03-21-2023, 03:01 PM | #1 |
Rep 299
automatic door button inside
New i7 - button inside to auto open front passenger door won’t work any more. It won’t even illuminate. (This is the button built in to the diamondy light bar across front of car, closest to front passenger side).
My bmw assistant verbal commands still work to open and close the door. Door also opens when using the outside button. Just not the inside button. Anyone have this issue? I tried ‘resetting’ the car by holding down the music volume button for 30 seconds, system reset, but that didn’t seem to fix the button not working.
2022 M760i - Black
2021 M8 Competition - Frozen Grey |
03-21-2023, 04:27 PM | #2 | |
Rep 1,618
Drives: '23 760ix; '23 X3; '23 MB wgn
BMWCCA
Current: 23 760ix (Carbon Black/Tartufo) (after first one totaled) '23 X3; '23 MB E Wagon Prior: BMWs (3,5,7 & 8 series (2x!)) X3, MB (C, E, and S), Alfa GTV, MGB, Audi (A4, A6), Saab, Volvo, Toyota, Lincoln, Chrysler, Oldsmobile, Chevy, Rambler. |
jwestfield379.00 |
03-21-2023, 04:56 PM | #3 |
Rep 455
Yep, have the exact same issue + the vent control slider is dead too on that side. I took mine to the dealer and they ordered the part. No clue when it’s coming in though.
jwestfield379.00 |
03-22-2023, 05:01 AM | #5 |
Rep 299
That’s exactly same with me. What part did they order?
2022 M760i - Black
03-26-2023, 04:52 PM | #6 | |
Rep 46
jwestfield379.00 |
03-28-2023, 08:36 AM | #7 |
Rep 289
03-28-2023, 09:43 AM | #8 |
Rep 1,618
Having done this a few times, you do not need to time the 70 seconds with a stopwatch -- other than to make sure it is at least 70 seconds.
BMWCCA
03-28-2023, 11:18 AM | #9 | |
Rep 302
when resetting: do you lose settings or is it a lossless reset? |
03-28-2023, 11:47 AM | #10 | |
Rep 46
I must also say that whilst my i7 is great car to drive; in terms of quality and all these annoying defects, BMW has really disappointed me. It seems that they have really taken their eye off the ball and have rushed through with building these i7s without paying attention to quality and reliability. In relation to your reset query, no, it does not erase your settings. It is just like a Windows restart. |
03-28-2023, 12:58 PM | #11 |
Rep 1,618
My issues requiring reset were setting up the esim. Nothing major.
BMWCCA
03-30-2023, 09:58 AM | #12 |
Rep 37
Now I am having the same problem with the inside button for the automatic door. First wind noise and this!!
Never ending problems. |
jwestfield379.00 |
04-02-2023, 12:38 PM | #13 |
Rep 289
Yes, I agree. I think the 70 seconds is needed for it to turn back on the second time. For me, it happens at about 68 seconds on my car every time.
04-03-2023, 11:06 PM | #14 | |
Rep 2
04-04-2023, 07:19 AM | #15 | |
Rep 46
WARNING
NO NO NO!!! DO NOT try this on the i7. On the i7 the 12v battery is connected to the car's High Voltage battery. Therefore, in order to do a full battery reset, you MUST first disengage the High Voltage battery and allow it to drain. If you fail to do this, you are exposing yourself to a really dangerous situation and could also potentially seriously damage your car. It is therefore certainly not as easy as "disconnecting the negative battery terminal" on the 12v battery. The whole process, if done properly will take about 45mins to an hour. It will also most likely simply mask the cause of the issue rather than to fix it permanently. It would therefore be best to simply book the car in for a full software update as this will ensure that all the software patches are up to date. Most likely such an update will fix the issue. I am going to have this booked to be done on my i7 within next 4/5 weeks and will update you accordingly- unless someone else gets to have theirs updated quicker than me!!!! |
04-04-2023, 09:34 PM | #16 |
Rep 455
04-05-2023, 11:51 PM | #17 |
Rep 46
No parts may be required. They just need to do a full and clean software update for you first. Depending on the number of updates required based on when your car left the factory when it was built, it will take between 40 to 90 mins to do this.
04-06-2023, 09:40 PM | #18 |
Rep 455
Really? A reinstall of the existing version or is a specific version required that fixes this particular problem? When mine was at the dealer about a month ago they told me that there wasn’t a newer version than 2022.11 available.
04-07-2023, 11:18 PM | #20 |
Rep 455
04-08-2023, 09:03 AM | #21 |
Rep 299
Mine is in shop now. They are trying software reset first. If not, they will replace light bar
2022 M760i - Black
04-08-2023, 09:23 PM | #22 |
Rep 299
They have to order new light bar. One month
2022 M760i - Black
