08-29-2023, 01:40 PM | #45 | |
Rep 880
Any more bearing failures ?
2022 G80 M3 6MT
2020 G20 330i xDrive 2011 E90 335i xDrive 1996 E36 318i |
08-31-2023, 07:17 AM | #46 |
Rep 217
Drives: BMW M3 Competition XDrive
I went with the B58 gen 1 bearings. 😂
But from what I saw recently, starting to believe that this wear is normal in the oem s58 bearings. They just designed that way. Car with 30 miles- they look the same like mine.
m3inquisitor -- XtremWerk XW12 Twin Frame Turbo Setup -- Build Motor -- Reworked Cylinder Head -- Upgraded Transmission -- R44 Titanium Exhaust -- xHP Stage 3 -- Unlock Femto + bm3 -- Custom Tune by odintuned --
chris7197334.00 |
02-13-2024, 10:52 PM | #47 |
Rep 7,299
I am starting to think this is a feature of the Glyco material they use on these bearings. They claim they are "intelligent" bearing materials that get harder after the wear-in layer is gone. How are your B58 IROX bearings holding up? I am still not sure why they used the S63 rod and bearing assembly in S58. The S63 and therefore S58 rod bearing is the same material used in N54, N55, S55, etc. The B58 bearing seems superior but there must be a reason unless they never validated the combination of S63 rod with new bearing design and didn't want to spend the money.
02-14-2024, 08:59 AM | #48 |
Rep 1,929
It's not the s63 rod.
02-14-2024, 09:55 AM | #49 | |
Rep 2,076
Rods are pretty much in the same condition.
Dnshift156.50 |
02-14-2024, 10:55 AM | #50 |
Rep 7,299
02-14-2024, 12:32 PM | #51 |
Rep 857
Proper fueling and that Motec along with a really good tuner who’s dead on familiar with every inch of that standalone will get you an engine that won’t blow up. It’s all in the tuning really and where most general tuners will lean a lot on the ECU safeties to keep things in check for most street tunes, you can’t keep expecting timing pull via knock feedback to save the day. Most really good Motec standalone tuners will tune like the Euro and Aussie tuners tune and that is, they will load the drivetrain at every single load point on the tune when on the dyno and check the limits of that load point before the engine either doesn’t make any more power or it develops knock, then back off that limit by a good margin. What ends up happening is you get a tune that you literally can bang on 24/7 no matter what and the combustion chamber never gets anywhere near knock for correction safeties to even kick in. Those tuners know not to ride the safeties and their engines last. You don’t ride the bleeding edge of the VE of an engine at every load point and you won’t have issues. I never understood why more tuners in this country don’t have the same philosophy as the other side of the pond. 🤷*♂️
02-14-2024, 01:07 PM | #52 | |
i can haz horsepowr ??
3831
Rep 1,927
I think many tuners are pushing these S58's and even their own abilities to the bleeding edge simply because the end user wants to achieve xyz record or goal. Stock motor 1/4 with full interior, upgraded turbos with no interior, stock motor and trans on Pirelli's, and so forth. These micro records are being chased constantly and while it's great to have a goal in mind and executing them, doing so just for the sake of gloating on social media feels disingenuous and is leading to a lot of people finding the limits of the S58 as it stands now. I understand aftermarket shops like MPower House, Autocraft, MLife, RK Tunes, etc. going to a friendly war with one another in order to obtain records and gain clientele - it's business. But when typically normal guys 'n gals with big wallets go at each other with these "micro records" - we see cars having issues and the negative affects of social media. The fact is, the S58 is still in its relative infancy. We don't even have a fully unlocked DME yet. femto don't fully unlock these DME's for MHD/bootmod3 to use at their unfettered disposal, hence the reason why it has to go back to femto for any sort of major update like rev2 on bootmod3.
Dakar Yellow G80 M3
10SecGG504.00 |
02-14-2024, 02:06 PM | #53 | |
Rep 1,929
Skip to 5:02 https://youtu.be/o9X8zrMYy94
chris7197334.00 |
02-14-2024, 05:40 PM | #54 | |
Rep 7,299
02-15-2024, 07:40 AM | #55 |
Rep 857
It was my understanding that this was due to how BMW had handled the lock of them and how FEMTO, while still able to unlock them, had some limitations in how they were able to still do it. Are you saying you have credible info that says otherwise and FEMTO is asking a premium for a DME unlock that “should” be the same as before but isn’t because of a decision they made to either keep control or make more money out of additional unrequired transactions? Please do elaborate.
