01-13-2024, 09:06 PM | #1 |
Rep 80
Drives: 2021 M340ix
Wrench size needed for bolts under front lip?
I am flying from MN to MA to pick up my new M4 in a few weeks and plan on installing a StoNSho license plate bracket before I leave. The instructions say to remove and replace the bolts under the front lip but do not mention a size and I don't want to bring my entire wrench set on the airplane, lol.
If anyone can tell me what wrench size I will need for these bolts I would greatly appreciate it! |
01-14-2024, 12:46 PM | #5 |
Rep 2,606
Yeah you don't need to worry about a front plate with a temp tag.
01-14-2024, 02:47 PM | #6 |
Rep 80
Drives: 2021 M340ix
Massachusetts does not provide temp tags for out of state buyers. I have to wait for my actual plates to arrive before I can pick it up. Otherwise I would have driven it home the same day I traded my car in.
01-14-2024, 02:56 PM | #7 |
Rep 80
Drives: 2021 M340ix
01-15-2024, 08:00 AM | #8 | |
Not my first rodeo
808
Rep 481
When I initially mounted it to the stock bumper I just reused the 10mm bolts. |
01-22-2024, 06:49 AM | #10 |
Not my first rodeo
808
Rep 481
01-22-2024, 02:46 PM | #12 |
Not my first rodeo
808
Rep 481
If you are simply installing this on a stock bumper, you just unscrew the two 10 mm head screws, and then use them to hold this bracket on. It is absolutely the most simple DIY possible. On my car, I added the M performance style lip, and this changes things a bit. I ended up using some different screws that were roughly an inch in a quarter longer and they had to put spacers between the lip and the stock bumper to keep things straight.
01-22-2024, 09:06 PM | #13 | |
Rep 605
NicolasB808.00 |
01-22-2024, 09:21 PM | #14 |
Not my first rodeo
808
Rep 481
Yeah, it's the best solution for this situation that is removable. I have only driven with it once because I was crossing the border into Canada and didn't want Customs messing with me on the way back.
01-23-2024, 06:47 AM | #15 |
Rep 605
