ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M3 (F80) and BMW M4 (F82) General Forum
      04-18-2014, 07:17 AM   #45
Imola.ZHP
Imola.ZHP's Avatar
Drives: 2014 BMW i3 BEV EE
OP, great post, thank you for sharing!
Originally Posted by GolfProGiff View Post
I printed a few copies and made my 3 year old a new coloring book. Thank you!
Parenting win!
Originally Posted by alexmtl_135i View Post
Am I the only one to wonder why the M3 has a wider rear track than front, while the M5 has a wider front track than rear?
I wondered this too, I would think, however, that if there were a benefit to one or the other that they would both be the same. Since they are not, perhaps there is no particular reason for the difference.
- 2014 CPO i01 BEV Electronaut Edition Capparis White Tera World, '17-
- 2015 CPO i01 BEV Laurel Grey Tera World, '17-
- 2015 i01 REx Laurel Grey Tera World, '15-'17
- 2003 CPO 330i ZHP Imola Red Build 03/03/03, '06-'15
      04-18-2014, 07:37 AM   #46
Kadema
Kadema's Avatar
Germany
Drives: 123d
I think this is because of the tires. As track width is measured between tire centers, larger tires result in a narrower track.
      04-18-2014, 08:21 AM   #47
i001947
i001947's Avatar
26
Drives: '13 E92 M3
I love a car with a wide rear
      04-18-2014, 08:37 AM   #48
Savage_M3
Savage_M3's Avatar
Drives: 2011 E90 M3 & 2022 X3M Comp
Interesting. I didn't realize that on the E60 and F10 M5 the front track is wider than the rear. It's the opposite setup on the others...
2011 M3 Sedan - ZCP, DCT
2022 X3M Competition
      04-18-2014, 08:46 AM   #49
bradleyland
TIM YOYO
Drives: 2013 M3
Originally Posted by Thurman Murch View Post
Is wider always absolutely better?
I can see pros and cons for different track setups
Just because the track is wide doesn't mean the car looks better
I prefer the handling of the e9x series over the f3x series
I see a little bit improved turn in and a couple mpg efficiencies
Need to have tangible results from a real drive to come to any real conclusions
Few things are always absolutely better. Wider allows for a longer moment arm for lateral loads in many aspects of suspension geometry (resulting in less body roll and better tire-road contact), but comes at an additional cost in weight.
Wider doesn't always mean better handling though. Keep in mind that handling and roadholding are two different things. Handling is how the car feels; roadholding is how much grip the chassis can sustain. A poorly designed suspension on a wider car will handle worse than a well designed suspension on a narrower car (within limits).
All things being equal (which they never are), a wider car will have physics on its side when it comes to mechanical grip. That's about the extent of what one can say "absolutely" about track width.
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech
Past: 2013 ///M3 - Interlagos Blue Black M-DCT
Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport
      04-18-2014, 09:52 AM   #50
Sir Loin
M3AT LOVER
Sir Loin's Avatar
Drives: Silverstone F80 M3
^^^^ This.
2015 F80 M3 | SSII ext SO int | M-DCT | 19" Black Wheels
      04-18-2014, 09:54 AM   #51
stylinexpat
stylinexpat's Avatar
415
Drives:
Now look at the front and rear track width of the Porsche Carrera and Corvette. The wider the track width the better the high speed sweepers you can take.
      04-18-2014, 10:21 AM   #52
///1M
Drives: On a good day, AW 1M coupe
For city dwellers, certain parking garages will be a problem. The garages with the spiraling ramps can be tricky.
      04-18-2014, 01:39 PM   #53
sq86
sq86's Avatar
Drives: 2013 328i E92 LMB
Never knew that the E60 and F10 had wider front tracks. Probably to help with turn in I assume since they're heavy.
BMW CCA Member# 481791
Current: 2013 E92 328i LMB/Saddle Brown (1 of 21 for E92 LCI in that combo), 2018 F31 330xi AW/Saddle Brown
Sold: 2011 1M BS/Black, 2008 E90 328xi AW/Beige, 2001 E46 330xi SG/Black
      04-18-2014, 09:28 PM   #54
roadmax
Drives: M3 Coupe
I'm just thinking Audi RS5, at first look and you can notice how wide that car is so it was time for BMW to take similar direction with increased width. But RS5 looks even wider because it is around 6cm lower than new M3, so the lower the car it appears wider. So it is the height that counts as well.
f80post
