Classifieds Sponsors Classifieds Suspension / Brakes / Chassis / Spacers
      05-03-2023, 05:41 PM   #1
IND-Distribution
IND-Distribution's Avatar
9588
Drives: G82 M4 / G87 M2
IND | Goodridge G8X M2 / M3 / M4 Stainless Steel Brake Line Set
In the world of professional motorsports, you can never cut corners when it comes to high quality braking. For the best part possible, Goodridge has supplied the Stainless Steel Brake Line Set. Goodridge brake hoses increase braking efficiency and remove the "spongy" feel under arduous conditions. With an unmatched reputation backed by champions worldwide, there is no reason to choose anyone else.
Goodridge G-Stop High Performance Brake Line Kits are direct bolt-on replacements for all of the rubber brake lines in the vehicle's brake system. To ensure proper fit and easy installation, hose ends and brake line brackets that match the vehicle's original equipment style are used for each application.
By conforming to all requirements of the Federal Motor Vehicle Safety Standard Number 106, Goodridge G-Stop High Performance Brakelines are US Department of Transportation Certified and T.U.V approved. All Goodridge G-Stop High Performance Brakelines go through a 9-point Quality Assurance testing process that includes measuring tensile strength and the ability to contain line pressure to 3,000 pounds per square inch.
Product Details:
  • Fits: All G8X M2 / M3 / M4
  • Quality stainless steel line with PTFE inner liner
  • Abrasion and corrosion resistant with long term durability
  • Direct replacement of OEM brake lines
  • Hose ends and brackets match OEM for easy installation
  • US DOT and T.U.V approved
  • Eliminates "spongy" brake pedal feel
The Goodridge G8X M2 / M3 / M4 Stainless Steel Brake Line Set may be viewed at the following link to our online store:
https://ind-distribution.com/product...brake-line-set
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
