09-05-2021, 12:36 PM | #1 |
Rep 2,068
My car is lowered on the mss kit but if I remember right I was getting the sound before hand.
It's pretty much at all times forward(pulling out of my garage), reverse(turning), and especially any time im turning. To the point that if you just do a slow tight circle it continuously clicks. Am I the only one? Id really like to take it into the dealer but I'm dreading putting it all back to stock. Update: Solved! All I had to do was torque my lugs to 125😎 |
09-05-2021, 01:29 PM | #2 | |
Rep 148
09-05-2021, 01:55 PM | #3 |
2531
Rep 1,908
I have 15F/13R Burger Motorsport spacers.
The front left 'clicks' in reverse with hard clockwise steering. P Zero tires The clicking is the left front wheel rubbing against vent blades. To date, the blades remain intact. Others have reported them getting cracked off. Personally, not a concern either way, intact or cracked off. Is that your 'click'? Not sure, but sounds very familiar to me. Perhaps your click occurs more often because you are lowered vs. spacer only? Perhaps you have both spacers and lowered? ///AVM |
M4Tejas835.50 |
09-05-2021, 02:06 PM | #4 |
Rep 2,068
@babyghost
Yeah I just watched that, unfortunately I currently have no way at home to jack my car up and take a peak to see if it's the same design as on the G cars. ///AVM Good to see you around again! I actually had the fins cut out of my car which got rid of that problem all together. It's more of a metallic "click" or "tink" sound. |
///AVM2531.00 |
09-05-2021, 05:05 PM | #5 |
2531
Rep 1,908
For those who do not know what the vent blades (or fins) are that are in reference and 'clicking,' here is a pic. . . notice my wheel is turned full clockwise.
In the pic the vents are not catching the blades, nor do they ever catch except in reverse for some odd reason. Even then, they just barely 'clip' them and make that clicking noise. Now that I look closer at photo, I notice there are two blades that are cracked on their margins, and right in line with the tire apex on the wheel well. I suspect, sooner or later, they will get broken off. No worries on my part, as it will have no consequence to form or function of the vehicle. Sounds like TrentMeister just cut them off, which is not a bad idea . . . just rip the bandaid off and get rid of the problem all together. I would consider doing that, but I have no easy access to the inner margin of the blades short of taking the wheel off. ///AVM EDIT: I now also realize why the 'clicking' only occurs in REVERSE. The blades are canted downward. So, in reverse, the tire clips the bottom margin of the blade. Going forward, the tire would only glide over the downward canter. Obviously the tire just barely clips the blades or they would have been torn off immediately the first time I put it into reverse. Still no idea why I have thus far only noticed it on the drivers side??? I would assume it happens on the passenger side with counterclockwise turn of the wheel. Perhaps it does and I have not noticed it from the driver's side??? Last edited by ///AVM; 09-05-2021 at 05:12 PM.. |
09-05-2021, 05:47 PM | #6 | |
Rep 2,068
///AVM2531.00 |
09-08-2021, 03:59 AM | #7 |
Rep 2,119
How annoying
IG: SirLanzelotte
Individual Atlantis Metallic G80 M3 Competition xDrive 2015 Audi Allroad P+ Brilliant Black/Black Past: F80 M3/Z4MR/E46 M3/Z4MC/Z3MR/335Xi |
TrentMeister2950.00 |
09-08-2021, 07:18 AM | #8 |
2531
Rep 1,908
Not sure if that is a question, or a statement?
In the event it is a question, it is not annoying at all. The number of instances I am in reverse and turning wheel hard clockwise are nominal, and the 'clicking' is at the threshold of even being perceptable. Worst case scenario is a couple blades get ripped off the vent inside wheel well. If it was truly annoying, I would just cut the couple blades out. I figure they will just pop off at some point on their own. ///AVM |
09-08-2021, 09:24 PM | #9 |
Rep 2,119
A statement, I would be annoyed, poor measuring/quality check IMO (I wonder if it’s a PZero issue or all tires)
IG: SirLanzelotte
09-08-2021, 09:27 PM | #10 |
Rep 2,068
04-21-2022, 02:00 PM | #11 |
Rep 162
Hi anyone with updates on a solution or reason to why this issue is happening? I’m having the same click noise on my left front wheel
Alvinmark12669.50 |
04-22-2022, 06:15 PM | #12 |
Rep 2,068
04-22-2022, 08:37 PM | #13 |
Rep 371
04-23-2022, 08:48 PM | #14 | |
Rep 421
04-23-2022, 08:54 PM | #15 | |
Rep 421
04-23-2022, 08:57 PM | #16 | ||
Rep 2,068
05-25-2022, 09:42 PM | #17 |
You got my money?
3226
Rep 4,706
Drives: Ice Cream Truck
Bumping this. I just noticed my front end click/ticks once or twice when I go full lock to lock left to right. I hear it pulling into and out of my garage. I can do it on command just turning my wheels side to side. My fins are shaved down and not rubbing. Not sure if this is a normal sound or something to do with me lowering it. But I just noticed it. Anyone find the cause of the clicking noise?
Mine is very faint. It's like one or two max single click/tick sounds.
05-25-2022, 11:38 PM | #18 |
Rep 3,608
Super common on lots of BMWs - have the strut clamp bolt torqued to spec. There’s no downside to doing this, best case it fixes the click and worst case your bolt is just guaranteed to be at spec
Current: F80
Prior: F82, F32 |
05-26-2022, 10:27 AM | #19 |
You got my money?
3226
Rep 4,706
05-26-2022, 11:05 AM | #20 |
Luxury at the redline :)
9108
Rep 7,563
This was a known issue on the "F" generation BMW..
It sounds like a faint "tick tick tick" noise coming from the driver side wheel but only when pulling off at slow speeds. BMW solution was two friction gaskets, one sandwich in-between the wheel hub and wheels and another between the hub and rotor. https://static.nhtsa.gov/odi/tsbs/20...84575-9999.pdf Clicking sound from front left wheel https://www.2addicts.com/forums/show....php?t=1283009 M2 ticking noise from front wheel area https://f87.bimmerpost.com/forums/sh....php?t=1819907 |
05-26-2022, 11:09 AM | #21 | |
Rep 2,068
It's progressively gotten worse as the miles go on. Unfortunately I'm lowered so I know bmw won't even investigate and just say it's from the springs somehow. Even though the sound is rotational and not based on the up and down movement. |
05-26-2022, 11:22 AM | #22 | |
You got my money?
3226
Rep 4,706
