      10-25-2020, 07:28 PM   #1
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Does it matter to you if the oil BMW recommends is not your preferred brand?
I know talking oil is akin to talking politics but I'm just curious if it matters for our more enthusiastic BMW fans.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      10-25-2020, 07:42 PM   #2
dmikhael619
Drives: e92 ST 335, e46 m3, e39 m5
For what it's worth i work at a mercedes dealer and use the Mobile one that gets put in all of our cars in my M and everything runs great and my Blackstone oil analysis looks great so IMHO it doesn't matter just get a quality oil. Also im running 5w40
      10-25-2020, 08:25 PM   #3
GuidoK
#buildnotbought
GuidoK's Avatar
10855
Drives: Z4 3.0i ESS TS2+
Also in your s54?
Ever done a rodbearing swap on that engine?
      10-26-2020, 01:59 AM   #4
dmikhael619
Originally Posted by GuidoK View Post
Also in your s54?
No im not running it my s54 just because it needs 10w 60. Have not done rod bearings yet but It is a 2005 with 30k and had the vamps redone so its probably not going to get rod bearings for a while. My 335i did get the mobile 1. Also running it in a Bentley flying spur no issues
      10-26-2020, 02:14 AM   #5
Tambohamilton
Drives: E91 330d
No, it doesn't matter in the slightest what logo is on the oil jug/bottle. What matters is what the oil is/what's in it.
Chapperss492.00
      10-26-2020, 03:29 AM   #6
GuidoK
#buildnotbought
GuidoK's Avatar
10855
Yes ok that was not clear to me.
The clearing on the rodbearings in the s54 is also bigger than on most bmw engines, so going with a thinner oil (especially in warmer areas) can be a serious risk
      10-26-2020, 04:37 AM   #7
Chapperss
I only ride park
492
Drives: e93 335i Msport FBO 2+
I`d go with this - buy quality and everything will be fine.
Personally have no issue buying the recommended oil/brand but, my knowledge of the business world tells me that, the brand recommendation will be part of a mutually beneficial deal between those two companies and not that that oil is leagues ahead of the competition.
      10-26-2020, 07:39 AM   #8
CTSean
Drives: LCI BSM MT M2
This right here.
When was the time anyone saw someone come of a message forums and complain "I used the right spec oil, changed it at correct intervals, and the oil ruined my engine"
I'll wager this has never actually happened. Buy good oil with the right specs, change it regularly, and the rest of the car will fall apart around a well lubricated engine.
F32Fleet3571.50
paquet629.50
      10-26-2020, 08:09 AM   #9
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Ya I'm on board with that 100% but IMO Shell (and M1) offer a better product but perhaps that's because I remember the days when dealer Castrol used to turn the internals a reddish hue.
      10-26-2020, 10:15 AM   #10
Tambohamilton
Drives: E91 330d
Oil performance really is a long, deep rabbit hole. Unless you really want to get technical on it, or your engine is operating significantly outside its design parameters (heavily tuned/modified), just find an oil which is certified for your engine (eg LL-01 or LL-04 ,etc) and carry on. That's not to say that non-certified oils couldn't be better; it's just an easy way to be sure that the oil you choose will be good enough to keep your engine running properly for a long time. Don't cheap out, but also don't over-think it.
ga9213364.50
heavyD^23688.50
jjasonSU194.00
      10-26-2020, 12:50 PM   #11
pz619
Drives: F87 M2C 6MT, Tesla 3
As long as the oil it quality, it doesn't matter to me. It's not like BMW recommends the best based on lab results. They are recommending Castrol over Shell because Castrol paid more
Chapperss492.00
jjasonSU194.00
      10-26-2020, 02:03 PM   #12
CTSean
Does BMW actually recommend Castrol anymore? The used to but switched to Shell a couple years ago
      10-26-2020, 02:25 PM   #13
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Yes you're correct but times are changing.
      10-26-2020, 03:20 PM   #14
BzsBimmer
BzsBimmer's Avatar
3274
Drives: '23 G80 FO M3, M3 & MY Tezzy's
Now BMW has Motul branding on some of their race vehicles... so there’s another option.
A lot about oil in general can be found on BITOG forum.
      10-26-2020, 03:44 PM   #15
Mason Hatcher
Drives: BMW 230i
Why it it matter?
      10-26-2020, 04:26 PM   #16
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
Castrol isn’t an approved oil for my M2. It isn’t LL-01 approved.
      10-26-2020, 04:27 PM   #17
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Why it it matter?
Back in the day it was alleged that Castrol was in close development with BMW and enthusiasts were adamant about using it. I'm not talking about TWS 10w60.
Just curious if things have changed.
      10-27-2020, 09:15 AM   #18
CTSean
As far as I can tell, Castrol Edge Euro 5W40 is the only current LL-01 oil they offer.
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/BC02228946E6670C802585B300470DFA/$File/WEPP-BRY7K6.pdf
      10-27-2020, 09:29 AM   #19
ga9213
Drives: 2018 X3 M40i
Nope, I'll still use my preferred brand. Spend enough time over on BITOG and you'll know what you want/don't want and the mystery behind BMW oil approvals is better understood.
      10-27-2020, 09:34 AM   #20
MPOWER5266
Drives: 1997 Dinan m3
Nope, I will have Liqui Moly in all my cars the next time my 02 gets an oil change. They are all far far far out of warranty so I use what I want.
      10-27-2020, 09:34 AM   #21
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
Drives: 11' 335is DCT
I understood less by going on BITOG lul
