07-04-2022, 03:23 PM | #23 |
Riding the knock sensor
2371
Rep 1,591
Drives: 21 X5MC | 23 M4CSL
I spent more time reading all the methods people have suggested and their woes than it took to replace the rears.
As mentioned above, service mode is slick. Once activated (BimmerLink) the calipers behave like a mechanical non-threaded piston. I use a large c-clamp but pry method works with very little force. The other tip, is to use a thin 17mm box (spanner) wrench to hold the pin so that the bolt can be removed (13mm socket). I hate the idea of using vice grips. I have a thin 17mm wrench from an old German car toolkit (I think from a GTI) but you should be able to find one on Amazon. I would grind down an old wrench before use pliers/vice grips but I have thing about teeth marks.
02-25-2023, 11:27 AM | #24 |
Rep 106
Drives: 2023 M3 Comp X-drive
Snap ring pliers also work to screw the piston back in a bit.
03-08-2023, 12:10 PM | #27 | |
Rep 158
03-11-2023, 12:03 PM | #28 |
Rep 328
ProTool has a very useful feature to put the rear brakes in service mode for pad swap out. No more dicking around with taking the top of the parking brake motor off to retract the rear pads.
https://g80.bimmerpost.com/forums/at...1&d=1678557636
2023 M4 Comp
Dravit Grey Metallic |
fanofbmwe462072.00 Kaiz3n0.00 |
03-11-2023, 02:02 PM | #29 |
2024 M440i GC (G26)
279
Rep 511
I just replaced the rear pads on my G80. A couple of tips.
Bimmerlink is great for retracting the parking brake servo. Highly recommended for this use. The 17mm wrench needs to be pretty thin. I have a large selection of wrenchs, and had one thin enough. Nearly all my standard Craftsmen wrenches were too-thick. The brake pad wear sensor is only on the passenger side. It’s a bit fragile and wires short, and if you forget to take it out, you can break off the sensor wires (ask me how I know). In my case, I just soldered the wires together and zip tied it to the bracket. This threw a code which you can clear with Bimmerlink. Finally, you can ONLY clear brake pad wear sensor messages (either with Bimmerlink or the onboard diagnostic menu) if the parking brake is off (again, ask me how I learned this.) I used EBC Red pads. They generated quite a bit of dust until they were bedded in. Excessive brake dust is still one of my biggest complaints about all BMWs. I end up changing pads on every BMW I buy. |
03-11-2023, 02:04 PM | #30 | |
Rep 158
Anderson11458.00 |
03-13-2023, 07:21 PM | #31 |
Rep 200
I’ve used both BimmerLink and the 9v battery method (mainly because I didn’t believe it could be that easy and cheap). They both work, and neither method results in codes or dash lights.
LuckyBrand1321.50 Kaiz3n0.00 |
04-26-2023, 09:52 PM | #32 | |
Rep 32
Kaiz3n0.00 |
