01-23-2024, 09:23 AM | #1 |
Rep 107
Wheel Adapter help
Hey guys,
I would like to see if you guys could help me out with my measurements. In another post a user suggested using wheel adapters to fit my mustangs wheels to my BMW M4 without Xdrive;I would like a flush fitment. Car has KW HAS The Specs -The adapter would be 5x112 to 5x114.3 -The wheels in question are velgen forged SL7's -Fronts are 20x9.5 ET 30 275/35 -Rears are 20x11 ET 50 305/30 -With a 20mm adapter in the front this would give me ET 10 -With a 35mm adapter in the rear this would give me ET 15 -according to online calculators both should clear brakes and suspension My questions -would these new offsets be flush for my vehicle? -Is there any possibility of needing to shave off my studs? My wheels have pockets in the rear. -The center bore of the mustang was 70.3mm the g82 is 66.5mm does this matter? -Am I missing anything important? Thanks for any and all help guys! Sorry for my lack of knowledge. This would be my first time using wheel adapters. Here is the link to the thread in reference: https://g80.bimmerpost.com/forums/sh...hlight=redrill |
01-23-2024, 11:42 AM | #2 | |
Rep 1,929
You might need to trim your studs, just figure out how much they stick out from the hub and see if the pockets in the wheels are deep enough with the 20mm adapters. No idea if they'll sit flush, that you have to figure out yourself.
GabesSlowM4185.50 |
02-01-2024, 10:23 AM | #3 | |
Rep 107
In case you wanted to know the specs; -Fronts will be using a 22mm adapter for ET8 fitment -Rears will be using 36mm adapter for ET14 fitment The wheels I will be mounting are: -20x9.5 ET30 (CB70.6) -20x11 ET50 (CB70.6) Bronson investments will be making the custom adapters with conical style bolts. Accelerated Motion on youtube has been very helpful as have you sir!! Thank you! |
thompsac25708.00 |
02-01-2024, 12:39 PM | #4 |
Rep 1,929
Post a Pic of the back of the wheel, odds are he pockets are big enough so you don't have to worry about that.
GabesSlowM4185.50 |
02-01-2024, 12:42 PM | #5 |
Rep 107
Here they are!
02-01-2024, 02:55 PM | #6 |
Rep 1,929
You should be good, plenty of clearance.
GabesSlowM4185.50 |
