06-12-2023, 07:01 PM | #287 |
Rep 73
Drives: '23 BMW G80 M3 Comp
06-12-2023, 07:04 PM | #288 |
Rep 191,282
equal length with stock axle back has a rattle on cold start, you'll need to upgrade the axle back to fix it.
06-12-2023, 07:06 PM | #289 |
Rep 73
06-12-2023, 07:07 PM | #290 |
Rep 191,282
Ah ok, got it.
06-12-2023, 07:14 PM | #291 |
Rep 310
Drives: ‘23 M3 Comp xDrive
I can’t speak for everyone else but I don’t have any rattle with the valves open. Same setup, stock everything with this midpipe
06-12-2023, 07:17 PM | #292 | |
Rep 73
View post on imgur.com |
06-12-2023, 08:21 PM | #293 | |
Rep 310
Pizzathehut0494.00 |
06-12-2023, 08:26 PM | #294 |
Rep 73
EatThatLunchBaby388.00 |
06-12-2023, 08:29 PM | #295 |
Rep 246
Been holding off to purchase this vs the MAD single midpipe… think this rattle just about settles it. Sorry to those that are experiencing it!
EatThatLunchBaby388.00 Johndaks43.50 |
06-12-2023, 09:51 PM | #296 |
Rep 310
It’s all good, after hearing sound clips of other midpipes I definitely would purchase this again even knowing about the cold start sound. As Mike has said as well, axel back would solve the issue if/when I want to upgrade
cubanbimmer3310.00 |
06-13-2023, 10:09 AM | #297 | |
Rep 310
Long story short, I think our cars sound the same |
06-13-2023, 01:54 PM | #298 | |
Rep 310
Valves open: https://youtu.be/Iiy0FXZ3ZIs Valves closed: https://youtu.be/pS8eeDubvtM |
CaptBoaty106.50 Pizzathehut0494.00 |
06-13-2023, 07:49 PM | #299 | |
Rep 40
For those with an axle back like the AA, I understand the rattle goes away. Does an axle back significantly increase the volume throughout the range? The stock rear section is already plenty loud. My AA EL mid pipe is paired with a Dahler exhaust valve controller. I have the stock down pipes and rear section. My next test will be to unplug the valve controller to see if I can bring the volume down a bit. It’s a bummer the cold start is so unpleasant because the exhaust note is so good everywhere else. |
06-13-2023, 08:40 PM | #300 | |
Rep 679
06-13-2023, 10:01 PM | #301 |
Rep 129
Oh wow so the rattle is also present with AA axle back???
FrankieNuo1286.50 |
06-13-2023, 10:12 PM | #302 |
Rep 679
Yes, but I haven’t ruled out installation errors. It could very well be hitting the brace or clamped to close to the heat shield. I’ll confirm and report back. Currently it sounds exactly like the videos shared previously, but louder.
06-14-2023, 09:39 AM | #303 | ||
Rep 191,282
I know from personally having this setup and absolutely no rattle, also we have sold hundreds of these, with no complaints. Please double check the brace and midpipe clearance and update us.
Johndaks43.50 FrankieNuo1286.50 |
06-15-2023, 08:52 AM | #304 |
Rep 37
I just installed my the other day no rattle more rasp if anything with a cold start here is the clip
Valves open then closed later on View post on imgur.com |
06-15-2023, 10:37 AM | #305 | |
Rep 191,282
06-15-2023, 11:47 AM | #306 | |
Rep 310
06-15-2023, 12:58 PM | #307 |
Rep 250
06-17-2023, 01:40 PM | #308 |
Rep 165
I was trying to order from active the other week and it showed the EL Mid for G8x was out of stock. When I was trying to order it kept telling me that "my shipping address was avail". I figured was because they were out of stock.
I looked yesterday and saw they were "in-stock" so I tried ordering again and it still said the same thing. I even tried using my performance shop's address and the result was the same. Anyone know why that may be? I've shipped things from active to my home address before.. I emailed active and I'm await a reply, but wanted to see if others had the same issue? https://store.activeautowerke.com/pr...ower-48-states |
