02-20-2024, 09:39 PM | #1 |
Rep 83
G80 + 15mm Spacer plus 295/30/20 PS4S, fits?
Got rwd g80, due for new rear tires, thinking going size up 295, seen G82 guys fitting it on stock height how about G80? Stock height and 15mm spacers. No rub at full compression? Often have people in the back seats and trunk full of luggage. Thank you!
02-21-2024, 02:49 PM | #3 |
Rep 83
02-21-2024, 03:22 PM | #4 |
Rep 6,962
The BMW Star tires are made are comprised of half PS4S and half Sport Cup 2. You may be giving up some performance, going to an off the shelf PS4S. BMW only makes the Star tires in the stock BMW sizes, 275/19 and 285/20. Just thought I would throw that out there.
YT: G Dubyou |
02-21-2024, 03:51 PM | #5 | |
Rep 1,929
Found a post on facebook with a guy running 295/30/20 with 15mm spacer, about as flush as can be it seems. He has kw has and says no rubbing. https://www.facebook.com/groups/2066...4662660295434/ For some reason the other "Official BMW G80/G82 M3/M4 Discussion & Marketplace" group is blocked here :\
mattg80m3116.00 |
02-21-2024, 06:11 PM | #6 |
Riding the knock sensor
2371
Rep 1,591
Drives: 21 X5MC | 23 M4CSL
I guarantee that Facebook car will rub with rear passengers and full luggage over a highway swell. No one mentions camber, which is sort of funny, just a small difference (say -1.5 vs -1.7 degrees) can mean the difference between rubbing or not. OP, not sure what the fixation is on 15mm spacers, but 295 rear is an obvious upfit on these cars. I wouldn't make a tire size decision based on a fixed spacer size - just get the tires and go from there. Unless you're moved by the star spec argument above, which is valid but marginal. I think youll find 10mm spacer is a better choice for your load requirment but that's based on me trying about every combination of spacer with 295 and 305 PSC2 but on a G82 with -2 degrees of rear camber.
mattg80m3116.00 |
02-21-2024, 06:26 PM | #7 | |
Rep 83
02-21-2024, 06:27 PM | #8 | |
Rep 83
02-21-2024, 07:38 PM | #9 |
Rep 2,372
I have 295 30 r20 PS4'S tires and have BC Forged +12 offset which is the equivalent to a 13mm spacer and eibach springs all around. I drove my car to Nags Head Nc with my wife and I and luggage. It rubbed once going over a bridge joint but the car wasn't lined up at that time. Now the car is lined up and I have it dialed in with a little less camber to reduce wear on tires .
Formerly Wyndi335I
mattg80m3116.00 |
02-22-2024, 06:24 PM | #10 | |
Rep 83
JDUNITNOW3516.00 |
02-25-2024, 01:02 PM | #11 |
Rep 6,962
315s.
YT: G Dubyou |
