12-22-2021, 07:21 PM | #45 | |
9055
Rep 7,621
W288SH159.00 Capt Canuck704.00 |
12-22-2021, 08:18 PM | #46 | ||
Luxury at the redline :)
9105
Rep 7,563
Bye bye Apple CarPlay and Android Auto due to chip shortage?
I figure that, hence the original sarcasm.. It's funny that works; when I suggest I would get the moonroof because this is a daily driver, not some racecar.. I get pushback like; "Bro, this a racecar, carbon fiber roof only!" But when BMW omits CarPlay, you hear folks crying about; "This is my daily driver that I go pick up toilet paper and bread with, not some racecar; how dare they take away my creature comforts 😢" |
12-22-2021, 11:52 PM | #47 | |
Rep 66
12-23-2021, 04:43 AM | #48 | |||
Rep 337
12-23-2021, 10:47 AM | #50 | |
Rep 6,637
Also I'm perfectly happy with the two cars I have now, no reason to sell them for something new I'm not happy with. |
12-23-2021, 11:07 AM | #51 | |
Sith Lord
3452
Rep 893
Drives: G80X, Mazda 3 6MT (daily)
aimetti163.50 |
12-23-2021, 11:31 AM | #52 | ||
9105
Rep 7,563
Just busting some balls here.. 😉 You have an E92 M3 also, right? Sweet right, one of all time faves.. 👍🏻 |
12-23-2021, 02:32 PM | #53 | |||
Rep 6,637
Poochie9104.50 |
12-23-2021, 09:26 PM | #54 | |
Rep 322
12-23-2021, 09:50 PM | #55 | |
9055
Rep 7,621
Poochie9104.50 |
12-23-2021, 10:43 PM | #56 | ||
9105
Rep 7,563
I agree, the carbon roof does look hella cool and it's awesome that you're honest and at peace with your decision, thus, my previous comment doesn't apply to you. It was more so to highlight the hypocrisy of some folks perception of the vehicle's model purpose, which is constantly changing on a sliding-scale to support their argument. Regardless, let's move on, 'cause it obviously went over some folks head and they're taking it too personal. 😗 |
12-24-2021, 05:57 AM | #57 | |||
Rep 779
2022 M3 Xdrive Frozen Dark Grey - 4/27.
2016 Charger Hellcat - 908 RWHP & 988 WTQ 9.9@ 140 - 2012 - Charger SRT 392 - Sold 2009 - Charger SRT 6.1 - Sold |
12-24-2021, 07:25 AM | #58 |
Rep 1,124
It impacts every manufacturer, tbh
?When you have fast cars and bad luck, it's a lot easier to handle than having slow cars and bad luck.?
Kevin Harvick |
12-24-2021, 07:38 AM | #59 |
Rep 3,292
This is getting so nuts. I'm amazed that I had a moment where I almost turned away from buying my car in March because it was one of the HEA cars that didn't come with blind spot monitoring...a feature I've never had on a car and don't really need. I feel like I should go hug my cameras and features that I DID get.
Best wishes to you all |
12-27-2021, 08:32 AM | #60 |
Rep 1,108
So, this is the #1 thing that has me worked up about my order (I'm #4 in line for an allocation at my dealer). My question is…..has anyone else (besides the OP) received this message? My hope is that, if no one else has received this, maybe it's not happening? Also, if CarPlay is deleted, am I reading this correctly that it WILL be retrofitted later? Meaning, it's only temporary for those that have this deleted? Is it US? Canada?
12-27-2021, 08:46 AM | #61 | ||
Rep 482
The Nerd427.50 |
12-27-2021, 08:53 AM | #62 | |
9105
Rep 7,563
Reading between the lines, it sound like the part that they are in short supply of is the WLAN antenna, which is an external part that easily plugs into the back of the iDrive unit and allows for communication with your phone, via WiFi, which then makes provisioning of CarPlay an option. Bluetooth 5.0 is built into the iDrive unit and uses a separate module to communicate with your phone, so that option remains all the same. So widgets (such as Spotify) within the iDrive system would still function as normal, without the Wi-Fi antenna. In fact, some ingenious folks might be able to use an aftermarket WLAN antenna and revert CarPlay sooner, before the supply-chain bottleneck catches up with demand for the OEM antenna. . |
The Nerd427.50 QuarterMileJoe9.00 |
12-27-2021, 09:43 AM | #63 | ||
Rep 2,303
2001 330Ci (sold)
12-27-2021, 09:56 AM | #64 |
Beware of cheap bait!
709
Rep 715
12-27-2021, 10:09 AM | #65 | |||
9105
Rep 7,563
If you're lucky, they didn't change the actual programming and just systematically blocked CarPlay, since the hardware is not available to support it. That would mean it could be easily be coded back on, once you install the Wi-Fi antenna. However, if they developed a separate program to bin these features, then it would require a complete re-flash of the iDrive software, back to version of software that is written for CarPlay as an option. It's soon to tell just yet but if I had to make an educated guess, I would say it's just blocked via coding. The negative to this is that you would not be able to easily jump into a wired version of CarPlay, since the set software is not setup to allow such functionality. I can't find any specifically on the iDrive 7, since CarPlay is now typically included standard, across the board but here is an an example of how it's flashed on earlier versions of iDrive. They are pretty much all the same, minus the minimally revised hardware between each iteration. |
jimbethesda1856.00 QuarterMileJoe9.00 |
12-27-2021, 10:10 AM | #66 |
Rep 1,070
are touchscreens still not available? i can't imagine using carplay without a touchscreen
2018 M3 6 spd
2017 M3 AW/SO 6spd 2014 435i M sport BSM/Coral 6spd (retired) 2013 550i M sport Alpine White/Cinnamon (retired) |
