11-04-2022, 10:14 PM | #1 |
6923
Rep 3,276
Drives: E46 M3 Coupe/G80 M3CX
Drone at 1k rpm
Car has about 2200km on it and just started to notice this drone noise whenever I am off the gas and the engine is slowing the car down. Noise happens right as you are descending to 1k rpm. Sounds like a drone noise and it coincides with some resistance from either the engine, transmission or brakes.
Anyone else have this? |
11-10-2022, 01:51 AM | #4 |
6923
Rep 3,276
Yes it's a groan. Not sure if the engine is lugging though, it's just when I slow down and the rpm is around 1k. The transmission dosent shift down either. Not sure why it's programmed to not shift if the result is that nasty groaning sound.
11-10-2022, 08:18 AM | #5 |
Rep 872
I read your post again. Mine makes noise when I am on throttle, not off throttle like you. Mine makes this weird groaning/grinding noise on very light throttle applications at the very bottom of a gear - so like if you're in 3rd or 4th with RPMs below 1500 and you give it light gas, it will groan/grind until you get to 1500rpm or 1700rpm or so.
2023 iX M60
2023 i4 M50 2024 Wrangler 392 |
11-14-2022, 10:16 PM | #6 |
6923
Rep 3,276
Just bumping this. Just curious if this is a characteristic of the drivetrain before i waste a trip to the dealer. Started to happen after my break in service and it's best described as a done or humming when i am decelerating (coasting) to around 1k rpm and at low speeds without any throttle. It's very quiet but, i can only hear it without the radio on and it sounds almost like a friction or rubbing and it does vibrate the wheel at high frequency. When it happens and i shift down it goes away (not touching the throttle) so probably not brake or diff related.
Any ideas? |
12-12-2022, 07:11 AM | #7 | |
Rep 77
12-12-2022, 07:15 AM | #8 | |
Rep 872
I'm just learning to ignore it. Have you taken yours in yet? I have not but if I decide to do so, I will post what they say.
2023 iX M60
12-12-2022, 07:20 AM | #9 | |
Rep 77
Young04700.50 |
12-12-2022, 07:26 AM | #10 | |
Rep 872
I only drive in D1 until the car is warmed up or if I'm in heavy city traffic so I can mostly avoid it. I had a client in my car the other week and the noise happened and he definitely had a WTF was that look on his face.
2023 iX M60
12-12-2022, 07:34 AM | #11 | |
Rep 77
The specialists at the dealer were also able to reproduce it, but none could find the cause. |
bwoodahl236.50 |
11-27-2023, 02:45 PM | #12 | |
Rep 171
Forzanerazzurri6922.50 |
11-27-2023, 04:00 PM | #13 | |
6923
Rep 3,276
If its normal I am surprised some of the members with more of an OCD attention to detail haven't made a bigger deal about this. |
bwoodahl236.50 |
11-28-2023, 03:27 PM | #14 | |
Rep 171
11-28-2023, 04:04 PM | #15 | |
6923
Rep 3,276
bwoodahl236.50 |
12-04-2023, 06:27 PM | #16 |
Rep 2
I started experiencing this at around 5000 miles on my 2023 M3CX. Hoping that someone / BMW figures it out, the vibration in particular is disconcerting.
Forzanerazzurri6922.50 bwoodahl236.50 |
12-04-2023, 09:58 PM | #17 |
6923
Rep 3,276
12-13-2023, 10:23 AM | #18 |
Rep 171
02-05-2024, 02:56 PM | #19 |
Rep 171
Additional data points. The issue does not occur until the oil temperature reaches standard operating temperature (about 210°F). For my commute, that is about 35 minutes after I leave (in the morning). Then it is fairly noticeable while driving around -- but mostly during "off throttle" when the engine (at above 1700 RPM) passes through 1200 RPM.
Secondly, when I arrived back home today, car stationary and in Park, I revved the engine to 3500 RPM, removed my foot from the throttle, as the engine passes through 1200 RPM there is a slight shudder. P.S. Cold or warm, the car idles like a dream, silky smooth. |
04-30-2024, 11:07 PM | #20 |
Rep 29
Does anyone have a video of the sound they are experiencing? I’m having something similar.
-only occurs when the car is warm -occurs while moving or stationary (both in gear and neutral) -occurs accelerating or decelerating with foot off gas -only occurs from 1k-1.8k RPM I reproduced the sound while stationary. Not entirely clear the source is under the car but the camera picked it up. Don’t really hear it on the engine area. https://youtu.be/ySxWc7osxrw?si=iUiDmbgsfir6O31_ |
05-15-2024, 12:18 PM | #22 |
Rep 2,765
