04-19-2022, 10:17 PM | #89 |
Rep 1,410
r33_RGSport12973.50 |
04-19-2022, 10:21 PM | #90 | |
Rep 18,718
Once all confirmed, I will start ordering.
m20e30871150.00 |
04-20-2022, 02:37 PM | #91 |
Rep 123
I need some help guys. I'm on my 2nd set. First DFC 5000 set didn't fit. Now the DFC3000 seem to big where they touch the hub. The tech came pull me to show me.
04-20-2022, 05:41 PM | #93 | |
Rep 18,823
jmg18710.50 |
04-20-2022, 05:57 PM | #94 | |
Rep 14,115
Drives: G82 M4C X-Drive
Until you properly bed these in, they smell like burning clutch, but don't worry, that's just part of the process. I'll be going for my first track day in them next week so I'll know how they perform once properly track bedded. I'll follow up if noise level changes after track days.
04-20-2022, 09:12 PM | #95 |
Rep 2,373
I'm not sure what you are doing. No problem whatsoever with installation. Did you reach out to supplier? OEM pads had a huge weight on it, can't recall the reason for it.
Formerly Wyndi335I
04-20-2022, 09:44 PM | #96 |
Rep 488
I like the patina of brake dust.
04-20-2022, 10:44 PM | #97 | |
Rep 123
04-20-2022, 11:05 PM | #98 | |
Rep 2,373
Formerly Wyndi335I
04-20-2022, 11:06 PM | #99 | ||
Rep 123
04-21-2022, 08:26 AM | #101 |
Rep 123
Can you take a picture of the front pads and how they fit? The DFC 3000 you have?
04-21-2022, 08:45 AM | #102 |
Rep 2,373
Here you go...
Formerly Wyndi335I
04-21-2022, 08:46 AM | #103 |
Rep 123
04-21-2022, 05:28 PM | #105 |
Rep 77
04-21-2022, 07:58 PM | #107 |
Rep 2,373
Can't wait to see what your take is on these pads. When I ordered mine, the rear pads were not available.
Formerly Wyndi335I
FISH225404.50 |
04-21-2022, 09:37 PM | #108 | |
Rep 338
Worked fine regardless. |
04-22-2022, 03:40 PM | #109 |
Rep 77
04-22-2022, 05:34 PM | #110 |
Rep 338
Its not actually hitting to rotor. As per photo above, it is about 2mm from the rotor, same with mine and I dont see any mark on the rotor to indicate the pad touching at all.
If you are a bit annoyed with that tiny clearance you can try: 1. Remove the caliper and put a spacer to the 2 bolts to have extra clearance 2. Mark off the new pads with the OEM pad and grind off the difference. I think the middle section of the pad is the main focus. Take a few minutes each if you have a good grinder. |
spridge647.50 |
Tags |
2021 m3, brake dust |
