03-31-2023, 10:33 AM | #991 |
Riding the knock sensor
2371
Rep 1,595
Drives: 21 X5MC | 23 M4CSL
Yellow
MadBimmeRad7122.50 |
03-31-2023, 10:47 AM | #993 |
1122
Rep 7,690
There you go. Both running, lights off
03-31-2023, 10:51 AM | #994 |
2371
Rep 1,595
First pic, car off parking lamps on (white). Start car with headlamps off, yellow (marker is lit in photo cause parking lamps were on). Basically yellow whenever car is running regardless if headlamps on/off or high/low. Of course, you can disable DRL but only a psychopath would do that.
03-31-2023, 10:53 AM | #995 | |
1122
Rep 7,690
I don’t think I’ve ever seen mine white. Let check and report back. Just flushed the brake fluid cause the pedal is getting soft under spirited driving. Lots of bubbles came out. |
03-31-2023, 10:59 AM | #996 |
2371
Rep 1,595
That's surprising - how spirited, enough to boil the fluid?
HudsonHornett1258.00 MadBimmeRad7122.50 |
03-31-2023, 11:02 AM | #997 | |
Rep 658
Agree with your view of the car though, it's genuinely awesome to drive, can't wait to get it on track.
Current BMW M4 CSL, X3M Competition LCI
Gone but not forgotten: X3 M40i, X3 35d M Sport, M235i, BMW 125i Cab, E92 M3, E36 M3 Saloon |
Hit_Apex2370.50 MadBimmeRad7122.50 |
03-31-2023, 11:04 AM | #998 |
1122
Rep 7,690
The interesting thing is, there was some fluid outside the reservoir that I noticed.
It was early morning and zero cars on the road and I wanted to see what’s the top speed was. I did a couple pulls back to back and when I got on the back roads, I noticed the brake pedal wasn’t as before and the travel was more. Same thing happened to me in the M5 CS and after a proper flush with proper fluid, stops on a dime. |
03-31-2023, 11:19 AM | #1000 |
Rep 405
03-31-2023, 01:34 PM | #1001 |
Rep 799
What pressures are you guys running on the ps4s. I noticed in the garage today while taking it around the block I was set to 48-50… way to high and need to lower it to correct psi. Was thinking a 32-36?
03-31-2023, 01:36 PM | #1002 |
1122
Rep 7,690
HudsonHornett1258.00 02M3ForMe4264.50 |
03-31-2023, 01:48 PM | #1003 | |
Senior 1Addict
5166
Rep 2,426
Drives: BMW iX, Porsche GT4 RS
I had the carbon bucket seat adjusted at the break-in. Went down to the lowest of the 3 settings (car came in the middle setting) with mid-level of tilt. I’m 6’0” and that seems to be perfect for me. |
03-31-2023, 05:25 PM | #1004 | |
2371
Rep 1,595
HudsonHornett1258.00 |
03-31-2023, 05:41 PM | #1005 |
2371
Rep 1,595
Here are a couple options I use to adjust seat tilt in position for the race buckets. If you need to change among the three slots you have to remove the seat, but once you get your slot - these tools will help dial in tilt. You may want to set a different tilt for track, spirited driving, long trips, etc. Easily done with these tools which I now carry in the car.
My preferred option uses one of my favorite tools - the Ares Micro Bit Ratchet. An awesome bit of kit, with a T45 torx bit and a 1/4" hex extension inserted into the end of the ratchet. So slick. The other option is a T45 from this set of low-profile ball detent bits coupled with a 13MM ratcheting wrench. Bit pops in securely but you need to flip it to reverse direction. Downside here is that it is shorter so you lose some leverage but is easy to control. The detent bit set is pricey.
03-31-2023, 06:49 PM | #1006 |
Rep 405
Will someone be an absolute legend and measure the width of the red bonnet stripes for me? 😁
I’m going to order some red stripes and stick it on my black 3CS bonnet so it’s not tooooooo stealthy. Even a rough estimate will do… 5mm, 7mm, 10mm? 😄 |
03-31-2023, 07:38 PM | #1007 |
Rep 152
The design is asymmetric: ~10.5 mm on the narrow side, ~24 mm on the wide side. Good luck with the stripes! Please post a picture showing the final product.
Current: 2023 Frozen Brooklyn Grey ///M4 CSL Retired: 2022 Frozen Dark Grey ///M3 ||| 2021 Tanzanite Blue X7 ///M50i ||| 2016 Mineral Silver X5 40e |
02M3ForMe4264.50 |
03-31-2023, 11:11 PM | #1008 |
M4 CSL FBG
1268
Rep 1,871
I had my CSL coded with anti dazzle and the only way that it could be done fully was to have Euro spec which the yellow DRL is only on when low/ high beams are one, alarming on/ off car. The rest of the time it’s white.
16' M4 GTS Frozen Dark Grey Metallic
14' i8 Sophisto Grey Pure Impulse World 08' E92 M3 Jerez Black |
04-01-2023, 04:04 AM | #1009 |
Rep 405
04-01-2023, 05:00 AM | #1010 | |
Rep 405
Is the strip one width through out the whole side on both sides? Or does it get narrower as it gets to the bottom. |
04-01-2023, 05:18 AM | #1011 |
Rep 658
Oh brilliant - thanks!
04-01-2023, 09:32 AM | #1012 |
Rep 152
Hard to tell because the hood indentation (on each side of the exposed CF) gets progressively deeper near the front. The red stripe sits right on that indentation and it is hard to measure its width (down to mm precision) because this is not a flat surface. Sorry I can't be of more help this time.
BmwFanBoy94436.00 |
