01-10-2023, 12:53 AM | #1 |
Rep 13
Engine limiting power during donuts
Decided to finally make a post about this lol
In M2 with everything on sport + with DSC full off, my 6 speed g80 limits my revs and cuts power. What is the point of having a 500hp sedan with a clutch if I can’t send her out in some donuts?? Tried to search this up but nothing comes up Anybody have an idea of what’s going on? Screenshot uploaded for reference |
01-10-2023, 01:22 AM | #2 |
Rep 145
That's strange. It shoudn't be doing that. Maybe the engine is getting to hot, or not enough fuell? Do you have the 10 step traction? Maybe that's not at 0?
jimbethesda1865.00 |
01-10-2023, 08:47 AM | #3 |
Rep 8,091
Drives: 2024 X5 M60i
How soon after starting the car up are you trying to go out and do this?
NorCalAthlete3196.50 |
01-10-2023, 10:36 AM | #5 | |
Rep 2,311
OP, do you have M Drive Professional on your car? If so, make sure that’s set to 0 and try again.
2001 330Ci (sold)
01-10-2023, 10:49 AM | #6 | |
Occasionally frequent poster
3007
Rep 2,745
The only reason (other than the aforementioned M-drive parameters being set correctly) is perhaps you only think that you have DSC off. There are two steps to it, you know. It's also possible that you did something to make the car think you are in launch mode.
Current inventory:
01-10-2023, 11:10 AM | #7 | |
Rep 2,496
Drives: 2018 F80 M3 CS,2017 F87 LBB M2
2018 F80 M3 CS
2017 M2, LBB, DCT, exec, car play, MPE, diffuser 2011 E90 M3 ZCP Past: E90 328i, F10 535i, F80 M3 (murdered) |
01-10-2023, 01:03 PM | #9 |
Rep 2,496
2018 F80 M3 CS
01-10-2023, 01:12 PM | #10 |
Rep 14,141
Drives: G82 M4C X-Drive
His oil temp is warm. Probably drove to that location, turned the car off for awhile, then started it up again to do donuts. I've never took note if the RPMs max out even if the oil is still warm.
OP: I would check to see that you have your lane assist and impact detection off etc. Easiest way is to go into TRACK MODE, which automatically does it for you, although your windows still might go up as mine do during donuts.
01-10-2023, 01:14 PM | #11 |
Rep 317
his oil temp gauge is saying 210 though....at least thats what i think it says from the blurry mess. lol
F87 /// M2 Comp - Hockenheim Silver/Black/Blue Stitching
G80 /// M3 CompX - Imola Red/Black/Carbon Buckets |
01-10-2023, 01:14 PM | #12 |
Rep 610
01-10-2023, 01:35 PM | #13 |
///M ♥ Recycled Dinosaurs
3213
Rep 1,781
Drives: BMW M4, BMW X5 45e
Revs are limited when gas is low. What was your gas situation at the time?
01-10-2023, 01:57 PM | #14 |
Rep 145
Are you a valet?
The only time I ever see the redline restricted that far is after an overnight start in below freezing temps. I don't know how that would happen in LA. Something else seems up besides the mini donuts. I have seen the redline go to full go with both warm oil/cold water and cold oil/warm water, but it seems to be more sensitive to the oil side. I've had full redline with the water temp below the first reading before, so this all seems very odd.
23 G80 TV; 12 C6 Z07 427TT; 99 Trans am
Dearly Departed: 06 Evo MR;16 FoRS |
MichaelB19691045.50 NorCalAthlete3196.50 |
01-10-2023, 05:47 PM | #17 | |
Rep 388
OP: Are you able to do any donuts? If so, after how long does the rev limit drop? If you are able to do some and then the limit is lowered, you may be getting fuel or oil surge that is causing the limit to come down (not that I have heard of that happening… so I am just speculating)
TJR
01-10-2023, 06:38 PM | #18 | |
Rep 14,141
01-11-2023, 02:11 AM | #19 |
Rep 13
01-11-2023, 02:18 AM | #20 |
Rep 13
Going to answer everything in 1 mass reply.
This has happened multiple times after the car has been warmed up to operating temp. Car was warmed up after my drive home from work. DSC is fully off (I don’t have M drive professional so no way to toggle traction settings), all settings are on sport plus, and I am not on valet mode lol. All the traffic nannys are off except for collision warning but I’m not sure why that would cut power? Power gets cut after a full rotation. |
01-11-2023, 05:56 AM | #21 |
3007
Rep 2,745
Well, that's different then.
Obviously you have damaged the engine and it's in limp-home mode. Stop doing this.
Current inventory:
01-11-2023, 07:34 AM | #22 | |
Rep 14,141
If you spin out and the car’s trajectory is opposite that of the gear direction (ie you are not sliding sideways, but backwards) the transmission will cut off so you don’t have to buy a new transmission. Ask me how I know lol.
RM73343.50 |
