04-17-2023, 08:45 PM | #2 |
Mad Linux Guru On The Loose
1166
Rep 5,448
Drives: 2008 335i Sedan, 2023 M3
So let me get this straight... You have catless downpipes and stock software AND you are wondering why tge engine is throwing codes at you?...
Needsdecaf7893.50 |
04-17-2023, 09:00 PM | #4 |
1166
Rep 5,448
I am looking at the codes and my rhetorical question still stands. Let me give you another one: do you honestly believe that with catless downpipes you will only get 18001 and 180101 codes and nothing else? You are messing with the air to fuel ratio as the dme is struggling to adapt to the new readings from the 02 sensors and it us clearly failing. Your car is NOT running fine at all. Definitely not under load.
04-17-2023, 09:24 PM | #6 |
Rep 783
I tend to agree. Plenty of people running piggybacks like jb4 or race chip with catless downpipes and those are not really doing a whole lot besides raising/controlling the boost. Maybe car is over boosting, due to the lesser restriction allowing turbos to spool faster and the car isn't adapting to that yet? What are you reading codes with? Can you do some data logging to see what's going on when the codes are thrown? Also why not go ahead and at least get a jb4 so you can really take advantage of the bolt on parts?
04-17-2023, 09:28 PM | #7 | |
Rep 783
04-17-2023, 09:32 PM | #8 | |
Rep 391
04-17-2023, 09:47 PM | #9 |
Rep 783
Well fine, but you're not really going to be able to get much help without being willing to share more information or provide some logs of what's going on to provide context. Help us help you.
04-17-2023, 09:50 PM | #10 |
Rep 391
Whst do you mean? That’s literally all I have. I read codes with BimmerLink app, it’s just a code reader. Car is stock tune. There’s no mods Beside dp and exhausts..
04-17-2023, 10:03 PM | #12 |
Rep 783
That's a start... Did you get the super knock codes exactly once? Or have you cleared the codes and they come back multiple times? Did car go into limp mode when the codes popped? Did they happen immediately after installing down pipes or did you run the down pipes for a while without getting super knock codes? Context my man.
04-17-2023, 10:11 PM | #15 | |
Rep 391
04-17-2023, 10:20 PM | #16 |
Rep 514
04-17-2023, 10:35 PM | #18 | |
Rep 783
04-17-2023, 10:38 PM | #19 |
Rep 391
Yeah have a thought that it might be a bad batch of gas. I pumped it at another station that I don’t usually go to. I did several highway pulls 4k n up. Guess I’ll wait and see what’s up with it. Just funny that this code doesn’t throw it into limp mode
04-17-2023, 11:47 PM | #20 |
1166
Rep 5,448
04-18-2023, 07:27 AM | #21 |
Rep 196
I am going to say your cars fuel trims are most likely way off based on the catless DP's and no tune. These new DME's are no joke, every car is different as well. My car may run them fine while yours may not, but the readings from the o2 sensor may be triggering your DME to throw this code.
Possible fix/trick may be o2 spacers to trick them to think it has cats on it still. |
04-18-2023, 07:38 AM | #22 | |
Rep 783
I'm just genuinely interested to understand these things better for S58 since not many people here talk technical details, it all just exhaust and front lips.. lol. |
Igor_M52296.50 |
