05-14-2022, 07:29 PM | #1 |
Rep 328
Wheel Adapter 5x120 to 5x112
I have a set of BMW 641m winter wheels from a M2C with a center bore of 72.6 mm and a PDC of 5x120 Bolt 14x1.25 I have ordered a 2022 G82 and of course the CB and PDC are different. The CB on the M4 is 66.5mm and the PDC is 5x112 Bolt 14x1.25. I have done the math and the wheels will fit with the correct wheel adapter. There has to be an adapter 5x120 that can be bolted onto the G82 hub? No luck finding one at this point. No hard driving during winter. Just looking to take the car out 3-4 times a week to charge the battery The set I have now have 3K and they are Michelin Pilot Alpins...Frustrating....
2023 M4 Comp
Dravit Grey Metallic |
05-14-2022, 08:12 PM | #2 | |
Rep 16
Agreed
05-14-2022, 09:30 PM | #3 |
Rep 100
HnR makes a 5x112 to 5x120 adapter for the g80.
Its hub centric as well. I used them to run some some bbs wheels before they were available for the g80. Pm me and ill get you a part number on Monday when I get to the shop. |
08-22-2022, 11:05 AM | #4 |
Rep 151
Can you pm link me to those?
2022 G82 M4 XDrive
2019 F82 M4 (sold) |
09-28-2022, 12:39 PM | #6 |
Rep 51
Drives: 2022 Brooklyn Grey M3 Manual
Not sure if anyone had success with this. I'm trying to fit HRE R101s that were used on a 2018 F80 M4 onto my 2022 G80 M3.
I just ordered H&R part# 405756653 which I think will do the job. It converts from PDC 5x112 with center bore of 66.5MM to PDC 5x120 with center bore of 72.5mm. And it has a thickness of 20mm. I got two sets, one for front and one for rear. Concerned that they will both fit/work but hard to find the resources online to figure it out. Not sure if I need to oder new lug nuts or anything else? |
09-28-2022, 07:23 PM | #7 | |
Beware of cheap bait!
709
Rep 715
09-28-2022, 11:40 PM | #8 |
Rep 328
2023 M4 Comp
12-06-2022, 07:04 AM | #9 | |
Rep 328
2023 M4 Comp
12-15-2022, 10:56 AM | #10 |
Rep 94
I did communicate with Weiser, who was unsuccessful with these adapters. I had already ordered a set, and have subsequently tried, and failed, as well. The adapters do fit the G80 hub and are a fit for my F80 hub. The problem is: the bolts included with the adapter are not the correct thread size. The G80 wheel bolts also will not fit the threads on the adapter. I was not able to source the correct bolts to attach the adapter to the hub. Performance Wheel Adapters in Fla.advertised the correct bolts: 14x1.25, 25mm shank, 42mm overall length, but what I received was 44mm long which protrudes by about 2 mm from the recessed hole and that will not work. The wheel bolts can be replaced by another BMW bolt; happy to get you the part number, but the issue is not the wheel bolts.
So, I finally gave up! I've mounted my winter tires on the G80's wheels and will purchase the ECS adapters when and if they become available. Hope this helps. |
12-16-2022, 07:26 AM | #11 | |
Rep 328
2023 M4 Comp
12-16-2022, 10:39 AM | #12 |
Rep 1,929
Shave them down?
12-16-2022, 11:04 AM | #13 |
Rep 94
01-01-2023, 04:13 PM | #15 |
Rep 6,589
Buy the correct wheels. These adapters are a dumb solution IMO.
01-02-2023, 10:16 AM | #16 |
Rep 94
IMO: adapters are absolutely a solution if you already have a set of wheels that you've expensed and appreciate. Unfortunately, the correct combination of adapters, hub bolts and either studs or wheel bolts are not yet available.
01-02-2023, 10:27 AM | #17 |
Stance to make her dance
708
Rep 2,002
I plan to have some adapters custom made. There are plenty of companies out there who can make them custom. I will report back when I do that.
01-02-2023, 07:24 PM | #18 |
Rep 328
Well when you have a set of 641M wheels with Pilot Alpin 4's with 750 miles from a M2C it's worth a shot. I have a set of adapters on order. It's worth a $300.00 shot to take the car out a couple of time a week in the winter.
2023 M4 Comp
01-02-2023, 08:02 PM | #19 |
708
Rep 2,002
01-12-2023, 10:39 PM | #20 |
Rep 328
Okay I installed the wheel adapters from ECS Tuning this morning and they fit perfectly. Here are the part links
https://www.ecstuning.com/b-ecs-part...-7256/?pdk=AQE https://www.ecstuning.com/b-turner-m...1467ecsx5~ecs/
2023 M4 Comp
01-13-2023, 04:25 PM | #22 |
Rep 328
No, I checked their site daily and they were always back ordered 4-6 weeks out. One morning 2 weeks ago I checked and they were in stock and I immediately ordered them and the were delivered 4 days later. ECS customer service said they sell quickly when they come in and they are made in Germany which adds time to shipments. I would keep checking...
2023 M4 Comp
kupcake58.50 |
