04-21-2023, 05:02 PM | #23 |
Rep 609
Doing research on the Falkens, the consensus is they are much more oriented to summer ultra performance tires than true "all season," but better in the rain. A couple of reviews even said they handled better in the dry than P Zeros. That, of course, is just opinion. I would be interested in seeing the difference in launch between performance biased A/S and regular summer. In a straight line, I would not expect much difference. The tread pattern and sidewall stiffness should yield similar results, assuming they are properly warmed up.
04-21-2023, 05:37 PM | #24 | |
Rep 353
04-22-2023, 10:25 AM | #25 |
6918
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
Sent you a PM. You're going to see a difference between performance all seasons and dedicated performance summer tires in launch control. The summers are just stickier because the compound doesn't have to adjust for "winter" temperatures like an all season does. It is what it is. It's probably not enough to discourage you from getting them if that's why you want but again it's just physics and limitations of the compound of an all season tire.
04-22-2023, 10:26 AM | #26 | |
6918
Rep 3,277
davidmct-M3234.00 |
04-22-2023, 12:43 PM | #27 | |
Rep 353
Limegrntaln13475.00 |
04-22-2023, 01:38 PM | #28 |
Rep 6,962
BMW Specs tires specifically for this car. The brands are Michelin, Pirelli, Continental, and Yokohama. Save yourself, and order a proper tire for the car. BMW specs winter tires for this chassis. This will keep you from creating another post, asking why your drivetrain failed, and now BMW is shit.
BMW identifies their tires with a Star on the sidewall. You will see, when you order tires from places like Tire Rack, they designate if the tires are Star marked, or not. Falken, UniRoyal, Firestone, Dunlop, arent on the list. Go out to your car, and look at the OEM tires that came on the car, and you will see the Star. Fit the other brands on this chassis at your own risk.
YT: G Dubyou |
04-22-2023, 02:38 PM | #29 |
Rep 609
Goodyear isn't on the "approved" list either. I doubt anyone can criticize their reputation in high performance cars. I have never seen Yokos on a BMW, but understand they are now an OEM supplier. I have no concern about a failing drivetrain with Goodyears, Dunlops, Firestone, Falken or Kumho. Porsche has an "NO" I believe that is like the BMW star. A friend with a Turbo S tossed (sold) the OEM Goodyears (which are not OEM for BMW as you note) originals and put Generals on it--also non-BMW, but excellent tires. He consistently wins SCCA runs with them. So, while I would not put questionable tires on any performance car, I have no concerns whatsoever with Falkens on the M4C, and look forward to driving in sunny but cold conditions--and a 50,000 mile treadwear guarantee. Lose a little grip? I can live with that.
04-24-2023, 05:03 PM | #30 |
Rep 609
Just an update: had tires mounted today by Discount--only one I'd use. Great ride, no vibration, did not notice a difference in grip at all. Only pita was getting the tire system in the M4 to recycle. Had a warning light until 3rd recycle of ignition. You need to change the tire type to Winter/All Season from summer. Then drive a while to get the pressures. I did the change twice, cycled the ignition 3 times--could see the pressure was reading fine, and all set now. Very happy with A/S decision.
04-24-2023, 07:48 PM | #31 | |
Rep 353
04-25-2023, 02:04 PM | #32 |
Rep 609
There is tire spin, but there was also with the P Zeros. Haven't launched it yet, but doing that--with stability and traction control off, the car goes side to side for awhile after launch with the Pirellis and I would expect about the same with the Falkens. Kind of fun...You do have to screw around with the TPMS after getting new tires, as I said. But, sets correctly after a few restarts once you update tire settings. Other than that, looking forward to taking it out after the snow we're getting tonight goes away.
04-25-2023, 03:24 PM | #33 | |
Rep 353
04-25-2023, 08:30 PM | #35 |
Rep 353
04-26-2023, 01:28 PM | #36 |
Rep 609
I agree. Whatever loss in RWD would be made up for by the fronts gripping. Excepting the low ground clearance, an AWD M3 would be the ideal daily driver. The M4 would too, if you only have small kids for the back seat. Keep everything in efficient, respect braking distances on slippery roads, and you'd be good for ~ 3-4 inches of snow. Ice? Forget it in any car.
04-27-2023, 09:27 AM | #37 | |
Rep 272
Valvetronic V2 Cat Back, CS Flash. -VPC Delivery Day. |
04-27-2023, 11:17 AM | #38 | |
6918
Rep 3,277
The extra grip you have with a dedicated summer tire is why they wear twice as fast. These charts seem to ague that there is a paradox here where the energy from the 2x wear rate is somehow lost into the ether. If this is true then perhaps for most people an all season probably makes more sense for their daily. |
04-27-2023, 11:50 AM | #39 | |
Rep 272
Forzanerazzurri6918.00 |
04-27-2023, 01:33 PM | #40 |
Rep 609
As I said, I'll give up .2 of a G on the skidpad for 50,000 tread wear warranty and the ability to drive in dry but cold (<40) weather. As to 2X the wear, I would have gotten maybe 7500 on the right rear, and 1000-1500 more on the left. The fronts were good for probably 10-11,000. I expect the Falken A/S will last LONG after I trade the car in. From the research I did, the sidewalls are unusually stiff and the tread surface somewhat softer than other Ultra High Performance All Seasons. And the price was right. Whether they make sense is an individual decision, of course. They do for me and I had always planned on getting them for my next set--just not so soon.
04-27-2023, 03:25 PM | #41 | |
Rep 353
04-27-2023, 03:59 PM | #42 |
Rep 609
Just an update: took it out on my normal backroads. No difference that I noticed. Going around 25MPH (suggested) curves at 65, launch control, or simply punching it at various speeds. On a track or skidpad--neither of which I do, maybe some diminished cornering speed would be noticed. But on straights or constant and gently decreasing radius turns, feels the same.
04-27-2023, 08:59 PM | #43 | |
Rep 272
02-26-2024, 09:21 AM | #44 | |
Rep 18
