BIMMERPOST Universal Forums Site Related Announcements - Suggestions - Feedback - Questions
      05-22-2022, 08:11 PM   #485
apptest
Private2
apptest's Avatar
Drives: BMW M3 F32 Coupe!
Originally Posted by MadBimmeRad View Post
Yep, still happening
See images
Ok thanks, I think I have a better understanding of it, I just pushed out version .30 which I hope takes care of the red and yellow at the least, but potentially the entire problem.
Let me know
Test 23456rt
      05-23-2022, 02:34 AM   #486
MadBimmeRad
MadBimmeRad's Avatar
Australia
7123
Drives: M235i, 420i, and now the M2 CS
See images
Let me know
Will do; so far, so good 🤞
M2CS,
The second coming of ///M!
apptest2999.00
      05-24-2022, 07:21 AM   #487
zcp312
///M
zcp312's Avatar
Drives: 2011 E90 M3 ZCP
Hi I’ve just released version 5.2.23 which I believe fixes this issue. If you notice more problems could you let me know?
Thanks!
Doesn't seem to be happening any longer over the last few days and a few different versions since 23. If I notice it again I'll let you know.
apptest2999.00
      05-25-2022, 03:55 AM   #488
titomi
titomi's Avatar
Drives: X3 G01 30i xDrive
2018 X3 G01  [0.00]
Looks like the performance went down with the latest updates. The app is slower, when I owned after some time. It takes longer to load forums list, forum threads, news, etc. I'm on the latest version and wifi connection, using Samsung device with Anddiid 11.
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
      05-25-2022, 05:21 AM   #489
apptest
Private2
apptest's Avatar
We didn’t change anything in those areas for a while.
Might be some random intermittent connection issue? I would say, keep an eye on it
Test 23456rt
      05-25-2022, 05:35 AM   #490
MadBimmeRad
Australia
7123
Everything seems stable on my end so far
On the news page, I no longer see any images associated with new threads
Is that meant to be?
Edit: edit send to be behaving also
M2CS,
apptest2999.00
      05-25-2022, 06:03 AM   #491
apptest
Private2
apptest's Avatar
That’s awesome to hear. We might have finally cracked that one then 😂
From the last screen shots you sent, it looks like you have “boss mode” enabled. That mode is designed to purposely remove all images from the interface. It’s still a work in progress and is about 75% done.
But you can just turn it off to get all the images back.
Goto setting -> app interface settings and switch it off and all those images should come back 👍
Test 23456rt
      05-26-2022, 06:05 AM   #492
apptest
Private2
apptest's Avatar
Any better today?
Test 23456rt
      05-27-2022, 01:50 AM   #493
MadBimmeRad
Australia
7123
Sadly my friend, it is happening again
M2CS,
apptest2999.00
      05-27-2022, 04:36 AM   #494
MadBimmeRad
Australia
7123
Also
Can we please have a feature in the messageboard where we can simply choose to DELETE ALL when the inbox is full. Atmo, I have to delete messages one by one to clear room in my inbox. With a maximum of 220 messages, it takes a long time to delete them.
Cheers
MBR
M2CS,
apptest2999.00
      05-27-2022, 06:16 AM   #495
apptest
Private2
apptest's Avatar
Thanks. It will take more time but we will solve this 😂
From which section of the app were you reading that thread? Ie. news, forums, my forums, new posts, subscriptions, notifications, etc…
Is there any pattern of events you notice where you can force that to happen?
Test 23456rt
      05-27-2022, 06:42 AM   #496
titomi
titomi's Avatar
2018 X3 G01  [0.00]
Any better today?
No. I might try to do a ideo capture of the screen. Maybe it is working as it should be, and it's just slow for me.
apptest2999.00
      05-27-2022, 06:44 AM   #497
titomi
titomi's Avatar
2018 X3 G01  [0.00]
Can't see the user name in the notifications in dark mode. It's visible in the light mode.
apptest2999.00
      05-27-2022, 06:46 AM   #498
MadBimmeRad
Australia
7123
It was from SUBSCRIPTIONS section
FWIW, I'm running v33
As for forcing it to misbehave, not really, it happens at random. It often happens when I'm replying to a post (where the page doesn't scroll up which means I can't see what I'm typing).
Then I check my reply and often Google has done an autocorrect on me which means I have to edit, and correct my reply.
The red font with yellow underline appears at this stage. I've had the red font on other occasions but it's not frequent.
So it goes like this, if the screen doesn't scroll, then edit will go red font, guaranteed. But, getting a red font doesn't just happen with the window not scrolling.
M2CS,
apptest2999.00
      05-27-2022, 06:47 AM   #499
MadBimmeRad
Australia
7123
Ditto
M2CS,
      05-27-2022, 09:28 AM   #500
apptest
Private2
apptest's Avatar
That would be great to show what you’re seeing
Test 23456rt
      05-27-2022, 09:31 AM   #501
apptest
Private2
apptest's Avatar
Nice catch, this is fixed in the next release coming today or tomorrow 👍
Test 23456rt
      05-27-2022, 09:42 AM   #502
apptest
Private2
apptest's Avatar
Ok I think I figured out how to make it happen, its happening when the app is closed, and you get a push notification and tap that to open the app and view the post/thread. Then if you try to use the drop down the red/yellow occurs.
Ok now to work on the fix…
Test 23456rt
      05-27-2022, 09:51 AM   #503
zcp312
///M
zcp312's Avatar
Originally Posted by zcp312 View Post
Feature request - when searching on Google or any search engine on your phone and clicking into the search link for one of the forum threads, it opens in the browser, there is no popup asking if you want to open the thread in the app. This would be very helpful to open the threads in the app instead of staying in the browser.
That's a great suggestion! Its on the list for future work 👍
Any updates or eta on this feature?
      05-27-2022, 10:15 AM   #504
apptest
Private2
apptest's Avatar
I’d say another month best case, but it is very high on the list
Test 23456rt
zcp31294.50
      05-27-2022, 01:20 PM   #505
apptest
Private2
apptest's Avatar
Ok I have released version 5.2.34 with the above recent fixes 👍 (… I hope!)
I also added a new feature where you can go to the next page in a thread by pulling the screen up when you reach the end of a page.
Try it out and see if you like it and it works for you all, its experimental for now
Test 23456rt
      05-27-2022, 02:32 PM   #506
titomi
titomi's Avatar
2018 X3 G01  [0.00]
Fixed. Thanks.
apptest2999.00
