10-19-2023, 09:07 PM | #1 |
Rep 5,178
Post your S58 Log Links here
This is a thread to post your logs, so we can build a library to compare ours against other logs. It's not meant as a discussion board to ask people to read your logs, please take those offline using your Private Messaging box.
RULES: Web links are preferred for logs. Post as many links as you like, but they MUST be the S58 engine. PLEASE detail your platform/tune, fuel and mods. Stock is welcome too. If you are showing examples of a problem (bad plug, injector, sensor, etc.) or learn of it later, please add that info to help us. Preferred values to log: Acceleration (pedal%, gear#, throttle angle, vehicle speed) Temps (ambient air, IAT, coolant, etc.) Boost (boost pre-throttle, boost target, MAP, WGDC) Timing (ignition timing 1,2,3,4,5,6 and knock) Fueling (HPFP targ. & act., LPFP, lambda act & bank 2, STFT & bank 2) ...and whatever else you like! And if someone starts to Troll just be and maintain Last edited by TopJimmy; 10-19-2023 at 09:30 PM.. |
10-19-2023, 09:15 PM | #3 |
Rep 381
Finally! I tried to get some views of logs but no one was sharing. Makes no sense even if custom tuned bc it doesn’t show what changes the tuner is making but more of what your car is doing with those changes.
10-21-2023, 02:34 PM | #6 |
Rep 381
Once I’m back from F1 I’ll share logs as well
hellcat2m4227.00 |
11-13-2023, 08:18 PM | #8 |
Rep 5,178
Hey khalua80 and Abacus
Can you delete your comments? That noob tuner got his post yanked for pandering. I’ll pull this down after, to keep the thread clean.
11-17-2023, 04:42 AM | #9 |
DisplacementReplacement
428
Rep 1,117
I think this is a great idea, the B58 community has hundreds of pages of logs which is helpful for comparison reasons... I'll post my MHD logs as soon as i can.
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
TopJimmy5494.00 |
01-26-2024, 03:03 PM | #11 |
Rep 5,178
No, just the CS Trans Flash by Kubax.
hellcat2m4227.00 |
01-26-2024, 09:33 PM | #12 |
Rep 962
Anyone know if that CSL map is a “true” CSL map or just what they built and extrapolated by logging a CSL? I’ve heard mixed info… that it’s 100% BMW’s factory CSL tune and then I’ve heard that it’s a modified Comp one to CSL boost values.
01-27-2024, 07:06 AM | #13 |
Rep 5,178
You could email Support at PTF and let us know what they say.
01-27-2024, 08:34 AM | #14 | |
2022 M4 Comp Xdrive
1019
Rep 1,538
"STage 2 93 is our OTS map and the CSL map is the OEM map from BMW." |
01-27-2024, 10:15 AM | #15 |
Rep 962
I did, just like the other poster above this and they said it was the OEM CSL map, but then additional info came out that they never did source a true CSL map (either dumped or BMW sourced), so that’s why I asked.
02-02-2024, 08:36 AM | #16 | |
Rep 4
greetings, yesterday i have tried e50 map same as you, my logs are identical of yours, what was your 100-200 ? thank you |
02-02-2024, 09:51 AM | #17 | |
Rep 336
I have XHP, but am NOT running drag race mode. This is just the regular stage 3 Map. |
02-02-2024, 03:32 PM | #18 | |
Rep 4
Im wondering that this E50 map is just a joke |
02-02-2024, 04:31 PM | #19 |
Rep 336
Damn on 93?! I got 7.4 and 7.6 in about 1500 DA with the E30 OTS.
The OTS maps are just conservative is all. Custom tune is where its at apparently. |
02-03-2024, 03:38 AM | #20 | |
Rep 4
my 100-200 6.0 sec is 60-130 7.5-7.6 seconds, so why i do ask your results? because i have better times on 93 octane than on e50 map 😅 I have identical logs as yours, also 93 octane has 9 degrees on ignition and e50 has 14-16 degrees but times are same or worse i dont know why, boost are same So I think this E50 map from bm3 is just a joke and nothing else |
02-03-2024, 08:50 AM | #21 | |
Rep 336
Not confused at all, well aware of the 60-130 vs 100-200kmph differences. Are you sure your blend was right? This map would be high 6s with drag race mode turned on in XHP. I havent posted my logs yet, but it's pretty much the same as everyone else's. I'll be going custom tune shortly with Orlando Autowerks. Last edited by hellcat2m4; 02-06-2024 at 11:17 AM.. |
02-06-2024, 03:53 AM | #22 | |
Rep 4
my logs are identical to yours, no retardation of ignition timing or knock or boost lower, all same but my 100-200 was like 6.3 while 93 oct tune my time was lower 😆 like 6.0-6.2 seconds. my main question is why boost pressure is so low like 23 psi on e50, |
