      12-08-2021, 03:51 PM   #23
nearwater4me
Drives: '22 G82 Base
Originally Posted by mike@x-ph.com View Post
nothing has been updated yet, once the update is released, you will be able to adjust the front to go lower
Originally Posted by r33_RGSport View Post
No details yet.
I am currently waiting for them to be shipped over so I can test it.
This is good news because most of the members with MSS wasn't too happy with the moderate drop in the front.
I wonder if this involves a revised rubber seat or a new spring all together, or even both.
r33_RGSport12972.00
      12-08-2021, 03:57 PM   #24
mike@x-ph.com
mike@x-ph.com's Avatar
There is definitely more room in the front.
MSS invited us a few weeks , Ben was there too. They did an install on the M3 and took all our feedback.
That's when they told us, they will be sending new kits free of cost and will be sending tester kits to dealers who have the kit
i personally like it for a daily driver, i don't want the drop to be too aggressive but i agree that there should be at least the option for customers to lower it even more
https://x-ph.com/sale/
Phone number 702-494-9435
r33_RGSport12972.00
      12-09-2021, 03:56 PM   #25
nearwater4me
Thank you for the information.
Looking forward to the release of the update kit.
      12-09-2021, 06:08 PM   #26
iviegatron
iviegatron's Avatar
Drives: G80 M3
Do I need a lift to install the kit or can I install it on jack stands?
      12-09-2021, 08:37 PM   #27
mattssi
Drives: 2019 X3
Jack stands will work. A little tough to get leverage for the rear, but doable. I tightened up the rear camber bolts as much as I could and let the alignment shop spec it up.
2021 ///M3
2019 X3
      12-10-2021, 09:14 AM   #28
mike@x-ph.com
Originally Posted by mattssi View Post
Jack stands will work. A little tough to get leverage for the rear, but doable. I tighted up the rear camber bolts as much as I could and let the alignment shop spec it up.
+1
      12-10-2021, 12:24 PM   #29
McLaren720s
McLaren720s's Avatar
Drives: 2024 M4 Competition X
Looking forward to the free update lowering kit as I'm very happy with these springs on both street and track, but I'd really like the front another 5mm lower.
      12-10-2021, 12:53 PM   #30
mike@x-ph.com
Do you have it on your car?
      12-10-2021, 01:40 PM   #31
McLaren720s
Yes
      12-10-2021, 03:47 PM   #32
mike@x-ph.com
Yes
I removed the lower adjuster from the front, It lowered it a little bit more.
      12-10-2021, 04:48 PM   #33
McLaren720s
Yes
Do you have a picture for the lower adjuster? I had a shop put in on for me 3 months ago so I don't really remember.
I'm transferring this to my incoming XDrive in March so I'd like to know what to tell the shop then
      12-11-2021, 10:13 AM   #34
mike@x-ph.com
its 2 pieces, i removed the lower one
      12-11-2021, 01:45 PM   #35
mzcp
Drives: BMW M
Attachment 2763085
Mike did you cut the front OEM bumpstops for your install?
      12-11-2021, 02:49 PM   #36
mike@x-ph.com
I did not , I asked the MSS guys about it and they said that if I want the car lower, I should just wait for the new kit.
After I removed the adjuster, it's enough for a daily driver. But I'll try the new kit since its free
mzcp2690.50
      12-11-2021, 03:00 PM   #37
mzcp
Drives: BMW M
I could have sworn from your video that the OEM bumpstop were reinstalled. Thanks
      12-11-2021, 04:48 PM   #38
mike@x-ph.com
you asked if i cut them not if i reinstalled them
      12-11-2021, 04:55 PM   #39
mzcp
Drives: BMW M
Yes to cut. Thanks
      12-13-2021, 02:51 PM   #40
nearwater4me
What was the reason behind the decision to reuse the OEM bump stops vs. the MSS ones?
      12-13-2021, 03:06 PM   #41
mike@x-ph.com
If i remember correctly, MSS kit does not come with new bumpstops.
It's been a while so i might be wrong, I'll have to re-check
      12-15-2021, 08:02 PM   #42
spridge
spridge's Avatar
Drives: 2021 M3 Comp
Fwiw- the MSS kit does come with replacement bump stops.
r33_RGSport12972.00
      12-15-2021, 08:10 PM   #43
mike@x-ph.com
if that's the case then I definitely used them.
I remember using everything that came with it
