04-09-2024, 09:59 PM | #1 |
Rep 631
RaceChip GTS vs JB4
I know that JB4 is the objectively more powerful option when you incorporate custom tunes and ethanol, but for a (reliable) moderate power bump, which product does the job better?
Being a former JB4 owner on another car, I know how it works and how there are all sorts of extra sensors that it taps into and how you can log the car to make sure its running good. That's the main argument JB4 guys use against the RaceChip. I'm thinking that you can also log the RaceChip by using Bimmerlink and can confirm if the map is running good on your car. I live in ACN so I'll primarily be running pump 91 from Chevron/Shell/76 and might sometimes throw in 2-3 gallons of E85 to bring it roughly to E30 so I can run Map 7 on the RaceChip or Map 5 on the JB4. I didn't have an overall great experience with JB4 on my old car so that's why I'm leaning more towards RaceChip, but I want to hear opinions from all across the board to make the best informed purchase. Thanks
Current: 2024 G87 M2 (ZF8)
Past: 2022 330i RWD 2020 M2 Competition DCT |
04-10-2024, 10:50 AM | #2 |
Joint Chiefs of Staff
24477
Rep 191,448
The result is the same for a stock car with 91 octane. They both add a boost to increase power and the amount of PSI is similar in both options.
when using E85, the JB4 will make more power You will lose out on the extra JB4 features, but you already know and are okay with it.
04-10-2024, 08:44 PM | #3 | |
Rep 631
r33_RGSport13108.50 |
04-11-2024, 10:55 AM | #4 | |
24477
Rep 191,448
I recommend keeping it on the default map as you mentioned, since you cannot datalog when you are going over default you can never be sure that the car is handling the extra boost well.
04-11-2024, 03:18 PM | #5 | |
Rep 1,243
I had the JB4 tuning box for my 2019 M240i and I thought it did well. And the burger tuning guys were all very helpful when I had questions. I ultimately switched to MHD, mostly because my DME was unlocked so why not flash tune instead. I like you am debating between the Racechip and the Jb4. I'm leaning towards Jb4 because of more flexibility and the ease of data logging.
2024 M2
2019 M240i- Sold |
04-11-2024, 09:27 PM | #6 |
Rep 90
How much of a HP bump does the default map make? Is the +90 hp/tq from map 7?
04-12-2024, 11:14 AM | #7 |
Rep 53
Yea I’d love an explanation on this… is that 90hp 90 torque on the default map 5 or map 7 or what??? I have ran my on map 7 since I had installed it and the only way I’ve confirmed that it’s putting more power down is with the cars g meter on a 3rd gear pull but I have no clue how much each map is adding.
04-12-2024, 11:26 AM | #8 | ||
24477
Rep 191,448
04-12-2024, 01:23 PM | #9 |
Rep 90
04-12-2024, 05:46 PM | #10 |
Rep 946
@mike@x-ph.com - any thoughts on high altitude running 91 octane? As-in front range CO? I had a JB4 on my 135i and ran into some stuttering and some issues on occasion. I did work with JB4 support and did a lot of logs stuff but still would get some stuttering on occasion. Or was it a JB3? What was out circa 2010?
///M
04-12-2024, 07:21 PM | #12 |
Rep 3,071
04-12-2024, 07:28 PM | #13 |
Rep 1,150
I knew you’d be watching.
Honestly, I’m just trying to add a little juice without going full tilt. Anyway, I’ve seen the videos on YouTube and read the chatter here but really don’t want to do this myself; 2.5 hours seems excessive. Solving differential equations is easy for me, mechanical work OTOH is basically Greek. |
04-12-2024, 07:41 PM | #14 | |
Rep 3,071
I hear ya. Many years ago I used to build my cars but that was old school American muscle cars with Holley 750 DPs. Most electronic parts was an MSD ignition. It was all mechanical, adjusting my roller rockers with feeler gauges. Now, with these cars, I am paying my friend's shop to do the work. |
04-12-2024, 07:57 PM | #15 | |
Rep 1,150
Funny story- when we bought our first F22 a few years back I spent a good 30 minutes looking for the dipstick. Duh… |
DrewNewM2419.50 |
04-12-2024, 08:51 PM | #16 |
Rep 280
I spent about 45 minutes installing mine. Most of it was spent finding a clever way to route the lengthy cables and getting that lower connector off.
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Nankang CR-S, Adro wing, IRL exhaust, Racechip, Mishi Skidplate, KG Splitter; IG:g87_43 |
Carefree1769.00 |
04-13-2024, 11:37 AM | #17 | |
24477
Rep 191,448
default map on the jb4 is map 1
default map on the racechip is map 5 Quote:
04-15-2024, 10:34 AM | #18 |
Rep 1,243
I installed the Jb4 on my previous F22 in about an hour after watching some Youtube videos. Installs there after (when I would remove it for dealer service visits) it was about a 15 to 20 minute process. 2.5 hours labor isn't a crazy unreasonable quote. Just gotta decide either figure out yourself or with a helper, or pay what $400 bucks for install?
2024 M2
2019 M240i- Sold |
04-16-2024, 10:27 AM | #19 | |
24477
Rep 191,448
Inexperienced JB4 installers will overcharge because they are worried that since it's an aftermarket part, there will be some issues with the installation. The jb4 installation will not take 2.5 hours. I recommend telling the mechanic that you will pay precisely how long it takes them to install it, which will end up half that time, even if it's their first installation.
