08-28-2022, 02:07 PM | #199 |
Rep 924
Im spoiled..this facility is the nicest in a 300 mile radius. Little kids take up the weekends so I take a weekday morning when work is light
2023 F90 M5
08-28-2022, 02:17 PM | #200 |
Rep 924
You and @jmg were certainly in the back of my mind
2023 F90 M5
08-30-2022, 04:21 PM | #201 | |
Rep 81
2021 G82 M4 6MT
2022 G07 X7 40i 2017 G30 530i |
08-31-2022, 09:44 AM | #202 | |
1954
Rep 1,913
Drives: E92 M3
Before I switched to self-insuring my track car, I kept buying per event insurance for open track days. HPDE insurance doesn't cover open track days, especially those without instructors, so it's something to keep in mind. There are policies that cover open track days, but HPDE insurance specifically does not.
Blk5er3324.00 |
09-10-2022, 04:12 PM | #203 | |
Rep 1,773
09-10-2022, 06:42 PM | #204 | ||
Rep 924
2023 F90 M5
BMWRacer5232522.00 DRLane3996.00 |
09-10-2022, 07:33 PM | #205 | ||
Rep 92
09-12-2022, 12:10 AM | #206 |
Rep 99
MDM vs DSC-OFF
I remember reading somewhere on this forum that MDM was more than just a sporty traction control and after an autocross event this weekend I can definitely confirm it does more than just allow some slip. In my experience, it is more of a loose traction control + stability control. It seems to keep the rear more stable in corner entry in both roll and squat. My guess is its doing something like https://www.topgear.com/car-news/mil...ing-called-kpc by working the rear brakes. This would also confirm why some people have been experiencing excessive rear pad wear in MDM. Either way it makes it very hard to trail brake oversteer on corner entry. Go in too hot and the car just plows and you get massive understeer. I only ran 30% of my laps in MDM so I can't 100% confirm but it seems to keep the car stable mid-corner as well.
On the traction control side, MDM definitely allows some slip but I've noticed only in defined, larger (in autocross terms) corners. Anything sharper than that and it won't give you power until you're straight. Slaloms, tight hairpins, chicanes (again all relative to autocross), and you wont get any slip whatsoever. All this makes sense though, MDM was obviously tuned for the race track and not autocross. I haven't yet ran the car in DSC-off at an actual track, only MDM so far so next time I'll have to try both and see if everything I felt in autocross also holds true on a real track. The times I've ran with MDM on a track though I've had no problems with it and didn't feel like it was invasive. I however keep it under 9/10ths at the track so maybe I haven't fully hit its limits yet either. Anyway, here's my best run from this past weekend, with DSC-OFF |
09-12-2022, 04:04 PM | #207 | |
Rep 924
2023 F90 M5
M4Tejas823.50 |
09-12-2022, 09:34 PM | #208 | ||
Rep 92
09-12-2022, 11:33 PM | #209 |
Rep 99
Interesting, I wonder if different setups move the calibration point towards however way you bias it. I've been able to power oversteer no problem on corner exit in MDM. More testing to be had...
09-12-2022, 11:36 PM | #210 |
Rep 99
I can see that being the case with x-drive since its constantly splitting torque front-rear. I wonder what would happen if you pulled the ABS fuse...
09-14-2022, 08:20 PM | #211 |
Rep 1,773
09-15-2022, 08:01 AM | #212 | |
Rep 924
I am often well beyond threshold and get saved by abs, hear that first chirp and can release at that point. The brakes bite really hard and require a much more softer engagement. It feels like the electronic assistance detects pedal velocity and applies brake pressure proportionally..Im not a fan of brake by wire
2023 F90 M5
BMWRacer5232522.00 M4Tejas823.50 |
09-17-2022, 09:41 AM | #213 | |
Rep 2,700
On some track I almost preferred to drive the M4 in RWD mode. Actually If I were to buy another G80/82 for track duties I'd go with a Manual RWD. I never felt this in the F87 M2 either, DSC Off was just Off, felt different in the XDrive.
09-19-2022, 04:57 PM | #214 | ||
Rep 1,291
PLF693770.00 |
09-19-2022, 05:45 PM | #215 |
Rep 2,700
Probably but on tight corners I didn't like the feeling, felt better in RWD mode.
09-19-2022, 08:55 PM | #216 |
Rep 14,141
Drives: G82 M4C X-Drive
What is it doing? Cutting power? I haven't felt anything close to what DSC feels like, even on tight corners. It should be seamless.
09-19-2022, 08:59 PM | #217 | |
Rep 2,700
Did you try the same laps in AWD/AWD Sport and RWD just for fun ?
09-19-2022, 09:33 PM | #218 |
Rep 14,141
No. Maybe I should next time!
09-19-2022, 09:41 PM | #219 | |
Rep 1,291
There is indeed a smidge more understeer in the XDrive, but lap times were significantly faster than RWD version. Smooth as butter on corner entry and rotation. How's your alignment? I generally prefer Zero front toe.
BMWRacer5232522.00 |
09-19-2022, 09:50 PM | #220 | |
Rep 2,700
Keep in mind it was a heavy convertible with a smidge more flexible frame so it could have some to do. It was a tire eater for sure. I agree I was "faster" in AWD Sport DSC Off but just saying the car felt more eager to rotate in RWD mode. It's a great system, I can't say I see much downsides if one it already going for the heavier 8AT version. Eager to see how the CSL feels but I am lusting about a plane base 6MT M3.. Need to make up my mind
