05-26-2022, 11:25 AM | #23 | ||
Rep 2,067
Super high speed tapping. |
05-26-2022, 11:30 AM | #24 |
You got my money?
3162
Rep 4,648
Drives: Ice Cream Truck
Interesting... Yeah mine is like one or two clicks only per direction. And I have to be going very slow to hear it. I only noticed it pulling into my garage space which it like threading a needle. Lots of back and forth turning to get in and out of my spot.
05-26-2022, 11:34 AM | #25 | ||
Luxury at the redline :)
9105
Rep 7,563
The dealer wasn't any help; I was out of warranty and they were ready to start padding a bill by replacing the entire wheel, rotor and even the inner wheel hub for good measure. As if 👎🏻 I refused to get swindled so I turn down their costly suggestion. I discovered this friction ring solution on my own while doing some research on this issue. Interestedly enough, these friction rings came standard on the F generation M2 CS and M4 CS only but not on the standard M models, for the identical MY as the CS, with same exact rotor/hub.. 🤷🏻 A web search will show this is a common issue amongst various BMW models. |
TrentMeister2860.00 |
05-26-2022, 01:03 PM | #26 | |||
Rep 2,067
Edit: just looked at your work order! Thanks that sounds like you found the cure🙌🏼 I'm actually pumped to do this Good to hear from you again too Poochie |
Poochie9104.50 |
05-31-2022, 03:35 PM | #27 |
You got my money?
3162
Rep 4,648
Update:
I had my car looked at. They heard the noise and loosened and redid all of the suspension bolts. It still clicks. If I turn left, the left side clicks. If i turn right, the right side clicks. Each direction has a sweet spot that I can hit to make it click over and over again moving the wheel back and forth. Id be curious to find out if anyone who is NOT lowered hears this too? Maybe its a normal characteristic? I dont know since I slapped KW HAS kit on shortly after buying the car.
05-31-2022, 05:12 PM | #28 | |
Rep 8,035
Drives: 2024 X5 M60i
05-31-2022, 05:46 PM | #29 | |
You got my money?
3162
Rep 4,648
You can see and hear it here pretty good. https://www.youtube.com/shorts/_hiAbt20_FM
05-31-2022, 06:35 PM | #30 | ||
Rep 8,035
Do you know if it also happens while in motion and at various speeds (probably hard to tell at that point with the road noise)?
05-31-2022, 06:50 PM | #31 | |
You got my money?
3162
Rep 4,648
I mostly hear it pulling into my garage or a parking spot. But I can also hear it when slowly rolling and turning too. Like slowing down enough at a 4 way to make a left or right turn on a green. I tried holding my brakes when turning to see if it was the pads or the rotor and it still made that noise. I dunno but I am going to ask KW for help and then to the dealer since my shop doesnt know what it is.
chicagofan0019161.00 |
06-06-2022, 10:00 AM | #32 | ||
Rep 2,067
06-06-2022, 11:43 AM | #33 |
Rep 142
Glad I found this thread. This has been an issue I have since I lowered the car. turn left and "click" turn right and "click". Always at low speeds. I track some so I had some SPL front lower control arms installed about a month ago and the "click" is now louder and almost a "pop". I am having the car looked at by SPL themselves to see if we can figure out what is causing the sound. I will let everyone know if we find something.
06-07-2022, 08:04 PM | #34 | |
You got my money?
3162
Rep 4,648
Are you talking about the shim spacer? If so, yes. But its not something I am willing to spend money on to try. My car didnt do this before I lowered it. So i suspect its something to do with that.
06-07-2022, 08:21 PM | #35 | ||
Rep 2,067
The shim is basically my last line of defense |
06-11-2022, 01:22 PM | #36 | |
You got my money?
3162
Rep 4,648
I havent gone to another shop yet for a 2nd look. But I noticed KW sells endlinks for the G8x. But no sway bar. It made me wonder if lowering somehow affects the OEM endlinks.
06-11-2022, 01:29 PM | #37 | ||
Rep 142
BIGW0RM3162.00 |
06-11-2022, 01:35 PM | #38 | |
You got my money?
3162
Rep 4,648
06-19-2022, 06:45 PM | #39 |
Rep 2,030
Drives: G80 M3 Competition
Add another one to the list. Thought I picked up on the noise about a week ago. Just got back from a long quite spirited drive.. pull in my driveway and doing a 3 point turn to reposition the car; the tick/click going either forward or reverse. Seems more rotational.
My G80C is at 13k miles, KW HAS, verified good alignment. KWs have been on since January, approx 4K miles. I've been chasing a front end knock for nearly 10k miles now. Now adding this to the list. Fun. |
06-19-2022, 06:47 PM | #40 | |||
Rep 2,030
The last few generation 3-series (M and non-M) have had poor steering racks… clunks and knocks. |
06-22-2022, 05:00 PM | #41 | |
Rep 2,067
06-22-2022, 05:25 PM | #42 | ||
Rep 2,030
I've been chasing this down since summer of last year. It really comes out in the warmer months (I'm in Virginia). |
06-22-2022, 05:43 PM | #43 | |||
Rep 2,067
Sabzi48.50 |
06-22-2022, 06:36 PM | #44 |
Rep 2,373
I noticed odd sound also once lowered on MSS springs. My installer redun my left s0ide a0nd now my right is making a clicking pand squeaky noise and over bumps I'm getting a binding noise. Might not be the exact same as yours and I'm in Virginia also.
Formerly Wyndi335I
FISH225407.50 |
