07-24-2023, 05:27 PM | #67 | |
Rep 1,453
Out. OY Vey BMW |
m4ml1868.00 |
07-24-2023, 05:42 PM | #68 |
Rep 738
Yes, when you purchase the tune you can purchase it with or without the burbles. It's actually extra $ for the burbles.
07-24-2023, 07:10 PM | #69 |
Rep 1,453
07-25-2023, 06:21 PM | #70 |
Rep 488
Is there a high-flow catted down pipe that works w/ the Carbahn tune? I know a catless voids warranty.
Using stock downpipes w/ a Carbahn tune seems like wasting HP. |
07-25-2023, 06:50 PM | #71 | |
Rep 100
Any aftermarket downpipe, with or without cars, is going to give you warranty issues. That probably includes the Carbahn warranty as well. |
ipayincash41.50 |
07-25-2023, 09:45 PM | #72 |
Rep 1,360
07-26-2023, 10:55 AM | #73 |
Rep 1,453
08-01-2023, 08:43 AM | #74 |
Rep 309
Modern catalysts are actually extremely efficient. Most newer platforms I've been involved with show minimal gains with downpipes.
Blake - 2024 M3 Competition xDrive
Square 826M 20" Wheels, Dinan HAS, Dinan Midpipe, Dinan Axle-Back Exhaust, Dinan 10/12mm Spacers, SST Valve Controller |
08-07-2023, 04:32 PM | #75 |
Rep 215
12-21-2023, 10:44 PM | #77 |
Rep 255
Drives: BMW G82 M4 Competition
Wow, there are a lot of people hating on this piggy back. Although I have many upgrades already installed and a ton of performance upgrades such as pure turbos and my transmission rebuild ready to go, i too am going to go with the Carbahn piggy back for the following reasons:
1. I already had an issue with my transmission leaking and want to keep as much of the warranty as possible. 2. Thompson BMW has a performance shop and will not give anyone a hard time with warranty issues as long as you follow their instructions. 3. If you haven’t tuned a car yet, unless you are an expert driver, it’s better to ease into all of the power of the g8x’s. 4. Having to do the FEMTO unlock will have you ready for a better tune software and map the second you hit your warranty time or miles 5. Unless you plan on tracking the car exclusively, or race for big dollars, this tune will allow you to use your car as a daily driver safely 6. I see a lot of 700HP+ tunes without all of the necessary OEM upgrades that will definitely lead to a catastrophic failure. This tune allows for the car to function within the OEM specs or Carbahn wouldn’t offer the warranty, while giving you a low 10s 1/4 and mid 2s on your 0-60 times. 7. I see aggressive tunes with street tires all of the time get smoked because they can’t keep the car on the road, more power doesn’t always equate to more wins. That’s my take on this post. Thanks for the video and draggy times. Hopefully I see you at the next meet in Philly or Jersey. |
IDKBRO680.00 |
12-22-2023, 02:29 PM | #78 | |
Rep 255
Looks like switching from Carbahn to BM3 may require another unlock. Sucks!!! |
ipayincash41.50 |
01-02-2024, 10:48 PM | #79 |
Rep 255
January 22nd is my schedule date for the Femto unlock and Carbahn tune. Thompson is claiming a bump to 632 Wheel Horse Power on an XDrive. I will be putting the car on the dyno after the tune and see exactly what we get.
Also I opted to keep my CSF heat exchanger instead of using the Carbahn Heat exchanger. Right now I’m clocking 3 seconds on my 0-60 times using a P3 guage. I’ll post my draggy times before and after the tune. |
01-04-2024, 11:06 AM | #80 | |
Rep 1,360
BSMG82M4734.00 |
01-04-2024, 03:32 PM | #82 | |
Rep 738
BSMG82M4734.00 |
01-05-2024, 04:12 AM | #83 |
Rep 255
Car is dismantled right now. As soon as they put it back together I’m taking it to run the Dyno. Will have air intake, charge pipe, exhaust and cooling. I’ll check the results pre and post Carbahn and let’s see what they are really putting out.
If I have a sec, I’ll run some dragy numbers too. Hopefully there isn’t a foot of snow on the ground. |
01-19-2024, 06:23 PM | #85 |
Rep 255
I asked if there was a software change that affected the numbers, they said no. I am going to assume that they made a mistake and quoted the RWD wheel horse power. Regardless, Labworx is going to do a dyno pull next Wednesday before the tune and then another one after. We will see how aggressive the Carbahn tune really is. Stay tuned.
01-19-2024, 07:18 PM | #86 | |
Rep 1,360
This is where the Carbahn tune really shines in my opinion. The HP & TQ gains across the rev range really helped the car accelerate in all conditions. |
01-20-2024, 02:41 PM | #87 |
Rep 609
Why would AWD hp be different than RWD? The engine is identical. Any power adder in X Drive can be replicated in RWD. The added AWD hardware adds nothing to the engine output. Or did I miss something?
01-20-2024, 03:47 PM | #88 |
Rep 1,360
AWD has more parasitic drag than it’s RWD counterpart and therefore will reduce WHP.
