06-13-2021, 11:30 AM | #23 | ||
Rep 191
06-13-2021, 11:33 AM | #24 |
Rep 191
Super weird the "part number" you claim on the invoice starts with G82 but then the part number off the H&R website just starts with a 286…something doesn't add up in your triple digit IQ logic, clown
06-13-2021, 11:35 AM | #25 | |
Rep 10,166
Here is the G82 part number, read very slowly again: https://www.hrsprings.com/applicatio...s/4/2414/2021/ .4 inches was on the G80 and 1.2 on the G82....thats .8 inches in variance or 20mm. Please Google how much 20mm is in inches There are people using G82 springs on G80 cars to get the larger drop. Of course something doesnt add up for you--- you shut down at 99 IQ. Clown hahahahhaa --- where is your car buddy- lets see those G82 springs and show me the part number since your invoice is showing G82 nomenclature.
06-13-2021, 11:41 AM | #26 | ||
Rep 191
Also no relevance to the "part number" you claimed had to be for a G82 because it happened to start with G82 |
06-13-2021, 11:48 AM | #27 | |
Rep 10,166
I have this G80 and clearly .4 wont cut it so Im going to use HAS springs as H&R has such a variation. Also I had an F90 M5 and used H&R and yep, their site said .4 inches and yep, it dropped it a paltry .4 inches:
06-13-2021, 12:01 PM | #28 | ||
Rep 191
Does the G80 have a shorter or softer spring than the G82 or are they the same? I doubt you know and neither do I at this point. However i'm going to assume using logic that the same springs are used on both cars, there is differing proportions as one a sedan and one is a coupe resulting in a minor difference in how weight is distributed and that is why there is a variance in the drop The whole point of this was that a different H&R spring could be fitted to achieve a better height rather than the 0.4" drop one you continuously post about. I'm genuinely unsure what you are trying to achieve. It is pretty simple for H&R to supply an alternate spring rate or length at a customers request, they are a suspension company after all |
06-13-2021, 12:04 PM | #29 |
Rep 191
Just to be clear, i'm not disputing the advertised kit exists that drops it .4 inches.
Just that an alternate H&R spring kit can be fitted to drop it further Your brain must have moved so fast you've over analysed the point of the actual post, see below image of you in this thread |
06-13-2021, 12:10 PM | #30 | |
Rep 10,166
Zero struggle, I sleep well at night--- please re read my posts again and again and again. My point which you need to get is that the actual G80 spring is going to have a lesser drop. I have already said over and over that one can use a different spring like a G82 to get a larger drop. Please provide me with the alternative spring that H&R will approve for the G80 or a universal fitment. Part number for G80 is 28616-1 Part number for G82 is 28616-2 I have used H&R for over 15 applications, these are two different part numbers where you might struggle to know the difference between 1 and 2... G80 says .4 inches drop in rear G82 says 1.2 inches drop in rear Whether or not its axle weight or whatever, the key is what is listed. Where is your car? Can you post the pre drop pics now and then post the part number (which is implanted on the spring) when you drop it and then post drop views for the members here. I think that would help the community. And maybe you should do more research since you know so much. This member actually spoke to H&R and they said 10mm which is .4 inches on the G80. Do you even own the damn car? https://g80.bimmerpost.com/forums/sh...19&postcount=1
06-13-2021, 12:23 PM | #31 | ||
Rep 191
I don't actually own the car just post here for lols to wind old senile men up and have never lowered anything in my life. |
06-13-2021, 12:29 PM | #32 |
Rep 191
The whole point of this post was to help people who wanted to get rid of the gap with the options available at the moment given the disappointing HAS heights.
Meanwhile you're having a 2 page aneurism going back and forward, after i've said a different rear spring can be fitted, you're telling me a different rear spring can be fitted… |
EMC22.50 |
06-13-2021, 12:29 PM | #33 | |
Rep 10,166
LOL. Lets see the car little pre pubescent man.
06-13-2021, 12:32 PM | #34 | ||
Rep 191
Meanwhile you're struggling to differentiate between 2 types of H&R springs like this |
EMC22.50 |
06-13-2021, 12:37 PM | #35 |
Rep 10,166
Lets see the car? So I can tell you what springs to get
06-13-2021, 12:41 PM | #36 |
Rep 191
I'm not sure i'd need advice from you, didn't you put 550i springs in an M5? I assume that would be worse than putting m4 springs in an M3.
06-13-2021, 12:44 PM | #37 | |
Rep 10,166
Ok that was funny... but please post the drop so we can review and see if H&R is worth it. For now Im going with KW. Sorry about the two page waste but hey, its free bumps
06-13-2021, 12:48 PM | #39 | ||
Rep 191
The KW pic was disappointing but I have been told they are revisiting to make it lower which is why it keeps getting pushed back, which is why i'm going the springs. The HAS seems to be 25-30mm front regardless of brand, and the rear only needs 20mm, if i'm just going to max out the HAS i can just go springs that achieve the same drop, like the blue car. Thats my thinking anyway |
06-13-2021, 12:53 PM | #40 | |
Rep 10,166
I think you may find that the H&R has basically lighter spring rates than KW and MSS (Eibach) which might not soak up the undulations and create that extra "bounce" which we all hate.
06-13-2021, 12:55 PM | #41 | ||
Rep 191
06-13-2021, 12:56 PM | #42 |
Rep 10,166
Tomorrow? And can you, for all of us, list the part number?
06-13-2021, 12:59 PM | #43 | |||
Rep 1,383
06-13-2021, 08:49 PM | #44 | |
Rep 679
LOL they are probably installing springs from another BMW. Do you think a shop called Stance Shop is going to get "unreleased" springs over all the other bigger accounts? Looking at the Stance Shops IG, they have been installing springs since April. I highly doubt they had access to a lot of R&D springs and were allowed to sell them. I want to see pics of the springs they installed, I can guarantee they weren't made for the G8X. They say they cant reveal information on their IG comments to people who have been asking what springs they used, gee I wonder why? Last edited by ///MeraldCity_G82; 06-13-2021 at 08:55 PM.. |
JTO245276.00 |
