02-26-2024, 05:08 PM | #1 |
Rep 97
Very loud coldstart
Hey! Just mounted the equal lenght midpipe for AA and the cold start even with valves closed is too much for my family,the rattle doesn’t help either! Would removing the cold start affect the car?
02-26-2024, 05:27 PM | #2 |
6918
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
Lol
02-26-2024, 06:02 PM | #3 |
Rep 1,929
Just get the dme unlocked, install bm3 and disable coldstart...
02-26-2024, 06:32 PM | #4 |
Rep 477
02-26-2024, 06:37 PM | #5 |
Rep 477
02-26-2024, 07:31 PM | #6 |
Rep 338
I dont think you can remove cols start without tuning. So for the time being, you can minimise the noise by shifting into gear immediately after starting engine, and let it roll slowly out of garage. I also put gear in reverse to go back and forth. After 20 second then the cold start is gone.
In other words, if you keep the car moving right after starting, then you can minimise the cold start noise 80%. |
02-27-2024, 12:06 AM | #7 |
Rep 687
I just installed an AA single mid with SST valve controller.
I put the car in drive ready then hit B to force the valves closed. It sounds stock during warm up. |
02-27-2024, 09:11 AM | #10 | |
Rep 97
02-27-2024, 09:16 AM | #11 |
Rep 1,929
What can module? If you can then do it.
02-27-2024, 10:31 AM | #14 |
Rep 1,929
What can module did you install? Cold start is for emissions, if you care about the environment then keep it turned on, turning it off won't destroy the downpipes.
02-27-2024, 11:34 AM | #15 |
Rep 190,807
removing the cold start wont hurt the car, as mentioned above, you can do so with a flash tune.
02-27-2024, 12:42 PM | #16 |
Rep 4,924
As said above removing cold start with a tune will fix your issue.
02-27-2024, 06:53 PM | #17 |
Rep 477
I start the car in the garage leaving it closed with my valve controller set to close. If you're still using the factory valve control they still open even in comfort mode.
The combination of both keep my neighbors happy. |
02-28-2024, 11:12 AM | #19 | |
Rep 190,807
the cold start loud sound is produced by the car's software not the valves
RACE M3548.50 |
02-28-2024, 02:38 PM | #20 |
Rep 277
Cold start is dumping extra fuel/air to rapid warm the catalytic converters to proper operating temp. ECM also ignores the o2 wideband for the short time - OpenLoop.
disabling hurt anything? no - just inefficient cats and shorter life. I guess coming from a Jeep Grand Cherokee srt with a custom supercharged 448 cu inch straight pipe... I find cold start 'quiet' |
02-29-2024, 07:40 AM | #21 |
Rep 858
^^^ That’s incorrect. The ColdStart routine doesn’t dump extra fuel… the system adds air via the exhaust ports/runners and secondary air pump so the primary CATs heat up faster. Cold start enrichment is outside of this and a normal process that’s done even if you turn off Cold Start. Your engine should still have a high initial idle during the cold start enrichment phase for a few seconds and then die back down to 700ish RPM, just the CATs won’t be as quick up to temp to help scrub exhaust gasses as quickly… it’s totally an environmental thing and nothing more. If anything, turning off Cold Start routine for some engines will actually solve issues like secondary air injection plugging up over time due to carbon deposits in the system, which is a byproduct of this routine. It doesn’t hurt the CATs at all.
02-29-2024, 02:43 PM | #22 |
Rep 190,807
