BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
BPM
      10-21-2018, 10:57 PM   #1
madrit21
Drives: 2018 BMW M3
HELPPPP! DCT Rough 1st gear and reverse engaging
So ill be at a red light in automatic mode and slightly accelerate in 1st gear but feels like the car is having trouble accelerating. Kind of like a violent jump into 1st gear. Also does it in reverse. I updated the software and even did a transmission fluid flush hoping this would solve the problem. 900 bucks gone and still left with the same problem. Every other gear shifts perfect. Car only has 30k on it i love my e92 and dont wanna sell it over this problem help!
      10-21-2018, 11:27 PM   #2
sibhusz06
Drives: 2011 M3, 2012 X35I, 2007 911
Have you had your clutch and transmission adaptions reset? I had an occasional buck even with the GTS software that has gone with the adaptations reset..
      10-21-2018, 11:33 PM   #3
madrit21
Drives: 2018 BMW M3
Yes i did but still no luck
I get the buck after every complete stop and when i start backing out in reverse. Kind of like a violent push into gear
      10-22-2018, 12:00 AM   #4
sibhusz06
I can't think of anything else other than try going back to the factory DCT software that was last released. Could be the gts software. And then try resetting the adaptations for the clutch first then the transmission.
      10-22-2018, 12:03 AM   #5
madrit21
Drives: 2018 BMW M3
Tried that as well today. What a nightmare 😫
      10-22-2018, 11:08 AM   #6
madrit21
Drives: 2018 BMW M3
Bump
      10-22-2018, 02:48 PM   #7
madrit21
Drives: 2018 BMW M3
Could this be a transmission mount issue??
      10-22-2018, 07:36 PM   #8
madrit21
Drives: 2018 BMW M3
Help😫
      10-22-2018, 10:08 PM   #9
sibhusz06
transmission mount is worth checking as well as engine mounts. Look at the engine as you rev it to see if it wants to torque to one direction.
Also just check your driveshaft to transmission coupling to make sure theres no excessive movement.
      10-23-2018, 12:56 AM   #10
codinge90
329
Drives: e92 M3
Did this just randomly start to happen or been happening since you've owned the car? This is a common issue with DCT, its going to feel jerky and violent from 1st to second gear as well as reverse engagement. Many threads on this topic
      10-23-2018, 12:59 AM   #11
madrit21
Drives: 2018 BMW M3
This actually just started happening last week. No SES light so hoping its not a major trans issue. gonna try to check the mounts asap
      10-23-2018, 07:43 PM   #12
madrit21
Drives: 2018 BMW M3
I should also add that this only happens when the car has been warmed up driven for about 10 minutes.
Also, i have gotten an increased emmisions light twice in the past that comes and goes due to gas cap
      10-24-2018, 10:33 AM   #13
RosieTheRedM3
RosieTheRedM3's Avatar
Drives: 2013 BMW M3 Frozen Red Edition
2013 BMW M3  [0.00]
This could be extreme for the mileage but you might have a driveshaft problem
      10-24-2018, 10:36 AM   #14
Patrón
PAZUZU
Patrón's Avatar
Drives: '15 M4
2015 BMW M4  [0.00]
2009 BMW M3  [10.00]
your solenoids are blocked or your mechtronics board is fried. hopefully it's low on fluid but for it to behave like that it , it's not good. I had signs of that and the 'basics' of reset adaptations, new software, new clutches didn't fix my problem. good luck.
2009 M3 DCT ESS625+ SOLD
2015 M4 BSM/Silverstone F4LCON
@texasMclub IG @jagemoets
      10-24-2018, 10:59 AM   #15
madrit21
Drives: 2018 BMW M3
Would that throw any codes? Sad to have this problem at 30k
      10-24-2018, 05:04 PM   #16
madrit21
Drives: 2018 BMW M3
Video
Got a little video on it. Not too clear but engine seems to move quite hard when i start accelerating
      10-24-2018, 09:52 PM   #17
0_to_60
0_to_60's Avatar
81
Drives: E92 M3
your doing it too fast.. put thr car in 1 or D, hold the break and give some gas and/or put it in Reverse and try it same way.. There should be a noticeable engine hop.. In this video, it seems like ur engine mount is bad but its not clear
      10-24-2018, 10:42 PM   #18
Patrón
PAZUZU
Patrón's Avatar
Drives: '15 M4
2015 BMW M4  [0.00]
2009 BMW M3  [10.00]
Yes, definitely
      10-24-2018, 10:46 PM   #19
madrit21
Drives: 2018 BMW M3
Yes, definitely
Thank god i dont have any codes on the dash. Taking it to the dealer tomorrow to check the mounts. Thanks for your feedback. Much appreciated
Patrón544.50
      10-25-2018, 09:05 PM   #20
madrit21
Drives: 2018 BMW M3
Update
I had the dealer check out my mounts today. Everything was in good shape. Got an "increased emmisions" ses light on today. Left it at the dealer overnight.
      10-27-2018, 08:27 PM   #21
madrit21
Drives: 2018 BMW M3
Video update
      10-30-2018, 11:55 PM   #22
madrit21
Drives: 2018 BMW M3
Tags
dct e92m3
m3post
