04-09-2024, 05:25 AM | #1 |
Rep 33
Xdrive Square setup
Hi Guys,
I saw many post mentioning about square setup and talk about the variance for front and rear wheels from factory is 0.4% and if we are doing any wheel change or tyre change. As long as it stay within 1% the X drive should be fine..... well i still cannot figure out how to calculate the math. If i play to do square setup. 20x 10.5 front and back. with tyre size 285/30/20 front and back. Does it mean the variance will be 0% and i am safe, and i assume the offset does not affect the variance |
04-09-2024, 06:16 AM | #2 | |
Rep 274
Drives: 2023 M3 Comp
https://www.calculator.net/tire-size-calculator.html You will have rubbing in the front with this set up and severity of rubbing on the inner fender "fins" depends on your suspension set-up and spacer use. I currently run this setup on my car with 12mm front and 15mm rear spacers. The rubbing at full lock is not present after removing fins and replacing with wheel arch aluminum metal plate. Install here: https://g80.bimmerpost.com/forums/sh....php?t=2073263 Last edited by blackops23; 04-09-2024 at 06:21 AM.. Reason: link |
04-09-2024, 08:49 AM | #3 |
Rep 33
Oh Thank you so much for that calculator, i think that is what i need to bookmark. yea i know it will rub so if i do decide to go this setup, i will cut out those fin to avoid rubbing. Just find it super headache to run stagger width and deciding on the tyres. Its like a puzzle game haha
blackops23486.00 |
04-09-2024, 09:03 AM | #4 |
You got my money?
3168
Rep 4,652
Drives: Ice Cream Truck
Heres another offset and circumference calculator for wheels and tires.
https://www.willtheyfit.com/
Today, 03:09 PM | #5 |
Rep 509
We’ve done a lot of them with a 285-30 front and a 295-30 rear and have never had a hiccup with it at all. Dropping it to the 285-30 square will be no different you’ll be 10000% fine
Today, 04:14 PM | #6 |
Rep 44
Any modification needed on MPerformance HAS? I'm looking to do this is exact setup - 285/30 front and 295/30 rear.
Today, 04:20 PM | #7 |
Rep 509
You might need to push in the vent up front on the fender liner with a heat gun or buy liner replacement if it really bothers you but you might get a very very minor rub on full lock turn reverse. It rubs out eventually we usually heat gun it and push it in.
