03-08-2024, 06:29 AM | #2 |
Rep 1,929
Every wheel should fit with the low offset on these cars, i had 19x8.5 +25 fit clear the calipers.
03-08-2024, 03:39 PM | #4 |
Rep 1,929
What size/offset? Any dimensions of the drawing? I made a cardboard cutout of the caliper to check on the 8.5" rims but I doubt you'll have issues.
03-08-2024, 09:49 PM | #6 |
Rep 1,929
Here's how i modeled the caliper on some cardboard, should give you an idea if it'll fit.
The dot is the center of the hub/wheel, caliper sticks out around 1.75" from the face of the rotor. The cutout around the dot on the left was 66.6mm wide so it fits inside the wheel. You should have no trouble clearing a +10 9.5" wheel.
03-09-2024, 12:59 AM | #7 |
Rep 25
03-09-2024, 10:15 AM | #8 |
Rep 1,929
Don't have any dimensions, the caliper shape might look weird but that's the shape that was needed to clear it when i made a negative of the cardboard.
03-09-2024, 04:16 PM | #9 |
Rep 25
03-10-2024, 04:22 PM | #10 |
Rep 25
Found this too for reference, thats a brembo gts 6 pot same as m3's.
https://www.racetechnologies.com/sit.../1N1.9070A.pdf Last edited by monkeysrus; 03-10-2024 at 04:29 PM.. |
