for the install of this midpipe? I am a noob. But willing to learn. I just need some ramps to get under the car. Hate my driveway as its on an incline but will figure something out. Unfortunately, the remus exhaust has been pushed to mid december or january, at least for me in the UK. Will check this midpipe out and if it does what its supposed to, I will add the remus rear section later in the new year. |
11-03-2021, 09:01 AM | #70 | |
Rep 190,807
madmedman275.00 |
11-03-2021, 10:36 AM | #71 |
Rep 88
I'd order one but I am really not digging the fitment issues. There is no way I'm putting washers under a structural brace on a car I plan to track. Until someone either redesigns the brace or they change the mid-pipe design I guess I'm stuck.
11-03-2021, 10:48 AM | #72 | |
Rep 1,383
I think some people cut the rear in the wrong place. |
11-03-2021, 01:23 PM | #75 | |
Rep 426
Apologies for multiple posts. Cant figure out how to merge. |
11-06-2021, 09:40 AM | #76 |
Rep 33
hi gentlemen, my first combo was ssr downpipe/valvetronic midpipe, it took me 12 hours to install, I had to make a spacer between one of the two downpipe not long enough, and I put a lot of pressure to be able to align and tighten the downpipe with the midpipe, and I even had the midpipe that rubbed on the rear brace, I had to put washer, very frustrating! I was really not comfortable with this setup!
so I changed to downpipe with flexible (project gamma), 3 hours later the work was finished, no need to make a spacer or force the pipes to tighten or washer at the back, perfect fit,same sound , same performance now I am happy! maybe it can help someone who wants to make the move still have a ssr downpipe with 200miles on it to sell, for those who want to still with dual mid pipe! |
11-06-2021, 11:00 AM | #77 | |
Rep 70
People keep saying "You didn't cut at the right place and that's why it doesn't fit" But I literally messaged Valavtronic on their website and they sent a picture with the cut area circled in in red. I cut at EXACTLY the same spot. The SSR downpipes are annoying because they are fixed position, if you don't have them rotated just perfectly( assuming that's even possible now) Fitment is way off. The stock downpipes are already in place obviously and the longer one has a flex pipe which makes getting fitment 10 times easier. When I rotated my SSR downpipes I was able to get a better fitment, (before rotation I could even get the brace on without washers, after I rotated them I could get it on without washers, but still needed to add them to avoid rattling. |
11-06-2021, 11:50 AM | #78 | |
Rep 426
I have the stock downpipes and the Valvetronic midpipe is incoming next week. Can you post the pic or please mention where to cut the stock exhaust. It may be a DIY job and I don't want to mess up. Thanks. |
11-06-2021, 05:14 PM | #79 | |
Rep 4,923
Y@nnick51.50 |
11-07-2021, 06:17 PM | #82 |
Rep 744
11-09-2021, 03:31 PM | #83 |
Rep 596
I tried to get my mid pipe installed today but the shop was saying it was f'ed up, basically the connections to the downpipes were screwed up, so you couldn't actually attach them without either having a massive exhaust leak at that point, or having the angle be completely off.
Anyone else run into this? Working with valvetronic to see if they agree/can send me a new front section. This shows does a ton of mid pipe and down pipe installs so I doubt they got it wrong/screwed something up. They were thinking it was likely just welded in the wrong place. Sucks because I've been waiting months to get it. |
11-11-2021, 12:10 AM | #84 |
Rep 94
I just got mine installed with stock downpipes and i too was told that it was really tough to get on….the guys eventually got it into place but the only concern was the clearance between the midpipe and that x-brace….there was literally a little less than half an inch….i guess if i hear it hit against it on a bump i can add small spacers but so far so good ✊🏼 🪵….as far as sound, id say normal driving in sport + is about 30% louder and you get some burbles when you let off the throttle….wot you definitely have more exhaust sound but its still neck and neck with engine sound….the exhaust isnt overbearing at all….in normal mode i cant even tell the differemce honestly….but this is exactly what i wanted bc i plan on finishing it off with the remus sport axelback….it just comes down to preference.
12-21-2021, 01:24 PM | #85 |
Rep 67
I just got my VT designs midpipe installed today on my G80 M3 - 6MT and it is a must do upgrade if you want to wake up your M3. It sounds like a proper M3 now and I am very happy with the outcome as well as the quality of the pipe and fitment (it went in perfectly). My shop also commented on how well made the midpipe is. Absolutely love it as this is just the right amount of sound increase that I wanted, but still neighbor friendly. It is NOT obnoxious but still hooligan when you want it to be.
12-21-2021, 03:29 PM | #87 |
Rep 67
