03-02-2024, 03:51 AM | #1 |
Rep 252
Drives: BMW G82 M4 Competition
AA catted downpipes not lining up with Valvetronic single midpipe
Has anyone had an issue with Active Autowerke catted down pipes not lining up with a Valvetronic single mid pipe?
The shorter AA downpipe fits with the long stock downpipe but when you try both the alignment is thrown off. Guessing the long downpipe is off. Had a second set of downpipes delivered from AA and still the same issue. We don’t want to heat and modify the downpipe but we are running out of ideas. |
03-02-2024, 10:40 AM | #2 |
Rep 190,807
did you test them with the stock parts?
03-02-2024, 10:44 AM | #3 |
Rep 252
Yes, we tried interchanging the stock and AA short and long downpipes. The short AA worked with the long stock. We even had two sets of downpipes from AA and tried both long downpipes. One was better than the other but still didn’t fit.
The fact that they have multiple configurations is telling us that this problem is common. |
03-02-2024, 12:26 PM | #4 |
Rep 1,929
Which part did you install just now, the aa downpipes or the valvetronic exhaust?
If you just installed the aa downpipes and took out the stock ones that were connected to the valvetronic midpipe then the aa downpipes are messed up.
03-02-2024, 07:34 PM | #5 |
Rep 252
Correct! The single midpipe has been in for a couple of months and worked fine with the stock downpipes. The midpipe even works with the stock long downpipe and AA short downpipe. It’s when you try to install the long AA downpipe that it throws everything off.
03-02-2024, 08:02 PM | #6 |
Rep 1,929
Sounds like the jig at the supplier moved then, refund time.
03-02-2024, 08:06 PM | #7 |
Rep 252
Had to!!! There’s not much room to maneuver in these engine bays. The fitment of the downpipes should be laser accurate. The fact that there are different iterations of pipe configurations (this is the replacement set that also doesn’t fit) shows that this isn’t there first time experiencing this problem:
03-03-2024, 05:45 AM | #9 |
Rep 252
03-03-2024, 10:10 AM | #11 |
Rep 150
I had the same issue with the AA downpipes not lining up to the stock mid pipe. I ended up pinching the o2 sensor unfortunately. I ended up cutting the welds off the bolts that ******t to the mid pipe as they were not welded on square.
03-04-2024, 03:38 PM | #12 |
Rep 252
We are going to do the same. Sucks that they don’t line up. It’s not that there off by a hair either, they are significantly off.
03-04-2024, 03:42 PM | #13 |
Rep 252
We didn’t try that, but it might make sense. With equal length pipes you can make up for small adjustments by moving the midpipe right, left, up or down. Having the single midpipe doesn’t leave a lot of room for error since the fitting where the pipe splits is so close to the connection to the downpipes.
03-04-2024, 05:36 PM | #14 |
Rep 252
03-05-2024, 11:13 AM | #15 |
Rep 190,807
03-05-2024, 10:07 PM | #16 |
Rep 252
Again, you’re the man!!! A little modification to the midpipe and we are back in business.
03-06-2024, 01:35 PM | #17 |
Rep 190,807
03-06-2024, 05:00 PM | #18 |
I drink and I pretend to know things.
119
Rep 226
Everything AA I've ever touched has been top quality. Ain't no GD way I'd pay the kinda M tax they charge on any of these components and have to modify them. Mix'n brands may have played a part but worries me. 3K for AA or Apex DP's with a reasonable quality (GESI) cat.
Sonic |
03-06-2024, 05:02 PM | #19 |
Rep 252
Info@mad-us.com1925.00 |
