05-21-2023, 09:14 PM | #45 | |
Rep 97
05-21-2023, 09:22 PM | #47 |
Rep 21
rideawayclean106.50 |
05-22-2023, 01:01 PM | #49 |
Rep 1,682
05-22-2023, 01:02 PM | #50 |
Rep 21
rideawayclean106.50 bwoodahl235.00 |
06-13-2023, 11:53 PM | #51 |
Rep 513
06-13-2023, 11:55 PM | #52 |
Rep 21
No. I didn't call BMW for that.
"Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Spoilers and body kits are how much of the wall you take with you. Roll cages and window nets are how much of a mess you leave on the wall."
qballis270.00 |
11-26-2023, 11:27 AM | #53 |
Rep 192
Can anyone confirm 33-50-2-414-216 is the correct part number? Is this the kit / best price? Searching for the parts yields a surprising variety of pricing.
https://www.genuinebmwminiparts.com/...SABEgIUePD_BwE Thank you! |
11-26-2023, 03:21 PM | #55 |
Rep 1,661
I’ve read the max drop is 20mm and the port/BMW sets it at a 10mm drop.
18' F80 6MT, 991.1s cab PDK, F83 6mt, 996 C4S cab 6mt, F30 328iM 6mt
E60 M5 SMG, E39 M5, E46 M3 cab 6mt, E36 M3 5mt |
11-26-2023, 05:01 PM | #56 |
Rep 990
11-26-2023, 05:25 PM | #57 |
Rep 1,661
My car is in transit so I don’t know yet. I believe the ride quality is fine. You can lower it up to 20mm. For the reasons already said, I think it’s worth it. Especially considering the stock wheel gap. Equivalent HAS would be less than $2800 for sure and you could do just front springs for really cheap, but I wasn’t keen on those options. I’ve also read the port mechanics do high quality work.
AP's G8067.50 |
11-26-2023, 06:55 PM | #58 | |
Rep 990
11-27-2023, 09:31 AM | #59 |
Rep 360
Adding it to my build. Is it better to add while still in production or once it’s on the boat? Lol wondering if it’s installed before it leaves is quicker than having it done once it arrives
Current:
Past: - 2023 Brooklyn Grey G80 comp xDrive - 2020 Mineral White M340xi - 2017 Mineral Grey F80 ZCP |
11-27-2023, 09:42 AM | #60 |
Rep 5,113
It's only done stateside at the port of arrival at the VPC (vehicle prep center). Add it ASAP to make sure it's on there.
carswithdonuts435.50 |
11-27-2023, 11:30 AM | #61 |
Rep 1,661
Fugly M3 have you been pretty happy with your MHAS? Any issues with ride quality, performance, scraping?
11-27-2023, 07:10 PM | #62 |
Rep 5,113
I've had no real issues. Occasionally there's a faint rub at a speed bump between the axles. I avoid steep drives and most bumps though. If you're not willing to do that, you will likely have issues.
11-27-2023, 07:15 PM | #63 | |
Rep 1,661
11-27-2023, 07:17 PM | #64 |
Rep 5,113
It's at whatever the factory specs are. I was told 20mm rear and 10 front. I have no idea what it is. Handling and ride are fine - I leave it in comfort for the suspension, even if the throttle and transmission are jacked all the way up.
Adcampo883.50 |
11-28-2023, 07:50 AM | #65 |
Rep 177
Personally I would get it done at the port and knowing it was done correctly and covered by warranty is worth the 500 odd bucks you could save. Just my two cents. Plus that way when you pick up all you have to do is enjoy the car. Also it being residualized or financed is a plus.
Adcampo883.50 |
11-28-2023, 09:40 AM | #66 | |
Rep 5,113
Adcampo883.50 |
