03-04-2023, 09:26 AM | #1 |
2024 M440i GC (G26)
279
Rep 511
19" wheel square setup
Is it possible to order 4 front wheels for the G80/82 for a square setup? I purchased two 826M fronts in black and need two more rims to complete a set. I'd prefer an all-season 19" square setup, so need to order 2 more 19" rims. Anyone done this? Thanks.
Note: My limited online research seems to show this will work. The front and rear both have the same offset, and the 82x wheels on the G80 all show 19x9.5 fronts. Thanks. |
03-04-2023, 09:32 AM | #2 |
Rep 2,700
Yep, you pretty much found the answer, since the offset is the same there is no problem, the rear wheel will be a bit more tucked in appearance wise.
03-04-2023, 10:03 AM | #4 | |
Rep 2,700
https://www.willtheyfit.com/
diablo2112278.50 |
03-04-2023, 03:05 PM | #5 |
Rep 269
My winter set is 19x9.5 at all four corners. Tires are 275/35/19 all around.
No problems at all. The rears are tucked in a bit more, but I view this as an asset as it keeps more debris in the shell well as opposed to the quarter panel. |
diablo2112278.50 |
03-04-2023, 07:13 PM | #6 |
Master Chief
1190
Rep 938
For winter, I run square 19x9.5 ET22 with 10mm spacers. 275/35/19 all around.
diablo2112278.50 |
03-04-2023, 07:46 PM | #7 |
2024 M440i GC (G26)
279
Rep 511
biglilsteve1189.50 |
03-04-2023, 07:50 PM | #8 |
Master Chief
1190
Rep 938
