02-12-2024, 09:08 PM | #1 |
Rep 196
827M need help .
I ordered 827M Forged Replicas. 20x11 on the rear snd 20x9.5 in thr front . Any suggestion on tire size would be really appreciated.
02-13-2024, 12:03 AM | #3 |
Rep 262
Drives: '24 M3 Comp X-Drive
X drive, you have to do 20x11 & 20x10 right?
Haters gonna' hate, ainters gonna' aint.
02-13-2024, 05:32 AM | #5 |
Rep 385
You can do 9.5 front and 11 out back. What’s going to matter is the diameter size of the tire or height of the tire front to back not exceed more than 1.1% from front to back.
02-13-2024, 05:36 AM | #6 |
Rep 196
I just sent the seller a message and he told me he could without any issues change the front from 9.5 to 10s so thank yall for the info and help.
02-13-2024, 07:59 AM | #8 |
Rep 5,183
From Apex Wheel fitment guide G8X:
Front: 285/30-20 // Rear: 295/30-20 X-Drive Compatible Some front rubbing can occur with tires that run wide against the inner fender liner at full steering lock. All Season: Continental Extremecontact DWS 06 + (560TW), Michelin Pilot Sport AS4 (540TW) Ultra-High Performance Summer: Firestone Firehawk Indy 500 (340TW), Falken Azenis FK510 (300TW) Max Performance Summer: Michelin Pilot Sport 4S (300TW), Continental Extremecontact Sport (340TW), Bridgestone Potenza Sport (300TW), Yokohama Advan Apex V601 (280TW), Pirelli P Zero (220TW) Extreme Performance Summer: Michelin Pilot Sport Cup 2 (180TW)
Llarry16522.00 |
02-13-2024, 08:34 AM | #9 | |
Rep 196
Wheel Offset: +18mm Front +18mm Rear Bolt Pattern: 5x112 Wheel Bore: 66.6 |
02-13-2024, 07:52 PM | #10 |
Rep 5,183
Front: 20x10" ET8 // Rear: 20x11” ET18
02-14-2024, 06:20 AM | #13 |
Rep 196
02-14-2024, 10:22 AM | #14 |
Rep 385
02-14-2024, 10:24 AM | #15 | |
Rep 385
20x10 ET12 and 20x11 ET14 is very safe and set the tire look right without issues. |
02-14-2024, 10:47 AM | #16 | |
Rep 196
I was trying to basically get almost stock fitment. I ordered the csl rims in black . The ET on the stock ones are ET20. The ones iam ordering are ET18 . |
02-14-2024, 06:26 PM | #17 |
Rep 5,183
This link is basically the fitment bible:
https://apexwheels.com/fitment-guide...-fitment-guide Apex gives you all the tried and tested combos. You want to look under the Performance Street category where they list your 20x10 f and 20x11 r fitment requiring spacing of ET8 f and ET18 r to fit 285/30-20 f and 295/30-20 r. Bridgestones or Michelins are the sure shot.
02-14-2024, 06:41 PM | #18 | |
Rep 196
TopJimmy5498.50 |
02-19-2024, 05:54 PM | #19 | |
Rep 1,942
I wonder how this combination would work on stock wheels, they test it on Front: 19x10" ET12 // Rear: 20x11” ET18 wheels. They mention some rubbing up front on the et12 wheel but stock is et20 so maybe no more rubbing.
02-19-2024, 06:15 PM | #20 | |
Rep 739
19x10 ET12 - 285/35/19 20x11 ET18 - 295/30/20 This works on my M4 without spacers, but as mentioned, does rub the fender liner on full lock. This tool https://tiregrades.com/tire-anatomy/...for-rim-width/ says that the 285 exceeds the max for a 9.5" wheel. This tool https://tiresize.com/wheel-offset-calculator/ can help with visualizing the different wheel/tire sizes. Using that tool comparing the 275/35/19 ET20 to 285/35/19 ET12, the outer sidewall is actually closer in than stock, which you would think would keep it from rubbing on the fender liner.
Susp: Turner Skid Plate/Strut Brace, KW v4, F-L Monoball, MS: Camber Plates, Spacers, SPL Rear Cosmetic: MPerf: Splitter, Side Vents, Sill Plates, Door Projectors; IND CF Roundels/Float Center Caps, Vorsteiner Grill, Xpel: Stealth PPF, Fusion Plus Ceramic, XR Plus 5/20/70 Last edited by m4ml; 02-19-2024 at 06:23 PM.. |
forcefed2577.00 |
02-19-2024, 09:05 PM | #22 | |
Rep 1,942
