BMW Lease Deals
      09-17-2024, 07:48 AM   #1
TJay74
Drives: 19 Audi S4, 20 X3M & 24 M4xC
24 M4xC - check tire pressure warning
So I got this warning multiple times yesterday. Tires are the one thing I stay on top of all the time as I check them several times a month. The door placard shows tires should be at 32psi, the iDrive showed the tires were no lower than 30psi.
I went ahead and brought the tires back up to 32psi, even still the warning persisted. I headed on into work. Left work to head home and run an errand. No warning, then ran my errand and came back out to the car and the warning is back up on the iDrive again.
Is anyone else seeing this behavior with the tire pressure warnings on the iDrive?
      09-17-2024, 08:02 AM   #2
Vernmeister
Drives: Subaru wrx - M3 awaiting produ
I had this on my manual ‘24
There are settings in idrive where you can go in and select the type of tires your car is mounted up with. My car came from the factory with race tires selected in idrive. The pressure settings for race tires has a recommended pressure of 36 or 37 for the rear.
The manual lists all the different pressure recs for different sizes tires. Most are around 33/32 but the race or track tire size has higher pressure for the rear.
When it got colder with the seasons changing I got the tire pressure warning but when I inflated to 33/32 it didn’t go off. Then I figured the above out. Go into idrive and find the tire settings and make sure it’s set to the right tires
R1250GS89.00
      09-17-2024, 09:42 AM   #3
jimbethesda
jimbethesda's Avatar
Drives: M3 (F80)
Recommended rear psi is 38 on my car. Did you fill them all to 32?
2001 330Ci (sold)
2007 335i (sold)
2008 E90 M3 (sold)
2015 M3 (sold)
2022 G83
      09-17-2024, 09:55 AM   #4
Vic55
Vic55's Avatar
22691
Drives: 2024 BMW M3 CS-2025 BMW M4 CS
Whats your setting in the IDrive for TPMS? There is a summer tire, winter tire, etc and speeds. If you have it in Summer and over some crazy speed number (I am not with my car so I cant check it) the TPMS range will be higher so even if you are at 32 which is great btw; the higher TPMS expectation will possibly make your 30 psi out of tolerance.
I run Summer and under 155 or whatever the speed is listed so the pressure range is 32 and therefore if my car hits 30 on a cold day at start it wont trigger.
2025 BMW M4 CS Black Sapphire Metallic
2022 Porsche Carrera GTS Coupe Shark Blue
2020 Audi R8 V10 Performance Suzuka Gray
2012 Mercedes Benz C63 AMG Black Series Obsidian Black
yousefnjr6890.00
      09-17-2024, 10:09 AM   #5
/ / / M3
/ / / M3's Avatar
1049
Drives: 2024 M3 Comp xDrive
Keep in mind that the tire pressure indicated on the door placard is cold tire pressure. It can go up several psi as the tires warm up from driving. So if your warm tire pressure is 30 psi, it is significantly under-inflated.
      09-17-2024, 11:24 AM   #6
yousefnjr
salty cowboys fan
yousefnjr's Avatar
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
Mine doesn't usually go off until it's ~25 psi or so, I think I have the setting on summer/"other' tires in ID7. Try fiddling with the type of tire setting you have.
      09-17-2024, 12:56 PM   #7
TJay74
It was checked stone cold as I always check all of my vehicles.
I will look into the iDrive when I get home later, to be honest I forgot to check that screen. I use it all the time on my 20 X3M but the menu system is vastly different from iD6 to iD8.5.
      09-17-2024, 01:15 PM   #8
Vic55
Vic55's Avatar
22691
This is what I was eluding to but not so eloquently
R1250GS89.00
      09-20-2024, 01:22 AM   #9
freshxdough
freshxdough's Avatar
3695
Drives: 2024 iX 50 | 2020 X3 M40i
You need to select the correct tire size for the rear and then reset the TPM. You’ll see a check control message that states initialized tire pressure monitor.
      09-20-2024, 05:35 PM   #10
Race_Doc11
Race_Doc11's Avatar
485
Drives: 2023 G82 M4
2023 BMW G82 M4  [10.00]
2018 F80 M3  [10.00]
2013 Audi RS5 (Sold)  [10.00]
2008 E93 M3 (Sold)  [10.00]
Where did you get the information from. The door says 32 psi
      09-20-2024, 06:36 PM   #11
/ / / M3
/ / / M3's Avatar
1049
The BMW app will often show recommended tire pressure values that are different from what's written on the door placard. I'm assuming that these recommendations are based on actual (as opposed to cold) tire temperature.
      09-20-2024, 06:55 PM   #12
MMnut
Drives: M4
Sometimes the sensors have a glitch. You can do the trick by inflating tires to 38 / 40 psi then save the setting in iDrive. Drive for a day or 2. Confirm no warning then reduce the tire pressure down to 35psi and then save the setting again in iDrive. Drive a day or 2 and reduce again till your preferable pressure sand save it.
My current setting is 32psi for over a year and no warning at all.
      09-20-2024, 09:32 PM   #13
Drives: S4
Not sure how you guys run 32 PSI on these cars and find it OK. It’s a heavy car. I ran either 36 or 38 both front and rear on the S4 for street and the M is no different, I’m sticking to same pressures, depending on feel. The Michelins that I know you guys love to run already have a soft ass sidewall, they must feel like marshmallows at 32. Lol
      09-20-2024, 09:51 PM   #14
jimbethesda
Drives: M3 (F80)
Mine says 32 38.
Maybe model specific.
2001 330Ci (sold)
2007 335i (sold)
2008 E90 M3 (sold)
2015 M3 (sold)
2022 G83
      09-21-2024, 05:53 AM   #15
Race_Doc11
Race_Doc11's Avatar
485
Drives: 2023 G82 M4
2018 F80 M3  [10.00]
Thanks! It says 33.1 is the recommended pressure. I’m not going to bother I always run 35 psi all around. It drives and responds better this way. .
      09-21-2024, 07:12 PM   #16
MMnut
Drives: M4
You may have higher pressure on stock car but if it's lower than surely you dont want the same setting as it is a very crashy and bumpy drive for sure. I have tried on 38 / 40 and couldn't stand it. From 32 to 34 is much better. And the same setting recommendation on door card and in the app. And also depending on how many people in it.
      09-21-2024, 08:27 PM   #17
Burrcold
It's tire specific as well. I have Pirelli P Zeros and my recommended pressure is 32 front 35 rear.
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5