02-15-2024, 03:34 PM | #56 | |
BM3 Tuner
292
Rep 272
And from what I heard no one state side really wants to unlock due to possible lawsuit reasons with Bosch, over in Finland they are pretty much lawsuit safe.
2019 BMW X3M40I - VRSF Downpipe, XHP Stage 3, Nostrum Stage 1 Injectors, VTT PCV and Oil cap.
Paul Johnson Tunes Shop/Development Car |
02-15-2024, 04:15 PM | #57 | |
Rep 857
02-16-2024, 02:01 AM | #58 | ||
3831
Rep 1,927
An example that gives credence to my claim is the fact that there are many out there running pre-June 2020 DME's on the G8X by getting their hands on X3M DME's from before that date. The X3M, remember, has the S58 and as a result, can be used on the G8X. Merrick, whom is the owner of M PowerHouse and is currently #3 on the list of fastest G80's out there, recently told me how nice it was that he didn't have to send his DME to femto at all since he's on a pre-June 2020 DME. When PTF released CustomROM, he had to just flash it whereas everyone that had a post June 2020 femto unlocked DME had to send their DME back to femto just to get CustomROM. Further evidence is found in how femto is handling the release of bootmod3's rev2 board. Again, all of us with already "unlocked" DME's from femto will have to send it in again to get rev2 functionality. If our DME's were truly unlocked, surely we could just flash it right? Nope, because it's not really completely unlocked. femto are basically allowing the tuning platforms bootmod3 and MHD small bits of access to the DME in order to code and do the things that they need to do. You've said it in far more fancier terminology than I have, but you're correct - they're limiting functionality for sure. This is done so as to not have their unlock reverse engineered and figured out by someone else. This is part of the reason why rev2 is taking so long - PTF is being forced to do a lot of work with their hands tied behind their backs essentially, all because femto won't supply us completely unlocked DME. It's a business and I understand it, but it just completely sucks for the end user that has to pay exorbitant amounts just to get some relatively basic functionality. It's extremely unlikely femto will ever completely unlock the DME as it'd literally turn their extremely profitable business to smithereens, but such is life. Thankfully, MaxxECU is showing strong promise as a port controller/ethanol analyser that connects via CAN bus and has a lot of functionality.
Dakar Yellow G80 M3
03-01-2024, 12:26 PM | #60 |
Rep 24
Incase you didn't see my post at the end of this thread, I'll ask it directly. I am planning on putting a s58 in a 93 Defender. Would the B55 be better? looking for around high 500 to low 600 HP @ the wheels
03-01-2024, 12:48 PM | #61 |
Rep 880
What's a b55
2022 G80 M3 6MT
03-03-2024, 09:05 AM | #63 |
Rep 989
Drives: 2024 M4 Comp X-Drive
Did you have any oil pressure issues or rod knock? Did you actually spin a bearing or was it just wear found at tear down and the motor was otherwise operating normally?
03-03-2024, 12:45 PM | #64 |
Rep 857
If you’re taking about those pics on page 2, that’s the coating on the bearings that’s wearing down as the engine works. Majority of it is the main crank ones, but they all do it. If you look carefully, you’ll see there is no scoring or scratches on the shiny spots, which means it’s fine. This coating is meant to come off as the engine breaks in… hell, you can even see the QR code still on them. Not sure why people are freaking out. Even the lines in the coating can still be seen. That engine is pretty fresh still.
ChrisM41627.50 |
03-03-2024, 12:51 PM | #65 | |
Rep 989
03-03-2024, 02:57 PM | #66 |
Rep 857
Yeah, if anything, it actually shows that the tolerances are larger than what people seem to think and BMW’s only reason for running a thin FE 0w30 oil is strictly for emissions and certainly not because the tolerances are tighter and requiring a thinner oil. The drift brothers for Motul ran 50 weight on their stock bottom end and it was fine. I personally wouldn’t run more than 5-40, but I’m gonna use the 5-30 Motul one initially and gauge it from there. I tend to drive my engines hard and 🤞considering the S4 engine passed 200k on Motul 5-40 excess gen 2… well, it’s my favorite by far.
ChrisM41627.50 |
