01-15-2024, 03:43 PM | #1 |
Rep 192
So many grills. Best G82 w/ACC no screws?
Can someone point me to the highest quality replacement grill (ABS or CF) for the G82 with ACC that doesn’t require screws or double sided tape? Am I right in understanding that’s typically the one piece replacements vs two?
There’s so many options it creates a bit of analysis paralysis, but when I find grills that are high quality they don’t seem to support ACC. I know the ACC sensor is ugly, but I’m stuck with it. Thank you! |
01-15-2024, 04:03 PM | #2 |
Rep 1,929
Yup that would be the one piece grill that you want, snaps right in like the stock one. The two piece ones need tape or screws.
https://autotecknic.com/products/aut...-m3-g82-g83-m4 https://autotecknic.com/products/aut...-m3-g82-g83-m4 https://nwcarbonhaus.com/shop/p/g8xcslgrill
adam12hicks250.50 |
01-15-2024, 04:08 PM | #3 | |
Rep 192
01-15-2024, 08:18 PM | #4 | |
Rep 726
Do note that even though it doesn't need screws or double sided tape, you'll either need to trim or remove the forward foam bumper to get it to fit (it sits more recessed than OEM or others), and it doesn't fit the full comp badge.
01-15-2024, 08:20 PM | #5 | |
Rep 192
m4ml1834.00 |
01-15-2024, 10:50 PM | #6 |
Rep 1,393
I just got my 2 piece CF Vorsteiner grille. Wasn't aware of the installation nuances between 2 piece and 1 piece. Whatever though, a shop is going to do the install so I don't care. Just wanted the best possible grille I could think of.
01-15-2024, 10:51 PM | #7 |
Rep 192
What makes you believe it’s the best?
01-15-2024, 10:52 PM | #8 |
Rep 1,393
01-20-2024, 09:42 PM | #9 |
Rep 168
heres what i got https://vinyl-designs-2-1515.myshopi...-g83-bmw-m3-m4
got bought with and without ACC |
adam12hicks250.50 |
