      02-24-2024, 08:34 PM   #1
Malloy
Malloy's Avatar
988
Drives: '05 M3 | 6MT | Slicktop
20x10.5 et15 - 285/30/20 on front?
I promise I searched before posting.
20x10.5 et15
285/30/20 Michelin Sport 4S (or similar)
Does anyone run this up front? Do you have any rubbing issues any where?
Thanks!
M3SQRD2164.00
      02-24-2024, 09:19 PM   #2
Tobster3
Tobster3's Avatar
634
Drives: 2024 M3 6MT
I run up Front - 10.5 ET14 285/30/20 with PS4S, lowered on Eibach (which is minimal). No rubbing.
I installed 10mm Spacers today and have very slight rubbing on full lock reversing.
Malloy988.00
      02-24-2024, 09:47 PM   #3
Nicklv_m3
Nicklv_m3's Avatar
196
Drives: 22' M3 Comp, 21' X3 M40i
I know the wheels aren't as wide but I run 20x10 ET10 in the front with a 285/30/20 PS4s and zero rub. I did cut out a middle fender plastic piece on the vents (only one) and now there is zero rub at full turn in reverse only.
No rub any other way.
IG: @nicklv_m3h
Malloy988.00
      02-25-2024, 10:50 AM   #4
M3SQRD
M3SQRD's Avatar
2164
Drives: E92 M3,G20 330ix,F22 240iX,F82
Your 10et10 has a ~0.09” less aggressive frontspacing than a 10.5et14 but the backspacing is ~0.40” worse for the 10.5et14. So outer wheel clearance is very representative of a 10.5et14 but a big difference on inner wheel clearances.
      02-25-2024, 10:55 AM   #5
Malloy
Malloy's Avatar
988
Thanks for the replies so far!
