01-12-2022, 03:53 AM | #1 |
Rep 14
Bmw m3 g80 drifting car symbol
Hello, i have seen this symbol on my dashboard as soon as i turn DSC completely off.
Does anyone know what it means and its function? Thanks in advance. |
01-12-2022, 04:06 AM | #2 |
Rep 290
Never seen it….is it the M Drift mode score? I didn’t get that option. Bet it’s in the manual.
NawafG80M34.00 |
01-12-2022, 04:08 AM | #3 |
m
604
Rep 504
01-12-2022, 04:11 AM | #4 |
Rep 14
01-12-2022, 04:47 AM | #6 |
Rep 14
01-12-2022, 05:46 AM | #7 | |
Rep 430
When that is showing, it means your traction control is completely off and you are in 2WD mode using the 10 level control. This looks like a RWD since you don't have the other symbol showing the axles like mine. I have mine set to level 5 in the pic. [/IMG]
2022 M3 xDrive - BSM/Tartufo
01-12-2022, 06:27 AM | #8 | ||
Rep 14
01-12-2022, 07:16 AM | #9 |
Rep 647
It is on because you turned off DSC and means you have no traction control. That icon is in almost any new car and means the same thing. No traction control and/or vehicle stability system if off. On some cars, it may not be completely off. When you see it flash briefly on most cars it means it is working.
01-15-2022, 10:34 AM | #10 | |
Rep 3,341
Drives: 2022 M3, 2022 X5 40i;
It's your DSC light. It used to be a lot cooler, an ! in a triangle. Now it's lame. In normal driving without any changes, it will flash if you lose traction and the vehicle cuts power. If it is fully on (the light I mean), that means you have traction control fully disengaged. That means: No nannies - the vehicle will not brake a specific wheel, or reduce engine power in the chance it recognizes slip No auto-steering - i.e. if you have lane depart warning or something to that effect, it disables any steering wheel intervention. So basically it means the car's handling is 100% all you. |
01-15-2022, 10:38 AM | #11 | ||
Rep 2,302
2001 330Ci (sold)
01-15-2022, 10:46 AM | #12 |
Rep 341
That’s your oil temperature gauge. If it’s only coming on when you turn DSC off, something is wrong. Go to the dealer and get the car flashed to the newest software.
You can tell something is wrong because the units of measure are Celsius. They should always be in Fahrenheit because imperial. |
01-15-2022, 11:59 AM | #14 | |||
Rep 3,341
jimbethesda1856.00 |
