01-13-2023, 02:55 PM | #419 |
Rep 6,991
Nice stance. What do you think about the brake lines? I've had them sitting on my workbench for like 6 months. I forgot all about them, until I saw them installed on your car.
YT: G Dubyou |
01-13-2023, 03:46 PM | #420 |
Track Rat
1760
Rep 403
I have used SS brake lines ever since I saw an M3 go hard into a wall due to total brake failure about 3 years ago. Upon further inspection it turned out that he had picked up a sharp piece of metal with his right front tire which then mangled the brake line and embedded itself in the inner fender lining. Bleed out was very rapid and thorough. Shit does happen, and SS brake lines are inexpensive. The rears got swapped out as well, but after the pics were taken.
Limegrntaln13525.50 PLF693768.50 |
01-13-2023, 07:45 PM | #421 |
Rep 274
Drives: 2023 M3 Comp
North Raleigh performance made a DIY video of this install on when they did my car. Figured it would be cool to share to this thread. Not sure if I am allowed to post here or not, but here it is….
https://youtu.be/PZ94E-Gp0JY |
Limegrntaln13525.50 L33t86.00 |
01-13-2023, 08:03 PM | #422 |
Rep 819
Oem has installed on g82
Picked up the M4 after having the OEM HAS kit installed at my BMW dealer. They set heights at the BMW recommended spec. You can see below in the image what BMW carried out and the parts.
Images of car before install: Images of car after install: Here are the parts and work performed: The 300km drive home was perfect. All highway driving and out riads in Australia are not good. The ride firmness is just right IMO. I was not after a firm ride. The height I am happy with and when my new wheels arrive (see below, due in 2-3 weeks, I think I will be super happy with the look. This is the first time I have fitted any suspension upgrade on one of my M cars and I am happy I took the plunge. Happy to answer any questions.
Current - G82 X-Drive in Verde Ermes
SOLD - F82 Sakhir Orange SOLD - G01 X3 White SOLD - E93 Burgundy |
01-13-2023, 08:54 PM | #423 | |
Rep 258
01-13-2023, 09:08 PM | #424 | |
Rep 6,991
Happened to me. I ruined mine, myself.
YT: G Dubyou |
T0RM3NT3684.00 |
01-14-2023, 08:21 AM | #425 |
Rep 215
Thanks for the posts. So what is actually the recommended spec? What is the height reduction they were aiming for, and is it achieved already or will it still settle to get there?
2022 M4Cx in Brooklyn Grey
Limegrntaln13525.50 |
01-14-2023, 10:17 AM | #426 |
Rep 5,134
It’s very detailed and on a page in this thread, but basically down full 20mm rear and down about 15-15.5mm front.
01-14-2023, 10:50 AM | #427 |
Rep 2,700
Anyone has the actual instructions from the kit? Curious what are the recommendations for best track performance.
01-14-2023, 10:54 AM | #428 |
Rep 6,991
I posted them in a PDF earlier in the thread. Check page 3 post 8, if I remember, correctly.
YT: G Dubyou |
PLF693768.50 |
01-14-2023, 11:55 AM | #429 |
Track Rat
1760
Rep 403
The recommended height from BMW is to achieve the maximum cornering performance on a track. That was their purpose in developing this kit in the first place. This height as measured from the bottom of the wheel rim to the top of the wheel well is Front: 628mm and Rear; 637 mm. for the M4 with 19in & 20in wheels.
The range of drop available from stock is 5mm - 20mm. The 5mm is achieved through the change to the shorter MP springs with no further adjustments being made. 15 additional mm's are available through adjustment. My car was delivered with heights of Front: 644mm and Rear: 657mm. I am assuming that this is the same across the board for all M4's with 19in & 20in wheels. M3's, and cars with different size wheels have different settings. A list of these is found in the installation instructions, and also in post #234 of this thread. A full drop from stock height should result in heights of Front: 624mm and Rear: 637mm on an M4 with 19in & 20in wheels. Again, this will differ for others.
01-14-2023, 09:13 PM | #430 | |
Rep 6,991
YT: G Dubyou |
01-15-2023, 09:36 AM | #431 |
Track Rat
1760
Rep 403
Correct. Measurements are provided in the instructions from both the bottom lip of the rim, and the center of the axle to the fender edge. Personally I feel that using the rim lip will be the more accurate method of the two as you have a solid starting point as opposed to eyeballing a starting point on a smooth surface. Just my OCD. Post #234 in this thread also duplicates all info provided in the kit installation instructions.
01-15-2023, 01:15 PM | #432 | |
Rep 6,991
YT: G Dubyou |
01-18-2023, 01:45 PM | #433 |
Rep 941
Would the warranty still be valid if it’s not dealer installed? Thinking about picking them up from AutoCouture and having them install them.
01-18-2023, 02:00 PM | #434 |
Rep 2,700
My guess is they would probably honor the warranty of the parts but not the labor cost.
01-18-2023, 02:03 PM | #435 | |
Rep 6,991
YT: G Dubyou |
01-18-2023, 02:30 PM | #436 |
Rep 707
good reading, thanks for posting.
01-18-2023, 04:16 PM | #437 |
Rep 8,059
Drives: 2024 X5 M60i
01-18-2023, 04:58 PM | #438 |
Mr. Irrelevant
3684
Rep 594
"If someone installs an aftermarket or
recycled part that’s defective or wasn’t properly installed, it could damage another part that is covered under the warranty. If that happens, the manufacturer or dealer can deny coverage for that part and charge you for repairs. But, before they can deny warranty coverage, the manufacturer or dealer must first prove the aftermarket or recycled part caused the needed repairs."
Past results aren't a guarantee of future performance.
Limegrntaln13525.50 chicagofan0019197.00 |
01-18-2023, 05:34 PM | #439 | |
Rep 6,991
You don’t have to use the dealer for repairs or maintenance to keep your warranty in effect. In fact, it’s illegal for a dealer to deny your warranty coverage simply because you had routine maintenance or repairs done by someone else. That said, the dealer or manufacturer can make you use select repair facilities if the work is done for free under the warranty.
YT: G Dubyou |
01-18-2023, 06:34 PM | #440 |
Rep 274
Also as long as the sticker that came with the kit is installed in the door jam sans bubbles, they cannot deny the warranty…
Tags |
g80 lowering springs, m performance accessories, m performance has, m performance suspension |
